Old 03-26-2019, 08:32 AM   #1
Seiryuu
Drives: ZC6
So 2017+ models CAN use GL-5 fluids in the tranny...
I want to change my transmission fluid so I started to do my homework on this and went through countless transmission fluid threads of recommendations and people warning against using GL-5... but they were all pre-2017.
An AMSOIL rep (through a clerk at an auto store) insisted that the AMSOIL 75W90 Severe Gear GL-5 will work for my BRZ and will not let me special order their regular manual transmission fluid.
I was going through my owner's manual and this was stated under Manual Transmission, "Other gear oil that meets APL GL-3, GL-4, or GL-5 and SAE 75W-90 specifications."
So... I guess Subaru updated the '17+ transmission to allow for GL-5 usage now?
Seiryuu is offline   Reply With Quote
Old 03-26-2019, 09:28 AM   #2
StraightOuttaCanadaEh
Wes
I guess? Been using it in mine for a while now
Instagram: @gt86ws
Old 03-26-2019, 01:27 PM   #3
Interesting. Seems kinda sketch. The transmission hasn't changed at all.
Not arguing with the manual but I'd stick with GL-4.
Old 03-26-2019, 01:55 PM   #4
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Personally, I'd go by what the book recommends (look in your manual). Not sure if there is an update, but definitely haven't read about one.
Also, I wouldn't trust the clerk at an auto parts store.
The Following User Says Thank You to Summerwolf For This Useful Post:
wparsons (03-29-2019)
Old 03-26-2019, 08:52 PM   #5
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Kind of like when manufacturers change nothing in a transmission, but yet suddenly one year it's now "filled for life"..
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following User Says Thank You to venturaII For This Useful Post:
Spuds (03-28-2019)
Old 03-27-2019, 09:39 PM   #6
chipmunk
Drives: _
Subaru only has GL-5 now as their OEM manual transmission fluid.
I emailed Subaru of America several times to confirm that it's OK to use Subaru OEM oil that states GL-5.
Is there a chance that the customer support guy didn't know what he was talking about? Possible! But when in doubt, Red Line is always there for you!
Sent from a potato
chipmunk is offline   Reply With Quote
Old 03-28-2019, 03:44 AM   #7
JIM THEO
Drives: BRZ 2018
Last generation GL5 transmission fluids have additives that protect yellow parts of the gearbox thus even when manufacturers say only GL4 a GL5 oil can be used, for example Gear 300 IS GL5 but protects yellow gearbox parts that ask for <GL4
JIM THEO is offline   Reply With Quote
Old 03-28-2019, 01:52 PM   #8
venturaII
venturaII's Avatar
This article has been cited in the past plenty of times, but is still an excellent explanation of why GL5 ratings are NOT compatible for transmissions using brass syncronizers...nor are they meant to be. Written by a knowledgeable regular over at BITOG, in this case for the Corvair community. Brass is still brass though, regardless of it being in a '65 Corvair or a '15 Toyota...
https://www.widman.biz/uploads/Transaxle_oil.pdf
Spuds (03-28-2019)
Old 03-28-2019, 03:19 PM   #9
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
So what that tells me is Subaru decided it was cheaper to only keep GL5 around, so they re-specified the transmission to take GL5 for supply chain purposes. I doubt the transmission was actually changed in any way.
The Following User Says Thank You to Spuds For This Useful Post:
venturaII (03-28-2019)
Old 03-28-2019, 03:25 PM   #10
chipmunk
Drives: _
Not sure about that... but for my next change, I'm thinking of going with GL4... and might even add some ZDDP additive.
Sent from a potato
2017+ STi Short Shifter (US Spec) fits all models 2013+ HeresMyMind Engine, Exhaust, Transmission 2 02-05-2019 02:16 PM
Autocross with models 2017+ IAM (ignition advance at 0.7) nico_rsx Tracking / Autocross / HPDE / Drifting 22 08-24-2018 10:36 AM
FI for 2017 models? gtengr Forced Induction 24 12-07-2016 11:08 AM
STI JDM tranny mount vs Perrin tranny support NVH khrono Engine, Exhaust, Transmission 2 03-15-2016 08:43 PM
Motul fluids Filipino Royale Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 88 04-20-2014 09:36 PM
