#20498 |
Drives: FRS
#20499 |
The best one (Torque) is android only, but there are apps that work for iOS, although I don't have any experience with them.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#20500 |
#20501 |
The Bluetooth adapters do not work with iOS but the Bluetooth LE adapters do. The problem is the descriptions on these products never tell you if they support BLE or just BT. The adapter I got runs Bluetooth AND Bluetooth LE. So it will work with Torque on Android devices or OBD Fusion on iOS. What is funny is the description for the adapter I got specifically says it will not work on iOS but it actually does.
Here is a link to the exact one I ordered (pulled form my order history): https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 This link should automatically select the "Bluetooth for Android (Enhanced Version)" but if not, be sure to select that option. The OBD Fusion app is $10 and also has an inapp option to adds Toyota specific PIDs for an additional $10. It will read almost everything that Techstream can with that addon. You don't need the addon to simply read a CEL and clear a CEL though. Here is a link to the app: https://itunes.apple.com/us/app/obd-...ign-mpt=uo%3D4 Here is a video I made showing all the channels you can read with the Toyota addon: [ame]https://www.youtube.com/watch?v=31F3ulaxaLU[/ame] |
#20502 | |
Drives: LS Swapped Scion FRS = 440HP
You can pay a small amount to unlock manufacturer specific PIDs (parameters). |
| The Following User Says Thank You to spitsnaugle For This Useful Post: | Dadhawk (02-18-2019) |
#20503 | |
Drives: FRS
The enhanced version? Sent from my iPhone using Tapatalk |
#20504 |
Yes, when you click that link to go to amazon you will notice the listing has several options. The “Enhanced Version” is the one I have which has Bluetooth (for Android) and Bluetooth LE (for iOS). The other option for iOS is to get the WiFi version but that one is annoying because you have to connect it to the adapters WiFi SSID which means disconnecting it from your home WiFi (assuming your at you home while using it). BLE is more convenient to use. |
| The Following User Says Thank You to ermax For This Useful Post: | Tcoat (02-18-2019) |
#20505 |
Drives: red 2014 FR-S
or you can just get one like this.
https://www.amazon.com/OBD2-Scanner-...s=obd2+scanner I have several scanners both handheld and software. This one was my first and gets the job done with no fuss. once you get the code just search for it on the internet to see what the problem is. |
| The Following User Says Thank You to fx1mark For This Useful Post: | humfrz (02-18-2019) |
#20506 | |
Forgot about that app. For the record the adapter I linked to above also works with DashCommand. I also tested it with Carista and that works too. Carista lets you change dealer set options like disabling the annoying seatbelt warning because a wet leaf blew in the window or disable DRLs, change the volume of the keyless entry and stuff like that. |
#20507 | |
We are not trying to read an MRI here - ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | fx1mark (02-18-2019) |
#20508 |
Weight Weenie
Drives: 15 FR-S
Removed the dash. It wasn't horrible. I was expecting worse. I'll be chasing electrical and smaller items for the next while. I'm going to see about removing the Evap core.
![]() Edit: I'm looking at removing the Evap core because I did the AC delete. I'd like to try and finish the job. I looked at it briefly tonight but saw no easy of doing this. I'll do more research. Last edited by new2subaru; 02-19-2019 at 10:11 PM. |
| The Following User Says Thank You to new2subaru For This Useful Post: | Jordanwolf (02-19-2019) |
#20509 | |
Well it’s nearly twice the price with less function. Simple in functions but not necessarily in usage. I’ve had a basic scanner for 15 years but these days I don’t even bother with it and instead just use the BT adapter. Actually I just leave it plugged in most of the time. If I ever want to monitor something I just run the app on my phone while I’m in route and up come a bunch of gauges without even plugging in a cable. I don’t even need to be in the car crouched under the dash with a 6in cable trying to read the screen. |
| The Following 2 Users Say Thank You to ermax For This Useful Post: | humfrz (02-19-2019), new2subaru (02-19-2019) |
#20510 |
Weight Weenie
Drives: 15 FR-S
^I leave mine in all the time too. It came flying out at track once so it's zip tied now.
| Tags |
| :popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
| Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
| If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 10:19 PM |
