Old 04-01-2019, 06:43 PM   #1
Howaitoguru
Howaitoguru's Avatar
Drives: 2016 Subaru BRZ
Shark Fin???
So I got a 2016 BRZ in silver. I was going to buy a black vortex generator but I was trying to see if they had covers for the shark fin and honestly I can’t find one anywhere. Is my only option to wrap the shark fin? I feel like that would be a waste when I could simply buy a black cover if they had those. And honestly I don’t even use the radio. If anyone can help me out it’d be great. Or any alternative and cost effective ideas.
Howaitoguru is offline   Reply With Quote
Old 04-01-2019, 07:25 PM   #2
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
as in for a shark fin/antenna delete? I've looked into this too and I have yet to find any true aftermarket cover or panel designed for this there is a thread on these forums where some folks used some sealant and plastic to cover it but to me it looks a bit janky..but with a vortex generator think it would be an even better candidate to fit in a plastic cutout over the hole and seal it, just gotta make sure it is all sealed properly ^^
HKz is offline   Reply With Quote
Old 04-01-2019, 07:27 PM   #3
Howaitoguru
Well I’m not actually trying to do a delete I just want to get the shark fin matchyy matchyy with the vortex generator. I think a silver shark fin in the center of a black vortex generator might look silly. I just want to change the color of it.
Old 04-01-2019, 07:39 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
You can get a black shark fin. Or you can get the vortex generator paint matched
Old 04-01-2019, 07:40 PM   #5
Howaitoguru
So I can buy a black shark fin and swap out my silver one? How difficult is the install?
Old 04-01-2019, 08:50 PM   #6
DarkPira7e
DarkPira7e's Avatar
Pretty sure you need to pull down your rear headliner to access the bolt that's holding it on. Reinstallation is just using the 3m tape provided, as the aftermarket fin isn't bolt-on.
Old 04-01-2019, 08:56 PM   #7
Howaitoguru
That sucks honestly. You’d think they’d just sell a cover that goes right over it. Or even have the vortex generators cover up the antenna that way it’s a solid color all the way through. But they have the silly cut out.
Old 04-12-2019, 03:08 PM   #8
MotoX16
MotoX16's Avatar
Drives: 2017 Subaru BRZ
The TS came with a black shark fin, you could buy that part or find a wrecked black brz and pull the fin off.
Cheapest option would probably be wrapping it...or rattle can
MotoX16 is offline   Reply With Quote
Old 04-12-2019, 10:41 PM   #9
norcalpb
norcalpb's Avatar
The oem shark fins come pre-painted. If you overtighten the bolt you will dent your aluminum roof.
Edit: they are $120, but also that vortex generator is most likely adding drag to your setup. You could consider selling that and keep your current shark fin.
Old 04-13-2019, 02:33 AM   #10
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Your best option would be to paint the vortex generator silver. A paint shop can do that easily. Check an example here on a blue WRX:
I would say that it looks like factory.
Old 04-13-2019, 07:04 AM   #11
Howaitoguru
Drag like weight? And it’s not going to matter when I boost it.
Old 04-13-2019, 03:08 PM   #12
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
No, not weight. Drag in terms of aerodynamics.
kevaughan is offline   Reply With Quote
Old 04-13-2019, 05:24 PM   #13
soundman98
ProCrastinationConsultant
soundman98's Avatar
speed factory also sells a vortex generator that's already painted
nikitopo (04-13-2019)
Old 04-13-2019, 06:15 PM   #14
Howaitoguru
Yeah I know that but I wanted to offset the color and do a black one and change the fin black but it seems like all the options are complicated.
Oem WRB Shark fin Falken86 Want-To-Buy Requests 1 05-17-2017 06:25 PM
TRD Shark Fin Still Available? Bonburner Cosmetic Modification (Interior/Exterior/Lighting) 6 04-16-2015 10:55 AM
Shark fin Antennas Ryan86 AFRICA 9 04-03-2013 10:32 AM
BeatSonic vs VG Shark Fin? JohnAyySays Cosmetic Modification (Interior/Exterior/Lighting) 27 03-12-2013 01:59 PM
Antanna Shark Fin?? scionfr_s Cosmetic Modification (Interior/Exterior/Lighting) 1 02-20-2013 11:29 PM
