Old 04-04-2019, 05:17 PM   #99
Code Monkey
Drives: Subaru BRZ
Raised the rear 1/4" and got an alignment today. Opted for 1/16" toe in both front and rear.
Code Monkey is online now   Reply With Quote
Old 04-08-2019, 03:08 PM   #100
kch
Senior Misanthrope
kch's Avatar
Why did you decide for some toe in the front? Having braking issues?
Old 04-08-2019, 03:31 PM   #101
Code Monkey
Drives: Subaru BRZ
The car was a little bit too wiggly under hard braking. With a little bit of toe in, no problems last weekend at COTA. Will have a better comparison this weekend at MSR Houston.
The Following User Says Thank You to Code Monkey For This Useful Post:
kch (04-08-2019)
Old 04-09-2019, 12:40 AM   #102
FRStevan
Drives: 2013 Scion FRS
How do you like the Ferrodo's? I see you use them quite often. I've got a set of ds2500's but I feel like they won't cut it for the upcoming track season.
FRStevan is offline   Reply With Quote
Old 04-09-2019, 08:59 AM   #103
Code Monkey
Drives: Subaru BRZ
The 2500's are street pads, the DS1-11 are race pads and I love them. You can see the differences between the different compounds here.
Takumi788 (04-09-2019)
Old 04-09-2019, 10:05 AM   #104
Pat
Pat's Avatar
Drives: 2023 BRZ
A fellow 86CUPer just switched from DS1.11 to DTC-60 last weekend. He much preferred the DTC-60s. I have not driven the DS1.11s. Have you driven both?
I think the 2500 is a good dual-purpose beginner pad, but that's about it. It is certainly a compromise, as it is a dual-purpose pad. But it is less compromise than others, IMO.
Old 04-09-2019, 11:04 AM   #105
FRStevan
Do you think you can run ds1.11 on the front while having ds2500 on the rear?
Old 04-09-2019, 12:21 PM   #106
Code Monkey
Drives: Subaru BRZ
I have used the DTC-60 but on a different and much heavier car. Glazed the pads in one weekend.
You could try it, may work just fine. I run the DS1-11 both front and rear, the fronts last me 4-5 weekends, I am on 4th set now. The rears I put in at 1,189 miles, I am at 16,xxx now, 19 hpde weekends and they are worn less than half way.
Old 04-09-2019, 01:05 PM   #107
Pat
Pat's Avatar
Drives: 2023 BRZ
Clearly different compounds work with different cars. I wonder what you would think with them on an 86.
Old 04-09-2019, 04:23 PM   #108
Code Monkey
Drives: Subaru BRZ
Would probably work better on the 86 platform. I also like Cobalt Friction but holy shit, are they dusty.
Old 04-09-2019, 05:58 PM   #109
Tristor
Tristor's Avatar
I noticed that on both the front and the rear you run slightly more camber on the left side than the right side, is there a reasoning behind not have a zeroed out cross-camber?
Tristor is offline   Reply With Quote
Old 04-09-2019, 06:32 PM   #110
Code Monkey
Drives: Subaru BRZ
I am not a pro driver and doubt I will feel the difference if the camber is not perfectly even side to side. The toe I want to be dialed in exactly.
In the rear, I have UCAs and camber is adjustable in about half a degree increments so I am stuck at what it is.
In the front, with my weight in the car the front left is actually -3.7 so I can live with -3.7 and -3.6.
Old 04-10-2019, 11:12 AM   #111
Tristor
Tristor's Avatar
I hadn't thought about how weight might affect it. I guess that's true that even if you were to get them exactly even on a rack, if your weight isn't in the vehicle they'll be off again. That's good to think about. I'm headed to Austin all day tomorrow to finally get my car corner weighted and a track alignment, so I'll make sure to ask that they do the alignment adjustments with driver weight in the car.
Old 07-26-2019, 06:39 PM   #112
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Wait, isn't toe out the right solution?
Berzerk's 2017 CWP 'Slow and Steady' Build Thread Berzerk Member's Car Journals 12 07-24-2017 04:57 PM
Rodie's slow '13 FR-S build rodie Member's Car Journals 0 06-14-2015 08:05 PM
Slow Progression FRS Build dgerny Member's Car Journals 1 04-15-2014 06:48 PM
Tkalz slow build! Tkalz Member's Car Journals 15 10-13-2013 05:35 PM
Slow Build by Jooks jooks Member's Car Journals 4 07-03-2013 10:53 PM
