Old 04-05-2019, 12:56 PM   #1
juniorrr
Drives: Scion Frs
What’s the Best Oil for e85?
Hey guys so I just started running e85 about almost 3,000 miles in and I was wondering what do you guys recommend for the type of oil for e85 and also in intervals of how many miles should I change the oil? And any other tips I should know about e85 and oil. The dealer only has 5w30 Pennzoil (sn/gf-5) synthetic but I don’t know if those are good for e85? Thanks Ahead if time!
juniorrr is offline   Reply With Quote
Old 04-05-2019, 01:05 PM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
http://www.ft86club.com/forums/showthread.php?t=67310
http://www.ft86club.com/forums/showthread.php?t=59585
http://www.ft86club.com/forums/showthread.php?t=126406
https://www.ft86club.com/forums/showthread.php?t=114784
BigTuna is offline   Reply With Quote
Old 04-05-2019, 01:43 PM   #3
juniorrr
Drives: Scion Frs
So I guess there’s no one true answer for this huh? The dealer has 5W-30 Pennzoil Pure Plus (meets specs for ILSAC GF-5 / API SN ) have you heard of this oil being good for FA20’s on e85? Thank you btw for those links!
Old 04-05-2019, 01:52 PM   #4
Tokay444
Run some oil. Take a UOA. Tell us the results.
The Following User Says Thank You to Tokay444 For This Useful Post:
Migit109 (04-05-2019)
Old 04-05-2019, 04:19 PM   #5
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
i ran synpower 0w20 for a year and blackview said i looked great. im currently YOLOing it with amazon 0w20 and will report back after 5k miles
The Following User Says Thank You to Breadman For This Useful Post:
finch1750 (04-05-2019)
Old 04-05-2019, 07:54 PM   #6
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Motul Gear 300.
The Following User Says Thank You to x808drifter For This Useful Post:
Tokay444 (04-07-2019)
Old 04-05-2019, 08:28 PM   #7
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Any oil rated for API SN /w Resource Conserving // ILSAC GF-5
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
eastendraceshop (04-08-2019)
Old 04-05-2019, 09:18 PM   #8
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I run AMSOIL 5w30.
Old 04-05-2019, 10:08 PM   #9
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
The best oil you should run is under deez nuts!
But seriously run what ever fucking oil you want or want to be fan boy part of.
Mobile 1 for life bro!
Fuck Amsoil, Pensoilz, cock-sucking Motul, and Royal-butt-fucking Purple.
The Following 2 Users Say Thank You to Mr.ac For This Useful Post:
fika84 (04-10-2019), Sportsguy83 (04-06-2019)
Old 04-08-2019, 04:30 PM   #10
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
IceFyre13th is offline   Reply With Quote
Old 04-10-2019, 02:34 PM   #11
fika84
fika84's Avatar
Oh man that gave me the happies.
fika84 is offline   Reply With Quote
Old 01-03-2023, 05:38 AM   #12
Sam86
Drives: Toyota 86 GTS
Sorry for bump,
Every thread has different opinions, hard for someone with no knowledge to make a decision.
I’ve ran e85 only for the past 30k kms, I’ve just used the standard oil recommended for the stock car and changed the oil every 5k kms. I want to go with a more focused oil and have settled on 0w-20 as that seems to be the most common answer.
Just wondering if there is any noticeable difference between the Penrite Enviro+ 0w20 and the Valvoline synpower 0w-20.
Penrite seems to have better reviews but only comes in 5L whilst the Valvoline seems slightly better value as it comes in 6L.
Sam86 is offline   Reply With Quote
Old 01-03-2023, 08:13 AM   #13
KillerBMotorsport
KillerBMotorsport's Avatar
The best oil you can run doesn't matter nearly as much as changing it more often.
Let the UOA tell you how long you can go but start short and work your way up.
One of our big power shop mules we change every 1K miles, and it reeks, but the UOAs say it's still good.
KillerBMotorsport is offline   Reply With Quote
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
DarkPira7e (01-03-2023)
Old 01-04-2023, 05:25 PM   #14
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Running E85 and Mobil 1 0w30 or 5w30 whichever I can get. It gets hot in Florida. Peak street oil temp runs 210-220. Change at 5k, or 6 months. Numbers come back fine every time, but I slipped up and went 7K before changing the last time. Aluminum was ever so slightly high, but not sure that could have been the cause.
Qwimby1 is offline   Reply With Quote
