Old 03-04-2019, 01:06 AM   #29
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
...continued
Intake back on and A/C Delete installed
RSYO4805 by Rice Classic, on Flickr
55mm Restrictor plate (because rules)
IMG_0389 by Rice Classic, on Flickr
Jackson Racing Oil cooler
IMG_0390 by Rice Classic, on Flickr
IMG_0391 by Rice Classic, on Flickr
Pulled the header - taking it in tomorrow to have the cat replaced with a straight through collector. The plan is to keep the heat shields in tact too.
IMG_0392 by Rice Classic, on Flickr
SCCA T4 - FRS
The Following 2 Users Say Thank You to rice_classic For This Useful Post:
CSG Mike (03-04-2019), Rampage (03-09-2019)
Old 03-04-2019, 01:16 AM   #30
rice_classic
...the wheels on the car go round and round
ARP studs aren't cheap so I figured I would press them into new hubs/bearings instead of into 85k old ones...
mmmm.. made in Japan.
IMG_0398 by Rice Classic, on Flickr
IMG_0400 by Rice Classic, on Flickr
IMG_0401 by Rice Classic, on Flickr
It was easy to use the old rotor to help with the press - but I needed to clean up the opening so the new hub didn't get wedged in there.
IMG_0404 by Rice Classic, on Flickr
IMG_0405 by Rice Classic, on Flickr
IMG_0406 by Rice Classic, on Flickr
Time to do the rears! Uh oh.. these are NOT made in Japan. That primarily only impacts my OCD.
IMG_0408 by Rice Classic, on Flickr
Removing the old front hubs... They did NOT come out easy.
IMG_0410 by Rice Classic, on Flickr
A couple swings of the hammer were not on target.
IMG_0411 by Rice Classic, on Flickr
Installed with APR brake duct adapters.
IMG_0412 by Rice Classic, on Flickr
I didn't like how my ball joint was exposed so I modified the OEM heat-shield to keep the lower joint protected.
IMG_0415 by Rice Classic, on Flickr
Unfortunately when I did the other side.. I CUT THE HEAT SHIELD ON THE WRONG SIDE OF THE MOUNTING HOLE!!! Anyone have a spare driver side heat shield they want to send me? (please?!)
IMG_0419 by Rice Classic, on Flickr
Time to put in the new pads.. Raybestos ST47 (I'm told these go to "11").
IMG_0417 by Rice Classic, on Flickr
SCCA T4 - FRS
CSG Mike (03-04-2019), Racecomp Engineering (03-12-2019)
Old 03-04-2019, 01:20 AM   #31
rice_classic
But now I'm stuck on brake duct hoses...
So I 'm stuck at the brake ducts..
Apparently the APR Brake hose routing wants the ducts to go where my oil cooler lines are and that just ain't gonna work. I also can't remove the washer bottle either because the rules don't allow it. I don't want to run the ducts under the car either so I'm really out of options here. I'm very interested in running brake ducts but not sure how to make this work!
Passenger side opening.. Just enough room.
IMG_0423 by Rice Classic, on Flickr
Driver side room.. Nowhere near enough room.
IMG_0420 by Rice Classic, on Flickr
IMG_0422 by Rice Classic, on Flickr
Thoughts?
SCCA T4 - FRS
Old 03-04-2019, 02:16 AM   #32
Tristor
Tristor's Avatar
I don't have a good answer on what to do about the brake ducts, but if you send me a PM I'll dig in my garage tomorrow after work and find the heat shields I took off when I put on my AP Sprint kit. I should still have them and I'd be happy to mail them to you if I can find them.
Tristor is offline   Reply With Quote
Old 03-04-2019, 07:54 AM   #33
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Vibrant performance washer bottle. You would have to make it work but it is tiny compared to the stock one. I have one in my turbo stuff somewhere in storage.
http://vibrantperformance.com/catalo...Path=1022_1249
Ptuning also sells a kit. They are designed so that an intercooler will fit in there.
Old 03-04-2019, 08:26 AM   #34
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Thoughts?
Hey nice thread so far! I was in your same position with the brake ducts a few years ago. My solution was to send back the APR kit and buy the Verus brake cooling kit. The Verus kit has a feature that sandwiches the air from the fog light opening, through the fender liner and into the center of the rotor.
