Old 01-31-2019, 05:21 PM   #127
steve99
Drives: FT86
Originally Posted by DustinS View Post
Okay bummer. Hopefully soon, thank you for your work.
I was able to program the cluster with techstream on my own. It's quick and easy. Took a few seconds once I found what menu it was under. I'll get a video of where it is at when I can get some time in the car.
and will do! Trying to decide if I buy it before the car goes down, or send you the cluster (for mileage change) while the car is down for the clutch job and just have you ship it back with the cluster.
So you were avle to just install dsh into key stsrt car to test, ie daie dash worked but car would not start with new dash. Then put old dash back and start ok ?.
Did resync with new dash work with techstream and car starts ok, without external techstream access ?
Old 01-31-2019, 06:06 PM   #128
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Yes. I actually set my needles correctly before I had the dash programmed to the car. Took them off so I could make them clear and used the test mode to set the needle position at 1k RPM and set the needle on. Same for speedometer needle.
Old 01-31-2019, 06:08 PM   #129
geraldjust
Drives: MR2, Sliver BRZ
If i ever figure out to decrypt those saved files i can see if i can change it.
FANTASTIC! so with techstream its easy to program the cluster to the BCM. A video would be fantastic to find out how exactly its done.
Its up to you! And were would you want to add the joystick? to the center TC buttons or the keycap?
LOVE the LED change BTW!
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
Old 02-01-2019, 09:28 AM   #130
DustinS
DustinS's Avatar
If there is anything I can do to help let me know. Might be fun to take a look at it see what I can come up with.
Video has been posted, depending on your browser you may need to un-block it.
Center Traction Control Button
The Following 2 Users Say Thank You to DustinS For This Useful Post:
Akuma-ZN6 (02-03-2019), geraldjust (02-05-2019)
Old 02-03-2019, 02:59 AM   #131
geraldjust
Awesome! im glad it can be easily be programmed. Haha sounds good. il print out a middle button then.
The Following User Says Thank You to geraldjust For This Useful Post:
DustinS (02-04-2019)
Old 02-03-2019, 08:15 PM   #132
Akuma-ZN6
Akuma-ZN6's Avatar
Drives: Hot Fire
Thanks DustinS, looks easy enough going to try on my 2017 Cluster
Akuma-ZN6 is offline   Reply With Quote
The Following User Says Thank You to Akuma-ZN6 For This Useful Post:
Old 02-10-2019, 11:09 AM   #133
STI-ish
STI-ish's Avatar
Drives: 13 BRZ Sport Tech Turbo
@DustinS
pardon if I am not understanding this all straight...electronics are not my forte...
with Techstream - does that allow you to adjust the mileage on the cluster as well? Or is this only for 'unlocking' the keyed cars? I have a 2017 cluster from a part out that my husband is installing in my 2013 with push button start.
STI-ish is offline   Reply With Quote
Old 02-10-2019, 11:39 AM   #134
DustinS
DustinS's Avatar
Originally Posted by STI-ish View Post
@DustinS
Just for “unlocking” on key cars. You need to take it to a dealer willing to do it, or wait for geraldjust to start offering his mileage service (if he even plans on it).
The Following User Says Thank You to DustinS For This Useful Post:
STI-ish (02-10-2019)
Old 02-10-2019, 09:34 PM   #135
Akuma-ZN6
Akuma-ZN6's Avatar
Drives: Hot Fire
I can also offer this service if needed. I had done my mileage to swap the 2017.
Old 02-12-2019, 11:06 PM   #136
geraldjust
@DustinS
I offer it as a service! just PM me and i can set it to what you need. And if you want BRZ or GT86.
STI-ish (02-13-2019)
Old 02-12-2019, 11:09 PM   #137
geraldjust
Are you the one that i send the corrected EEPROM file and told ya how to flash it though email?
Old 02-13-2019, 09:30 AM   #138
STI-ish
STI-ish's Avatar
That's awesome....but I'm not sure I'm tech savvy enough to do it tho haha
I don't even know what an EEPROM file is lol
Old 02-13-2019, 09:32 AM   #139
ermax
ermax's Avatar
Just curious, what sort of prices have people been paying for these clusters?
Old 02-13-2019, 12:01 PM   #140
Akuma-ZN6
Akuma-ZN6's Avatar
Drives: Hot Fire
I figured this out by following this thread , thank you for the guide geraldjust.
2017 Limited Gauge Cluster halleffect Electronics | Audio | NAV | Infotainment 26 10-22-2020 07:32 PM
2017 GR edition cluster mod vagthomas Cosmetic Modification (Interior/Exterior/Lighting) 63 06-29-2020 04:41 PM
Help! Is there anyway to change the 2017 cluster start up image? slashlee DIY (Do-It-Yourself) Guides 2 11-17-2018 05:36 PM
2017 Limited Gauge Cluster halleffect Cosmetic Modification (Interior/Exterior/Lighting) 0 01-16-2017 03:55 AM
2017 gauge cluster Drakiv Cosmetic Modification (Interior/Exterior/Lighting) 2 11-14-2016 11:32 PM
