Old 07-16-2016, 02:10 PM   #113
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Originally Posted by tommyhp2 View Post
Hope I didn't wake any zombies but... is the built engine still for sale?
link is bad, they now offer multiples
Stage 1 http://fullblownmotorsports.com/full...-1-short-block
Stage 2 http://fullblownmotorsports.com/full...-2-short-block
Stage 3 http://fullblownmotorsports.com/full...ort-block-1414
Old 08-06-2016, 02:02 AM   #114
Dipstik-sportech
Dipstik-sportech's Avatar
Takes abuse is right. Mine is still going strong and it's the first one they ever built so that says something.
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
GhostOp86 (11-26-2016)
Old 08-06-2016, 09:49 AM   #115
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
What exactly is coated in the stage 1 block? Piston skirt? Piston Top? bearings?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 03-22-2019, 05:11 PM   #116
Nawar
Drives: 2016 Red GT86
Do i need a new ECU (ie Motec) when getting a Short Block for my 86?
Nawar is offline   Reply With Quote
Old 03-22-2019, 07:29 PM   #117
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
No, you will need turning however if you are changing piston size or compression ratio outside of the stock specs.
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 02:05 AM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Performance! Pure Automotive Forced Induction 181 03-12-2013 02:11 PM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Pure Automotive Mid-Atlantic 22 02-12-2013 10:13 AM
Initial Review + First Dyno Run for my Full Blown Turbo FRS on Friday, Feb 1 @ 3pm TyperRspec789 Mid-Atlantic 66 02-02-2013 02:25 PM
