Old 02-26-2019, 04:00 AM   #15
504
504's Avatar
Drives: 2014 86 GTS
yes they are the three tables to change, zero out everything up to 0.6 load
up to and including 0.6 LOAD? how much can the DI take before hitting duty cycle?
504 is offline   Reply With Quote
Old 02-26-2019, 04:06 AM   #16
tomm.brz
Drives: brz 2017 hksv2
DI provides plenty of fuel.. you need to do a full throttle pull and log DI opening time (ms) and di injection end to spark (ms)
if you are at around 6ms and more than 1.5ms to the spark you are good
you won t max out DI at low loads
Old 03-01-2019, 05:48 PM   #17
504
504's Avatar
Drives: 2014 86 GTS
So reckon it's be safe zeroing all loads less than or equal to 0.6?
I wonder how tip in enrichment works also when there is a more significant DI only load region and having large PI injectors since the tip in is based off a strict time injection rather than quantity
Old 03-02-2019, 02:12 AM   #18
steve99
Drives: FT86
Yes snything based on a injection time for port injectors will need compensation wgen larget i jectors installed
Old 10-06-2020, 09:39 PM   #19
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Any of you guys having startup weirdness or stalling after installing these injectors? I'm thinking there's some information that was missing from DW's install guide.
D-VO is offline   Reply With Quote
tuning frs maf/injector QTR FMS Software Tuning 80 11-01-2018 06:45 AM
Element Tuning FRS/BRZ Hydra EMS Stand-Alone Turbo 400 whp Injector Limited Element Tuning Engine, Exhaust, Transmission 40 12-17-2013 01:12 AM
Injector Seals went Bad while tuning my car whitefrs Forced Induction 128 08-20-2013 12:19 PM
