Old 03-21-2019, 04:07 PM   #1
FT86.ca
Drives: '15 BRZ, '05 Acura TL
Tube blocked off on top of manifold?
Hi All,
I noticed that my automatic 2015 BRZ does not have a tube connected to the manifold next to the tube that connects to the PCV valve.
What is this tube (drivers side) for? Mishimoto catch can install says that's the brake booster tube but I don't think so. Radium video says that the crankcase vent. I think this is correct.
If there's no tube because mine is an automatic, why don't I have a crankcase vent? The port is just blocked off straight from the factory. Last time I checked, I do have a crankcase.
Vic
PS. Google search was no help. I couldn't find a single photo of this area with the port blocked off like it is on my car. 1st owner so I know it came like this from the factory.
FT86.ca is offline   Reply With Quote
Old 03-21-2019, 04:27 PM   #2
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
There's already an EXACT post about this.
Dr. BRZ is offline   Reply With Quote
Old 03-21-2019, 04:47 PM   #3
FT86.ca
I've been trying to find this info using search here for the past hour.
"blocked port, tube next to pvc port, plugged port, mystery port, plugged connector on top of manifold etc..... NOTHING"
Kindly point me in right direction.
Old 03-21-2019, 06:31 PM   #4
Lantanafrs2
Drives: 2013 frs red
I believe that's plugged from the factory. Probably another vacuum port for diagnostics
Lantanafrs2 is offline   Reply With Quote
Old 03-22-2019, 02:07 AM   #5
86TOYO2k17
Drives: 2017 toyota 86
Manual uses that for brake booster. Auto uses something else so it does not need/use it.
Old 03-22-2019, 02:47 AM   #6
86MLR
86MLR's Avatar
Because auto doesn't go fast enough for boosted brakes?
Old 03-22-2019, 07:37 AM   #7
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Is that sarcasm? Hard to tell just from reading.
Old 03-22-2019, 07:37 AM   #8
Captain Snooze
Drives: Red Herring
That is sarcasm.
Old 03-22-2019, 08:19 AM   #9
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
That is sarcasm.
This is not sarcasm.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 03-22-2019, 08:52 AM   #10
Auto uses a separate pump.
FT86.ca (03-22-2019), RedReplicant (05-10-2022)
Old 05-10-2022, 01:55 PM   #11
Arcadien Angel
I may be an idiot
Arcadien Angel's Avatar
Drives: Winona - White 2014 Scion FR-S
Why? Is there a reason for this? I've been looking for days and can't find a definitive answer. The AT and MT version both have the same Brake Booster part number, but one gets vacuum from the intake Manifold (MT), and the other gets vacuum from the Cam-driven Vacuum Pump on the rear, passenger side of the engine (Where the leaky cam plate is on the MT version). But why?
What's stopping me from just using the plugged port on the intake manifold for brake booster vacuum? If nothing, then why have the pump at all?
Winona, My Wingless Angel
Edelbrock SC w/ Flex Fuel - 18x9.5 Titan 7 wheels w/ 265/35x18 Michelin PS4S - Radium Dual Catch Cans - Verus Aero - OEM Brembos - Prototype HVT 6100e Dynamic Dampening Coilovers - JDL 4-2-1 EL / OP / Dual Catted FP w/ Greddy SP Supreme Catback
Arcadien Angel is offline   Reply With Quote
The Following User Says Thank You to Arcadien Angel For This Useful Post:
Tcoat (05-10-2022)
Old 05-10-2022, 02:29 PM   #12
No idea. If the engineers that designed the engine felt that was a good reason for the two different systems I have to believe them. Each little difference adds cost and they don't add cost unless they have to.
Old 05-10-2022, 02:44 PM   #13
Lantanafrs2
Might be for reading vacuum?
Old 05-10-2022, 04:04 PM   #14
KillerBMotorsport
KillerBMotorsport's Avatar
I've never looked at the PCV diagram for a CVT, but I would bet $1 it's because an auto does not pull nearly as much manifold vacuum when you let off the throttle. So an external vacuum source is required.
If you transition from throttle to brake in a manual, you get a lot of manifold vacuum. In an auto, you take your foot of the throttle it upshifts (and some CVTs go to idle) and you have little-to-no vacuum.
KillerBMotorsport is offline   Reply With Quote
The Following 3 Users Say Thank You to KillerBMotorsport For This Useful Post:
Ohio Enthusiast (05-10-2022), RedReplicant (05-10-2022), soundman98 (05-10-2022)
Plastic Vacuum Tube for Perrin Inlet Tube sebastiansim Engine, Exhaust, Transmission 5 05-04-2018 08:29 PM
2013 intake manifold vs 2017 Aluminium intake manifold Bobster Engine, Exhaust, Transmission 29 12-19-2016 10:40 AM
wtb: sound tube delete inlet tube Jimmy817 Engine, Exhaust, Bolt-Ons 1 12-21-2014 09:15 AM
'Induction Roar Manifold Tube' White64Goat BRZ First-Gen (2012+) — General Topics 1 04-28-2013 06:51 PM
