Old 02-18-2019, 12:00 PM   #20497
Ashikabi
Ashikabi's Avatar
Originally Posted by sittok View Post
My car check engine light is on. I need to buy a scanner to diagnosis the car problems.
You can get a Bluetooth one for like 15$
The Following User Says Thank You to Ashikabi For This Useful Post:
Tcoat (02-18-2019)
Old 02-18-2019, 12:37 PM   #20498
vladniko86
vladniko86's Avatar
Drives: FRS
Don't those only work with Android?
vladniko86 is offline   Reply With Quote
Old 02-18-2019, 12:53 PM   #20499
The best one (Torque) is android only, but there are apps that work for iOS, although I don't have any experience with them.
Old 02-18-2019, 02:16 PM   #20500
Ashikabi
Ashikabi's Avatar
I'm sure there is an iOS model somewhere
Old 02-18-2019, 02:39 PM   #20501
ermax
ermax's Avatar
The Bluetooth adapters do not work with iOS but the Bluetooth LE adapters do. The problem is the descriptions on these products never tell you if they support BLE or just BT. The adapter I got runs Bluetooth AND Bluetooth LE. So it will work with Torque on Android devices or OBD Fusion on iOS. What is funny is the description for the adapter I got specifically says it will not work on iOS but it actually does.
Here is a link to the exact one I ordered (pulled form my order history):
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
This link should automatically select the "Bluetooth for Android (Enhanced Version)" but if not, be sure to select that option.
The OBD Fusion app is $10 and also has an inapp option to adds Toyota specific PIDs for an additional $10. It will read almost everything that Techstream can with that addon. You don't need the addon to simply read a CEL and clear a CEL though.
Here is a link to the app: https://itunes.apple.com/us/app/obd-...ign-mpt=uo%3D4
Here is a video I made showing all the channels you can read with the Toyota addon:
[ame]https://www.youtube.com/watch?v=31F3ulaxaLU[/ame]
Old 02-18-2019, 03:08 PM   #20502
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
I use DashCommand on my iPhone with a wireless Kiwi OBD adapter. Its a pretty solid combo.
You can pay a small amount to unlock manufacturer specific PIDs (parameters).
spitsnaugle is offline   Reply With Quote
The Following User Says Thank You to spitsnaugle For This Useful Post:
Dadhawk (02-18-2019)
Old 02-18-2019, 05:40 PM   #20503
vladniko86
vladniko86's Avatar
Drives: FRS
The enhanced version?
Old 02-18-2019, 07:25 PM   #20504
ermax
ermax's Avatar
Yes, when you click that link to go to amazon you will notice the listing has several options. The “Enhanced Version” is the one I have which has Bluetooth (for Android) and Bluetooth LE (for iOS). The other option for iOS is to get the WiFi version but that one is annoying because you have to connect it to the adapters WiFi SSID which means disconnecting it from your home WiFi (assuming your at you home while using it). BLE is more convenient to use.
The Following User Says Thank You to ermax For This Useful Post:
Tcoat (02-18-2019)
Old 02-18-2019, 08:46 PM   #20505
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
or you can just get one like this.
https://www.amazon.com/OBD2-Scanner-...s=obd2+scanner
I have several scanners both handheld and software. This one was my first and gets the job done with no fuss. once you get the code just search for it on the internet to see what the problem is.
fx1mark is offline   Reply With Quote
The Following User Says Thank You to fx1mark For This Useful Post:
humfrz (02-18-2019)
Old 02-18-2019, 08:58 PM   #20506
ermax
ermax's Avatar
Forgot about that app. For the record the adapter I linked to above also works with DashCommand. I also tested it with Carista and that works too. Carista lets you change dealer set options like disabling the annoying seatbelt warning because a wet leaf blew in the window or disable DRLs, change the volume of the keyless entry and stuff like that.
Old 02-18-2019, 09:08 PM   #20507
I agree - keep it economical and simple.
We are not trying to read an MRI here -
fx1mark (02-18-2019)
Old 02-19-2019, 09:55 PM   #20508
new2subaru
Weight Weenie
Drives: 15 FR-S
Removed the dash. It wasn't horrible. I was expecting worse. I'll be chasing electrical and smaller items for the next while. I'm going to see about removing the Evap core.
Edit: I'm looking at removing the Evap core because I did the AC delete. I'd like to try and finish the job. I looked at it briefly tonight but saw no easy of doing this. I'll do more research.
The Following User Says Thank You to new2subaru For This Useful Post:
Jordanwolf (02-19-2019)
Old 02-19-2019, 10:12 PM   #20509
ermax
ermax's Avatar
Well it’s nearly twice the price with less function. Simple in functions but not necessarily in usage. I’ve had a basic scanner for 15 years but these days I don’t even bother with it and instead just use the BT adapter. Actually I just leave it plugged in most of the time. If I ever want to monitor something I just run the app on my phone while I’m in route and up come a bunch of gauges without even plugging in a cable. I don’t even need to be in the car crouched under the dash with a 6in cable trying to read the screen.
The Following 2 Users Say Thank You to ermax For This Useful Post:
humfrz (02-19-2019), new2subaru (02-19-2019)
Old 02-19-2019, 10:17 PM   #20510
new2subaru
Weight Weenie
Drives: 15 FR-S
^I leave mine in all the time too. It came flying out at track once so it's zip tied now.
