Drives: 2016 Subaru BRZ
Shark Fin???
So I got a 2016 BRZ in silver. I was going to buy a black vortex generator but I was trying to see if they had covers for the shark fin and honestly I can’t find one anywhere. Is my only option to wrap the shark fin? I feel like that would be a waste when I could simply buy a black cover if they had those. And honestly I don’t even use the radio. If anyone can help me out it’d be great. Or any alternative and cost effective ideas.
#2 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
as in for a shark fin/antenna delete? I've looked into this too and I have yet to find any true aftermarket cover or panel designed for this
there is a thread on these forums where some folks used some sealant and plastic to cover it but to me it looks a bit janky..but with a vortex generator think it would be an even better candidate to fit in a plastic cutout over the hole and seal it, just gotta make sure it is all sealed properly ^^
#3 | |
Well I’m not actually trying to do a delete I just want to get the shark fin matchyy matchyy with the vortex generator. I think a silver shark fin in the center of a black vortex generator might look silly. I just want to change the color of it. Sent from my iPhone using Tapatalk |
#4 |
Rust bucket enthusiast
You can get a black shark fin. Or you can get the vortex generator paint matched
#5 |
#6 |
Pretty sure you need to pull down your rear headliner to access the bolt that's holding it on. Reinstallation is just using the 3m tape provided, as the aftermarket fin isn't bolt-on.
#7 | |
That sucks honestly. You’d think they’d just sell a cover that goes right over it. Or even have the vortex generators cover up the antenna that way it’s a solid color all the way through. But they have the silly cut out. Sent from my iPhone using Tapatalk |
#8 |
Drives: 2017 Subaru BRZ
The TS came with a black shark fin, you could buy that part or find a wrecked black brz and pull the fin off.
Cheapest option would probably be wrapping it...or rattle can
#9 |
The oem shark fins come pre-painted. If you overtighten the bolt you will dent your aluminum roof.
Edit: they are $120, but also that vortex generator is most likely adding drag to your setup. You could consider selling that and keep your current shark fin. |
#10 |
Drives: '15 BRZ RA
Your best option would be to paint the vortex generator silver. A paint shop can do that easily. Check an example here on a blue WRX:
![]() I would say that it looks like factory. |
#11 | |
Drag like weight? And it’s not going to matter when I boost it. Sent from my iPhone using Tapatalk |
#12 |
Drives: BMW E30, 2014 FR-S
#13 |
ProCrastinationConsultant
speed factory also sells a vortex generator that's already painted
| The Following User Says Thank You to soundman98 For This Useful Post: | nikitopo (04-13-2019) |
#14 |
| Oem WRB Shark fin | Falken86 | Want-To-Buy Requests | 1 | 05-17-2017 06:25 PM |
| TRD Shark Fin Still Available? | Bonburner | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 04-16-2015 10:55 AM |
| Shark fin Antennas | Ryan86 | AFRICA | 9 | 04-03-2013 10:32 AM |
| BeatSonic vs VG Shark Fin? | JohnAyySays | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 03-12-2013 01:59 PM |
| Antanna Shark Fin?? | scionfr_s | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 02-20-2013 11:29 PM |
