Old 03-22-2019, 07:35 PM   #435
Gunman
Drives: 2019 Mazda Miata RF
Originally Posted by Open Loop View Post
How difficult is it to get to these screens?
Pull engine, remove valve cover, they are in the cam carrier. Technically they are OCV screens. Page EM-31 in the service manual.
https://www.slideshare.net/kokkat/20...service-manual
Old 03-22-2019, 07:59 PM   #436
maslin
Benz Tech
Drives: 2017 BRZ Premium
Jiffy Lube will clean them for $19.99
Seriously though. If there's loose sealant in the engine there is no reasonable way to get it out. The easy way would be not to drop sealant in the engine in the first place.
maslin is offline   Reply With Quote
Old 03-22-2019, 08:18 PM   #437
Gunman
Yep, and avoiding that is tough, when you are removing something the size of the front timing cover, which exposes the oil pan, and various other passages, with old sealant able to flake where ever.
Old 03-22-2019, 08:40 PM   #438
If I was remotely thinking about having a dealer perform this recall, I would pay for an extra day's labor of an experienced tech and personally ask her to:
1. Remove both of the valve covers at the same time.
2. Remove the pan and pickup tube.
3. Just before doing the covers, tape off the galleries and blow it all out with air blah blah blah...
The only thing affected by clogged AVCS filters is AVCS.
Old 03-22-2019, 09:26 PM   #439
Bubba suggests to rotate the engine on its end before completely removing the cover. Then bang on the engine with a BF rubber hammer, then take off the cover, then use a shop shop vac and suck up any hanging chads of old sealant. Then, with a shop vac hose in one hand and a tool in the other, carefully remove all the old sealant.
humfrz for Bubba
Old 03-22-2019, 09:27 PM   #440
Old 03-22-2019, 10:38 PM   #441
maslin
Benz Tech
I do this every day. Avoiding that isn’t tough at all. It’s rubber glue that is stuck to everything, it doesn’t flake anywhere. You have to physically remove it with chemicals and a scraper.
A wink wink plastic razor blade works best, but can damage the aluminum parts. Actual plastic razor blades work, but they take much longer.
It’s one of those things. Its easy to do it right, it’s even easier to do it wrong.
Old 03-22-2019, 10:38 PM   #442
Old 03-22-2019, 10:41 PM   #443
Bubba suggests...
Equally legit. Part of mine is an excuse to inspect the screen regardless.
Old 03-22-2019, 10:46 PM   #444
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Just have the synthesizer make you a new car
Old 03-22-2019, 10:58 PM   #445
I've modified the tricorder to emit an inverse paraphasic field using stone knives and bear skins.
Old 03-22-2019, 10:59 PM   #446
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
I made solar stills out of a bunch of red uniforms from dead officers to make water, so there
Sent from my PH-1 using Tapatalk
ybotspawn is offline   Reply With Quote
Old 03-22-2019, 11:02 PM   #447
#winning
Old 03-23-2019, 10:52 AM   #448
Gunman
Interesting. Even after 80k miles, in my case, it remains pliable? I know they found one very small piece of debris caught in a screen in my engine. Timing cover was removed once, with the engine in the car, post recall service, and with the added difficulty of getting to the sealing surface, I attributed the debris to that removal/cleaning. I have nothing to substantiate it, just seemed logical.
Regardless, removing that timing cover does expose the oil system to FOD.
brz, failure, frs, i cant even, j02, recall, so much glue
Registry Thread: Failure After J02 Recall DarkPira7e Issues | Warranty | Recalls / TSB 489 05-26-2023 02:46 PM
Is the fad threads ruining our fad threads? Andrew025 Off-Topic Lounge [WARNING: NO POLITICS] 12 10-04-2017 09:12 PM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 05:18 PM
BRZ or FRS (yes, another one of those threads) lisaaaxo FR-S / BRZ vs.... 19 04-11-2015 02:44 PM
Vs. threads.... TwinscrollGT35R FR-S / BRZ vs.... 34 05-22-2012 08:21 PM
