Old 04-06-2019, 05:13 PM   #54839
They liked the offer, but they want us to commit to closing on our house 30 days from now, which is not realistic. We are just now getting inspections etc. And expect to put it on the market in a couple weeks. They think I will have trouble selling my house in the hottest market in the world now.
What is really silly is they want 30 day close, then want 1-2 months rent back because they are in the same situation as us: have a kid graduating high school first week of June. What would be wrong with a 60 day close? We both need time? Oh well.
Well, that is unrealistic, unless they find a "cash" buyer, even at that, a 30 day close is tight.
humfrz is offline
Old 04-06-2019, 06:05 PM   #54840
cjd
cjd's Avatar
Drives: 2017 BRZ
yes, actually. my company does do work in chicago. we're based out of indiana, just over the border in schererville, i grew up in crook county though. (i don't really do side work, as i've got too much updating on my own place to accomplish!)
edit: re-reading your post, it sounds like you've already checked for ground-- it could just be as simple as a bad outlet that you're plugging into. sometimes the prongs that grab the plug stretch out and the outlet just needs to be replaced. <snip/>
I might ping you later - even if y'all can't help me directly I've found usually folks in the trades know each-other. I don't look for work on the side typically, when it's also a day-job. I'm open to it, but I never ask for it. Just seems wrong.
House was actually built in '03. New foundation (deeper, longer than the traditional Chicago house, still standard 25x125 lot...) so we don't get the tax break for being on an old foundation. I've already replaced the outlet, twice. Should be wired right, I tested for hot. Next step is to run a fish tape through to see if it catches on anything (test for breaks in the conduit best I can). Hope to avoid trenching since the line goes under the cement poured-in-place A/C pad (only one of two units is still on it... it was placed under the deck, stupidly... that's bad for condensers - and it HAD to be under something because it's actually below the back door...)
I've probably messed up code on the DIY front already... had to move some walls and outlets. Had to cap a gas line (I had that work checked... actually asked the guy to fix it and he said it was done right - he still fixed a bad waste-water joint that was leaking at the washer drain...) I try to read all the rules and stick to them, but...
More fun is trying to figure out how to get new conduit to the front of the house for the home theater. The existing conduit is at capacity.
Yay home ownership.
cjd is offline
Old 04-06-2019, 06:11 PM   #54841
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I schooled my CPA and saved myself big bucks in taxes. Where should I donate half the ill-gotten gains?
EAGLE5 is offline
Old 04-06-2019, 06:15 PM   #54842
soundman98
ProCrastinationConsultant
soundman98's Avatar
to me. let me know when you need my paypal.
soundman98 is offline
Old 04-06-2019, 06:18 PM   #54843
soundman98
soundman98's Avatar
Originally Posted by ls1ac View Post
Just wait till you have to fix a drain pipe in Cook county, cast pipe with lead and oakum. Can not use PVC, keeps the plumbers in work.
there's a lot of cast in the suburbs as well. but most suburbs now allow you to convert to pvc.
Old 04-06-2019, 06:22 PM   #54844
EAGLE5
Dismember
EAGLE5's Avatar
I don't donate to lost causes.
EAGLE5 is offline
Old 04-06-2019, 06:41 PM   #54845
Originally Posted by cjd View Post
...More fun is trying to figure out how to get new conduit to the front of the house for the home theater. The existing conduit is at capacity.
Yay home ownership.
Bubba says to just double tap into a circuit at the main circuit box, then run Romex on the outside of the house, punch a hole in the wall of the home theater room and wire a multiple outlet thingy to the end of the line -
humfrz is offline
Old 04-06-2019, 06:43 PM   #54846
NOT HERE! I ain't about to go to jail for income tax evasion and wire fraud -
humfrz is offline
Old 04-06-2019, 07:07 PM   #54847
cjd
cjd's Avatar
Drives: 2017 BRZ
Can't be any worse than running a 7x200 amp, a 700x2 amp, a 500x2 amp, a 1x200 amp, preprocessor, computer, and projector off a 20A circuit... (thank goodness for soft-starts! And never needing any of that power...)
cjd is offline
Old 04-06-2019, 10:10 PM   #54848
soundman98
soundman98's Avatar
what do you need a 7w x 200ch and a 1w x 200ch amp for?
Old 04-06-2019, 10:15 PM   #54849
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Do tell how.
Sapphireho is offline
Old 04-06-2019, 10:35 PM   #54850
cjd
cjd's Avatar
Drives: 2017 BRZ
I have a 7.2 + shaker setup in the home theater.
7x200 is the main 7... 700x2 is for the 4x15" log throw (36mm xmax) sub in the front wall, 500x2 is the 2x15" long throw setup in the riser for the rear seats. And 1x200 on the front row shakers. The 7x200 is 100 lbs...
Don't look at the pair of 1000W monoblocks I have on one of my other setups... Also on a 20a circuit also 100lbs each. I usually listen at maybe 1/4W output... Just a wee bit of headroom.
cjd is offline
Old 04-06-2019, 11:18 PM   #54851
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I think this simulation has run its course. Back to the bridge.
Old 04-06-2019, 11:39 PM   #54852
Awaiting orders, sir.
Ultramaroon is offline