Also, I ditched the backing plates. Mine is 95% track car tho. If Tristor doesn't have a backing plate to ship you, I believe I still have mine. But if you decide to go with the Verus kit, you won't need them, as they come with stainless ones.
http://www.ft86club.com/forums/showp...&postcount=164
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
Tristor (03-04-2019)
Old 03-04-2019, 11:59 AM   #35
Tristor
Tristor's Avatar
I have the PTuning one. I believe though SCCA rules don't allow modifying this component at all, so I don't think he can use either of these.
Old 03-04-2019, 01:46 PM   #36
CSG Mike
CSG Mike's Avatar
Are you allowed to cut THROUGH your washer bottle?
You can also go *around* it, although not ideal.
Opie (06-10-2020)
Old 03-04-2019, 05:52 PM   #37
rice_classic
SCCA rules = “If it doesn’t say you CAN, then you CANNOT.”
However I'm going to invoke the Roffle(sp?) Corollary which suggests "If if says you CAN then you bloody well CAN."
SCCA T4 - FRS
Old 03-05-2019, 12:12 PM   #38
rice_classic
IMG_0429 by Rice Classic, on Flickr
XTKJ1668 by Rice Classic, on Flickr
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post:
CSG Mike (03-05-2019)
Old 03-05-2019, 12:13 PM   #39
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I was going to suggest moving the washer bottle but it looks like you have a solution.
Sent from my Moto E (4) Plus using Tapatalk
Old 03-07-2019, 01:07 AM   #40
rice_classic
Damn these rules!
So the good news is that I found a UK shop on Ebay that could get me B14s before the race season started - nobody state side was expecting anything until late April!
The downside is that I didn't plan on the spring seats being incompatible with the springs the rules require me to run.
The Eibach Sport Plus springs required by the rules are designed for OEM type spring seats and not the small diameter seats that come with the b14s. Thankfully the upper perches I bought fit the eibachs perfect.
IMG_0434 by Rice Classic, on Flickr
The Eibach springs on the them:
IMG_0435 by Rice Classic, on Flickr
IMG_0437 by Rice Classic, on Flickr
Looks like I may need custom seats (or are they called perches?) made to mate these springs up to these shocks. Anyone know if an easy-button exists to solve this riddle?
SCCA T4 - FRS
Old 03-11-2019, 08:46 PM   #41
rice_classic
Hack and cut and grind and hope
It was time to bust out the grinding wheel to utilize the OEM perches so I can use the springs the rules dictate.
IMG_0458 by Rice Classic, on Flickr
IMG_0460 by Rice Classic, on Flickr
Just to be clear - I did grind the collar seat on the OEM perch to be both flat and smooth before seating it on the new shocks.
IMG_0464 by Rice Classic, on Flickr
With the Raceseng Cascam items on top:
IMG_0465 by Rice Classic, on Flickr
Finally installed!
IMG_0468 by Rice Classic, on Flickr
SCCA T4 - FRS
Old 03-11-2019, 08:52 PM   #42
rice_classic
Valve spring recall is causing what!?
Since I'm one of the folks who had the valve spring recall done, I'm now crazy paranoid. I've only driven it from the dealer to my house at this point so I don't know if things are gonna go kaboom or not.
With that said - I figured I'd remove the pan and inspect.
Holy Hell! The pan was hard to get off they used SO much sealant from the factory I had to take a metal putty knife and hammer around the seam to break the stuff free as there were no good pry points along the pan. I'm so used to my Hondas which used Oil Pan gaskets instead.
IMG_0451 by Rice Classic, on Flickr
IMG_0452 by Rice Classic, on Flickr
Now, notice how the sealant is gray.. That's the same with the sealant the Toyota dealer used during the valve spring recall work. However when pulled the strainer off - there was sealant stuck in the screen what was black.
IMG_0448 by Rice Classic, on Flickr
IMG_0449 by Rice Classic, on Flickr
IMG_0453 by Rice Classic, on Flickr
Not all that excited about this discovery, but I am glad I found it.
SCCA T4 - FRS
SCCA T4 Race Car Build - Suspension ccdrift Tracking / Autocross / HPDE / Drifting 10 11-11-2018 01:50 PM
Daryl Harr's FR-S SCCA Race Car Build driver71 Member's Car Journals 39 05-28-2016 05:50 PM
VADERR's Tie Fighter (C Street SCCA Build) VADERR Member's Car Journals 49 02-10-2016 01:31 PM
My SCCA National budget RTR build SeanRTR Tracking / Autocross / HPDE / Drifting 69 09-05-2014 01:49 PM
Bad Panda Motorsports - SCCA Solo STX BRZ Build BadPanda Member's Car Journals 7 06-13-2013 02:08 AM
