Old 01-29-2019, 03:24 PM   #43
Calum
That Guy
Drives: 2013 asphalt FRS MT
What's the purpose of making the plate removable aside from initially casting the ports? What would be the ramifications of welding the plates on?
Thanks so much to the guys that are sharing their findings.
Old 01-29-2019, 04:03 PM   #44
It always comes down to $$$. Making the timing cover a weldment would kick it into a whole new category because of the added prep work. The rough casting would have to be machined to prep for the weld. Then, after it was done warping, it could go for final machining.
For the record, I'm not convinced that the gap is a big deal. Same goes for the flat head cap screws. One is and the other is
Calum (01-31-2019)
Old 01-29-2019, 09:50 PM   #45
sam69
Drives: GT 86
Originally Posted by RayRay88 View Post
This may sound stupid, but has anyone tried to tighten down those Phillips head screws with an impact screwdriver? I found it was the best way to tighten/loosen stubborn screws without stripping them.
Doesn't matter how tight you make the screws it is not going to make any difference to the areas that aren't sealing .
Showed the guy who is building my motor and he reckons it would lead to cavitation at high revs as it only takes a small amount of air to help make it happen and we need to fix it .
sam69 is offline   Reply With Quote
Old 02-10-2019, 01:11 PM   #46
ermax
ermax's Avatar
Originally Posted by solidsnake11 View Post
I would not worry so much with the suction side of the pump. The vacuum should pull the plate down tight. I used gasgacinch on mine to seal the plates and oil pump cover. I also machined a new plate for the driver side which is 10mm thick, this is the maximum or it will hit the chain guides. I had no air leaking from the oem passenger side plate. I did get the engine in and started just haven't hooked a oil pressure gauge up, but the oil light goes out before it fires so that's a good sign. Another trick to help prime a new engine is fill the outside hole up with oil, underneath the oil filter in the front cover. This hole leads directly to the oil pump.
Switching the hubs to 114.3 on 5 so its not drivable.
I did this on mine. I also filled the filter up and then I turned it over with the throttle pressed all the way down (which disables fuel so it will not start) for about 10 secs. When I fired it up it sounded nice and smooth. It can be nerve wracking on first crank when it’s all dry for the first few secs and sounds like it wants to come apart. It’s was easy to combat this on this engine.
Old 02-10-2019, 03:01 PM   #47
This is truly impressive.
Old 02-24-2019, 11:11 AM   #48
Trust86
Drives: 2016 Halo FRS
Bump, any update?
Trust86 is offline   Reply With Quote
Old 02-25-2019, 09:39 AM   #49
chipmunk
Drives: _
Cavatation also has a side effect of heating the fluid. Seems Fa20 cooks the oil pretty fast when its pushed hard.
What oil weight were you using that caused cavitation & metal erosion?
chipmunk is offline   Reply With Quote
Old 02-25-2019, 09:46 AM   #50
churchx
churchx's Avatar
Drives: 2014 GT86
cavitation .. wasn't it more of boiling/evaporating of fluids due low pressure that lowers boiling temp of fluid, not rising temps themselves or my memory fails me?
At least IIRC it was that way for boat propellers, especially high speed ones, with water evaporating for fast spinning propeller, thus high pressure gradient on one side of blade ..
Old 02-25-2019, 09:53 AM   #51
ermax
ermax's Avatar
I don't think oil weight is the cause, it's a shit design causing it.
Old 02-25-2019, 02:05 PM   #52
fika84
fika84's Avatar
Thanks for this. I just took my engine apart due to a spun bearing. It's a 2013 BRZ (I was hoping a valve spring broke!). The engine has less than 35k on it, but I've been tracking it and it has an OFT tune and header back.
Is it OK to use the gasgacinch on all of those plates? Subaru put SO MUCH SEALANT everywhere that I would expect they would've put some here too!
Sealant galore
fika84 is offline   Reply With Quote
Old 02-25-2019, 07:23 PM   #53
Trust86
Originally Posted by remhex View Post
On the topic of oil stuff, I just tried a mod to my sandwich plate that helped out. I had a pressure drop after my oil cooler install. The manufacturer assured me the loss was normal and they have way more experience than me. Anyways, I drilled a hole through the sandwich plate. I started small and kept increasing the size of the hole until my redline oil pressure was close to where it was prior to the oil cooler install. I don't know a thing about thermodynamical stuff but the idea was that at all rpm's, some oil could bypass the cooler to increase flow but not enough to reduce cooling significantly. Max temps are 10° hotter but I gained 8psi even with the slightly higher temperatures. I started with a 3/16 hole and ended up with 5/16. Oil lines are an10.
I’m interested in this, you just drilled right through the sandwich plate? Any specific area? Also what oil cooler kit are you running? I’m going to get my feed for turbo from another location and cap off the feed by the a/c compressor, relocate my own oil temp sensor to oil pan and since I’ll have it off, add the killer bee pick up tube. I already have a blue moon lower oil pan baffle.
Old 03-26-2019, 11:24 AM   #54
ermax
ermax's Avatar
Is this thing on the road yet? Any updates on how effective your modifications are?
Old 03-27-2019, 07:51 AM   #55
Calum
That Guy
I always understood it to be that the fast spinning propeller causes sufficient vacuum at the leading edge to cause the cavitation.
Source: 20 years of the Canadian Navy
Old 03-27-2019, 08:00 AM   #56
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I've always thought vacuum cleaners were an oxymoron.
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 07:21 AM
WTB: OEM Mass Air Flow Sensor/Meter Assembly Air Flow Sensor driftking96 Want-To-Buy Requests 0 02-16-2016 04:57 AM
No a/c but system has pressure ZionsWrath Other Vehicles & General Automotive Discussions 8 06-14-2015 03:43 PM
Question: TPMS Tire-pressure monitoring system installed on aftermarket wheels Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-05-2013 01:54 PM
SRT FR-S/BRZ High Flow Intake System R&D Swift Racing Technologies Engine, Exhaust, Transmission 160 03-03-2013 01:41 AM
