Old 02-22-2019, 10:23 AM   #1
kev0
Drives: '14
Empty reservoir. Confused as to what coolant I should use
2014 FRS. I noticed that my coolant reservoir is completely dry and have noticed it being like that for a while. I understand that it is an overflow tank and being low level is good, but It is completely DRY. My temps are normal though, but having that low of a coolant level is concerning.
What fluid should I go with? I’ve done my fair share of research but I’ve been hearing different fluids. I live in Chicago so it can get very cold in winters, so I don’t think using distilled water would be good. I am not sure what kind of coolant the previous owner used, but I’m pretty sure it’s the OEM fluid and have never been changed.
Can someone supply me with the part number for the fluid I should use so I can just purchase if, top off and be done with this?
Also, I’ve noticed that some coolant fluids are a 50/50 mix, while others are a concentrate. Which one should I use?!? This is really frustrating me more than it should..
Thanks
kev0 is offline   Reply With Quote
Old 02-22-2019, 10:25 AM   #2
Vital
Drives: 2015 BRZ
Thanks
Here you go.
https://www.amazon.com/Genuine-Subar.../dp/B007NLOZAU
The Following User Says Thank You to Vital For This Useful Post:
kev0 (02-22-2019)
Old 02-22-2019, 10:28 AM   #3
kev0
Drives: '14
Originally Posted by Vital View Post
Heh, thanks! Do I just pour this into the overflow tank until its between full and low while its been sitting out in the cold for a while?
Sorry for the newbie questions..
Old 02-22-2019, 10:35 AM   #4
Vital
Drives: 2015 BRZ
Yes, doing it while engine is cold is fine. First open the radiator cap and check to see if you can actually see the coolant. Once you open it you should clearly see it at the top if its low fill it to the top. Then you can add some to the overflow i would just fill it a little above the Low marker. Coolant expands when its heated so you don't need too much in the overflow reservoir
kev0 (02-22-2019)
Old 02-22-2019, 10:56 AM   #5
Vital
Drives: 2015 BRZ
@kev0 out of curiosity whats the mileage on your car? I know the manual says to flush the coolant at 100K miles...
Old 02-22-2019, 10:57 AM   #6
kev0
Drives: '14
I’m at 69,000.
The Following User Says Thank You to kev0 For This Useful Post:
Vital (02-22-2019)
Old 02-22-2019, 11:07 AM   #7
tobin
tobin's Avatar
Drives: '13 BRZ
You want Subaru "super coolant." Any dealership will carry it. It's blue.
tobin is offline   Reply With Quote
The Following User Says Thank You to tobin For This Useful Post:
Vital (02-22-2019)
Old 02-22-2019, 11:07 AM   #8
Vital
Drives: 2015 BRZ
I’m at 69,000.
ah ok i think you should be fine with topping it off for now. Also, i forgot to mention if you do end up filling coolant in the radiator leave the cap off and turn on your car and let it get to temperature this will let out all the air it will start to bubble. Once the bubbling goes away you should be set. You can use this video as a guide.
[ame]https://www.youtube.com/watch?v=IxxNg9Z1ldw[/ame]
kev0 (02-22-2019)
Old 02-22-2019, 11:22 AM   #9
kev0
Drives: '14
Oh, I didn't know that. Thanks a lot for your help
Vital (02-22-2019)
Old 02-22-2019, 11:31 AM   #10
Vital
Drives: 2015 BRZ
Sure, no problem. It might not bubble since you're just topping it off, but just in case.
OMG coolant reservoir bone dry! qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 10-29-2017 10:35 AM
*SOLD* Cusco Coolant Breather Tank Water Reservoir Air Remover Bubble hirollaz Engine, Exhaust, Bolt-Ons 10 04-25-2016 12:33 AM
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 09:21 PM
Brake fluid reservoir empty cab33 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 07-16-2015 10:04 PM
Black Flakes in Coolant Reservoir?? John Rambo Issues | Warranty | Recalls / TSB 7 07-15-2015 06:58 PM
