Old 07-11-2015, 10:23 AM   #1
cab33
Drives: Fast
Brake fluid reservoir empty
Is there a trick to getting the brake fluid out of the reservoir?
A turkey baster just reaches the top 20%.
cab33 is offline   Reply With Quote
Old 07-12-2015, 12:02 PM   #2
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Your best bet it to slowly pour the new fluid in the reservoir, the new fluid should float on top of the old fluid, so when you do bleed the brakes you'll get 99% of the old fluid out.
If you do it every year with quality brake fluid, you'll be fine.
The Following 2 Users Say Thank You to dem00n For This Useful Post:
cab33 (07-12-2015), CSG Mike (07-12-2015)
Old 07-12-2015, 07:32 PM   #3
pantdino
Drives: Firestorm 2013 FR-S
I have never heard that new fluid floats on old fluid.
If they are the same chemical, why should it?
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 07-12-2015, 10:28 PM   #4
dem00n
dem00n's Avatar
Drives: Scion FRS
I've wondered the same thing as well.
Brake fluid is hydrophobic, perhaps the older brake fluid which would have a higher content of water, allows newer brake fluid to float on top of it. I'm not stating so much that old brake fluid and new brake fluid always remain separate, but when bleeding brakes, new brake fluid slowly poured on top of the old tends to stay put. It has worked for me.
Also all brake fluid are created without different mixtures, compounds, etc.
I have no idea if this is right, just a guess.
Old 07-12-2015, 10:31 PM   #5
wbradley
Sarcastic SOB
wbradley's Avatar
Once the new fluid in the reservoir is drawn into the lines by bleeding, I don't believe a whole lot of mixing occurs.
Old 07-13-2015, 03:09 AM   #6
Wyattkb
Drives: 2014 Whiteout FRS
I just kept adding new fluid as I flushed the old fluid out. I used a clear vinyl tube and container so I could see as soon as the new fluid started to pump out. The difference between old fluid and new fluid is night and day.
Also don't forget to bleed them in the proper order to ensure you get all the old fluid/air out.
Wyattkb is offline   Reply With Quote
Old 07-13-2015, 08:48 AM   #7
wbradley
Sarcastic SOB
wbradley's Avatar
BTW I believe brake fluid up to DOT 4 is hydrophilic. Glycol based compounds mix with water readily. Don't use DOT 5.
Old 07-16-2015, 07:10 PM   #8
RD1428
RD1428's Avatar
Drives: 2013 Scion FRS
Or what?^
RD1428 is offline   Reply With Quote
Old 07-16-2015, 07:25 PM   #9
swarb
Originally Posted by RD1428 View Post
Or what?^
or you die.
The Following 2 Users Say Thank You to swarb For This Useful Post:
Tcoat (07-16-2015), WHITE (07-16-2015)
Old 07-16-2015, 08:13 PM   #10
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
^^can't argue with that logic.
WHITE is offline   Reply With Quote
Old 07-16-2015, 08:54 PM   #11
wbradley
Sarcastic SOB
wbradley's Avatar
Or what?^
Google it.
Old 07-16-2015, 09:04 PM   #12
stugray
Drives: 2013 GBS BRZ Limited
they USED to sell the ATE BF in gold and blue.
That way you could altrernate colors and bleed until the color changes.
Now they supposedly cant sell the blue in the US anymore because techs were pouring it in the Windshield washer resivoir.
Glad I bought 3 quarts of it while you still could.
FS: OEM Exhaust, Radiator, Intake Tube, Sound Generator, Windshield Fluid Reservoir zeal86 Engine, Exhaust, Bolt-Ons 5 07-25-2015 08:42 PM
smaller washer reservoir for use w/ brake ducts blazinicon Scion FR-S / Toyota 86 GT86 General Forum 1 12-11-2014 07:57 PM
Mold in brake fluid reservoir Maverickgear Issues | Warranty | Recalls / TSB 3 09-15-2014 03:06 PM
Brake reservoir caps color, rit dye anyone?? OICU812 Cosmetic Modification (Interior/Exterior/Lighting) 3 05-13-2013 12:18 AM
