Old 04-01-2019, 07:17 PM   #15
juniorrr
Drives: Scion Frs
Originally Posted by Tangizdope View Post
I actually heard it decreases power just a smidge if you remove the sound tube. Because they designed the airflow with the sound tube. But idk for sure. Shouldn't make any noticable difference though. Report back if it helps with the whoosh noise though. I'd try to buy one from someone if it does indeed help.
Yeah for sure bro I'll let you guys know! Also let me know if you guys ever find any other remedies for this lol
juniorrr is offline   Reply With Quote
Old 04-01-2019, 07:24 PM   #16
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
Sound tube no, resonator yes. Mishimoto found this when testing their inlet tube. Though I guess no one has tested stock inlet with and without sound tube.
Weigaldo is offline   Reply With Quote
Old 04-02-2019, 01:24 PM   #17
juniorrr
Drives: Scion Frs
Yeah I just realized today that theres no way for me to put the stock sound tube back in because i have a mishimoto inlet hose LOL. I guess thats a no go then? But hey do you guys happen to know where i can buy the cap that goes at the bottom of the passenger side under the glove depart where the sound tube connects? Its a tiny little whole but you cap it and then take off the sound tube from your engine bay.
Old 04-02-2019, 04:30 PM   #18
JCW 86
JCW 86's Avatar
Drives: 2013 Raven FR-S
Open your glove box and there should be a 12V outlet somewhere back there. Take the cap from there and shove it into the firewall hole. Should be a perfect fit.
JCW 86 is offline   Reply With Quote
The Following User Says Thank You to JCW 86 For This Useful Post:
juniorrr (04-02-2019)
Old 04-02-2019, 06:18 PM   #19
kch
Senior Misanthrope
kch's Avatar
The sound tube has a diaphragm in it, so there's no air going through. It's just there to transmit sound. Removing the tube won't really impact performance.
The Following User Says Thank You to kch For This Useful Post:
Tangizdope (04-02-2019)
Old 04-02-2019, 06:49 PM   #20
juniorrr
Drives: Scion Frs
Wow I didn't know that LOL! Thanks for the advice I just uninstalled the sound tube and my engine bay looks a lot better!
Raspy header and weird noise Scalzo Engine, Exhaust, Transmission 39 08-24-2020 08:40 PM
weird noise sound coming around header area shern Issues | Warranty | Recalls / TSB 28 02-19-2016 08:39 PM
Weird Noise FloridaBRZ BRZ First-Gen (2012+) — General Topics 7 04-25-2014 09:35 PM
Weird Noise??? caradd Issues | Warranty | Recalls / TSB 3 11-02-2013 12:42 AM
Weird noise Touge_ninja Scion FR-S / Toyota 86 GT86 General Forum 3 08-28-2012 02:46 AM
