Old 06-24-2018, 02:45 AM   #43
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
Hello, what is the axel nut torque spec? Seems to be missing.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
The Following User Says Thank You to Lakitu For This Useful Post:
Ryan GT86 (02-13-2019)
Old 06-24-2018, 04:00 AM   #44
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
140 ft-lbs according to this thread:
https://www.ft86club.com/forums/showthread.php?t=45949
FYI (for anyone actually) if you're looking for torque specs on things not named on this list at the start of this thread. Google or look for DIYs on installs for the thing your doing. Even aftermarket parts will tell your their torque values which they most likely pulled from the OEM service manual.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
gravitylover (03-23-2019)
Old 08-25-2018, 12:51 PM   #45
Gunman
Drives: 2019 Mazda Miata RF
Anyone put this into pdf, or a spreadsheet, so it can be printed, and put in toolbox/posted on wall?
The Following User Says Thank You to Gunman For This Useful Post:
RL_BRZ (09-06-2018)
Old 03-04-2019, 06:53 AM   #46
Ryan GT86
Ryan GT86's Avatar
Drives: 2019 Toyota 86
https://www.counterspacegarage.com/a...ut-bar-brz-frs
Does anyone know which torque values to use? I know there's these values.
Strut Tower (FR) | 17
Strut Tower (R) | 22
Strut Tower Bars | 12
But I'm not sure which corresponds to which.
Ryan GT86 is offline   Reply With Quote
Old 03-04-2019, 07:36 AM   #47
zeal86
zeal86's Avatar
Drives:
It's been a while since I started this thread and/or messed with my strut tower brace and bars but I'm sure it goes like this...
>>The long brace going across from strut tower to strut tower is the higher torque value... the shorter bars that connect to the firewall are the lower torque value. The other value is for the rear strut tower brace.
Make sure to use a calibrated torque wrench. Good luck...
IG @zeal.eightsix
zeal86 is offline   Reply With Quote
Old 03-04-2019, 03:43 PM   #48
Ryan GT86
Ryan GT86's Avatar
IG @zeal.eightsix
So the 17 ft lb value is only for the rear?
Old 03-04-2019, 04:06 PM   #49
zeal86
zeal86's Avatar
Drives:
22 rear (R) Brace
17 Front (FR) Brace
12 for the two Bars
IG @zeal.eightsix
The Following User Says Thank You to zeal86 For This Useful Post:
Ryan GT86 (03-05-2019)
Old 04-08-2019, 05:55 PM   #50
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
I’m removing an oil pressure sensor that’s tapped in the engine galley. I got SU003-00108 but I need the torque value to tighten it to.
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8
the new guy is offline   Reply With Quote
Old 05-14-2019, 12:49 PM   #51
Sonic23
Drives: BRZ Series HyperBlue
Thumbs up
Thanks for the useful thread, it's been helpful.
Sonic23 is offline   Reply With Quote
Old 06-18-2023, 04:41 AM   #52
r4mr4m3024
Drives: gt86
Hello, I didn't understand exactly and I don't know its name. I want to tighten the central nut inside the front coil and also the rear coil because I changed the springs, but I don't know how many newton meters it should be for the front and rear? Please help me, thank you
r4mr4m3024 is offline   Reply With Quote
Old 06-18-2023, 10:16 AM   #53
Ohio Enthusiast
Drives: 2018 BRZ
If you are talking about the shock mount nut, it's 55 Nm front, 25 Nm rear. Be sure to keep the shaft from spinning (for stock shocks you can use an Allen key to hold the shaft and a passthrough socket wrench to tighten the nut).
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
r4mr4m3024 (06-20-2023)
Old 06-19-2023, 11:34 AM   #54
r4mr4m3024
Drives: gt86
Thank you, and how many newton meters should the anti-roll bar link front be tightened?
Old 06-20-2023, 08:43 AM   #55
Ohio Enthusiast
Drives: 2018 BRZ
That would be 46 Nm front, 38 Nm rear. This applies to both ends of the endlinks.
Old 06-20-2023, 01:42 PM   #56
r4mr4m3024
Drives: gt86
Hello, dear guys, I would like to ask you for an opinion. I would appreciate it if you could give me your opinion. I bought short springs for my car, brand H&R, the original element, my element, then I changed the spring connection base, the screw inside the shock absorber coil and the front stabilizer, and I changed the screws. I didn't use a torque meter, I tightened them as far as possible, I drove the car for a while, everything seems to be ok, is that the case or should I be worried about something? Of course, I went through all the steps with the specialized video on YouTube, I did the right steps, but I didn't torque the screws of the shock absorbers and stabilizers with a torque meter, and I tightened them as much as I could with my hands.
BRZ Steering Right Tightening + VSC Fault?? BRZ2Bars Issues | Warranty | Recalls / TSB 4 05-07-2015 04:58 PM
BRZ Values Apex_BRZ BRZ First-Gen (2012+) — General Topics 20 10-16-2014 06:38 PM
Front Oxygen Sensor Scaling - How do we make it read richer values? D-VO Software Tuning 7 05-08-2014 05:48 AM
Safe values? mike_ekim1024 Software Tuning 12 11-05-2013 02:19 PM
Tightening the Rear scottynoshotty Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 05-16-2013 01:57 PM
