Old 02-05-2019, 07:35 PM   #127
Beta
Drives: Hot Lava Fr-S
Welp time to find a flooded 86 and start building a K24/K20. Hopefully by the time I'm done building the kit will be avail to purchase.
Beta is offline   Reply With Quote
Old 02-08-2019, 10:05 AM   #128
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Still very early stages, but I wanted to give everyone a glimmer of hope.... we test fitted the first prototype harness for the K24! A couple minor changes, then we will re-fit it, make sure it's good, then it will have the jumper added, then it will go on a car and hopefully fire one up! This is all still a few weeks of work, but I just wanted everyone to know it has made a huge step!
Pure Automotive is offline   Reply With Quote
Old 02-08-2019, 10:06 AM   #129
Pure Automotive
Originally Posted by PolishFrs13 View Post
I looked through your other K swap thread on here, i noticed the DBW TB.. is it the grams honda one ?
Yea, I think that's going to be an easy to obtain option that bolts on to most K and S2k manifolds, so we are going with that style.
Old 02-12-2019, 03:35 PM   #130
Jdmjunkie
Drives: Scion FR-S 10 Series
What do you think is a ballpark estimate of what this will cost turn-key?
Jdmjunkie is offline   Reply With Quote
Old 02-13-2019, 11:50 PM   #131
PolishFrs13
building life
PolishFrs13's Avatar
Drives: Raven Black, 6MT
personally i think it will be a couple of grand.. each build is different, parts, labor(or if you do it all yourself), PnP, etc.. i'd say 10k if you buy used parts, no engine build, etc. most expensive cost will be the PnP harness
PolishFrs13 is offline   Reply With Quote
Old 02-14-2019, 04:29 PM   #132
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Used engine .................................................. .. $1000
Used transmission .............................................. $750
Pure Auto's Motec with harness .......................... $6000
Pure Auto's engine and transmission mounts ......... $450
Pure Auto's headers........................................... $1700
Ballade Sports transmission adapter ..................... $300
Ballade K24 to S2000 FW .................................... $600
S2000 clutch kit ................................................. $750
Driveshaft Shop (aluminum) ................................ $500
Custom Motec tune ............................................. $500
Shifter relocation kit ........................................... $500
Misc bolts, intake, fluids, etc ............................... $1000
Total .................................................. ........... $14,000
Obviously these numbers are estimates based on current prices and really don't include taxes/shipping/condition/etc. I would think $12.5-15k is reasonable after sale of the stock parts. If someone has their stock motor and trans in good condition then maybe they could get $2500 for those. I could be way off. I just figured someone should start something of a list.
Last edited by Irace86.2.0; 02-17-2019 at 11:44 AM. Reason: Added some more prices
Old 02-14-2019, 04:31 PM   #133
Tokay444
Anti stance.
Tokay444's Avatar
Thankfully this too only needs one header, so you can subtract 1.5 $ signs.
Old 02-14-2019, 10:17 PM   #134
Teseo
Drives: frs
Engine $500-2000
Transmission $500-750
Motec with harness $5k+
Engine and transmission mounts $$$
Custom Exhaust/headers $$$
Transmission adapter $350-500
Clutch kit with FW $500+
Custom driveshaft $500-750
Misc bolts, intake, TB, etc $500-1000
These were just numbers I came up with in my head on a guess. Please copy and edit and add to the list. I would think $10-15k. If someone has their stock motor and trans in good condition then maybe $8-13k. I could be way off. I just figured someone should start something of a list.
I heard you can do it with less cash, using stock the K engine factory harness and a transmission adapter to fit the fa20 tranamission
Old 02-14-2019, 11:00 PM   #135
Irace86.2.0
Maybe. Aren’t we talking in the context of a Pure Motor build? It is their thread. This isn’t a B is for Build thread.
Old 02-15-2019, 08:10 AM   #136
Ashikabi
Ashikabi's Avatar
There is no fa20 transmission adapter
Old 02-15-2019, 08:49 PM   #137
Irace86.2.0
What Ashikabi said, and as it was discussed before, an adapter would push the k24 engine further forward than the stock engine position, making the engine sit really far forward and making the Pure engine mounts ineffective, as they wouldn’t line up. The only way around that might be a custom bell housing, but this seems unlikely that anyone would want to produce such a thing. Even still, a remote hydraulic throwout bearing would probably be needed. After that, hopefully everything is worked out so that the input shaft fits into a custom pilot bearing. Also, the Pure header wouldn’t work because the engine would be moved further forward.
None of this seems like money is saved, and most importantly, this scenario would add front end weight.
Old 02-16-2019, 01:34 PM   #138
PuslarBrrrz
Engine $500-2000
It seems that for a street car this swap isn't great value for money as a Motec and harness are needed. Now for a track car you could probably get away with a Hondata ecu since you wouldn't care about the interior functioning and save a few bucks.
PuslarBrrrz is offline   Reply With Quote
Old 02-16-2019, 01:40 PM   #139
Ashikabi
Ashikabi's Avatar
Isn't anyone trying to get the CAN adapter to work?
Might be about to get the Nemesis computer to work too. I don't see why not
Old 02-16-2019, 01:57 PM   #140
PuslarBrrrz
I think someone on the forum has gotten a CANBUS emulator to work for most functions but not fully yet on a 2AR turbo swap.
Pure Auto's Swap Compilation Thread - 2JZ and LSX ! Pure Automotive Engine Swaps 29 01-10-2018 01:20 AM
SwapYour86.Com Pure Automotive 2JZGTE Billet Intake Manifold For 2JZ FT86 Swap Pure Automotive Engine Swap 0 12-01-2017 11:57 AM
SwapYour86.Com Pure 2JZ MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 11:49 AM
SwapYour86.Com Pure LSX MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 11:23 AM
Pure Auto's 2JZ Swap Thread - The DRAGFRS Pure Automotive Engine Swaps 153 06-20-2016 06:33 PM
