Old 02-11-2019, 01:57 PM   #1
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
2017+ Battery Terminal Sensors And Power Amp Connections
The 2017+ twins don't have any individual vehicle electrical connections made directly to the battery posts. Instead, there are modules clamped to both posts and all vehicle connections are made to these modules.
1. The module on the negative post is the "Battery Current Sensor" and is used to monitor the voltage, current flow, and temperature of the battery. The ECU uses this information to control alternator output (the 12 to 14 volt fluctuation noticed by many).
2. The module on the positive post *appears* to be just a distribution block with a couple of large fuses protecting major circuits.
I want to connect a sub amp in the trunk that requires 4 gauge power cables. I'm going to use a chassis ground in the trunk for the negative side so the amp's current draw will be seen by the Battery Current Sensor.
My question is this: Can I connect the positive 4 gauge cable directly to the battery post clamp bolt thus bypassing the "distribution block"? (Does that block do anything other than serve as a fuse holder?)
There would be a new fuse in the 4 gauge cable about six inches from the battery post.
Thanks!
LimitedSlip is offline   Reply With Quote
Old 02-11-2019, 05:25 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
New to car audio huh?
Yes you can.
Yes it's just like you said, it's a distribution thingy.
The Following User Says Thank You to Mr.ac For This Useful Post:
LimitedSlip (02-11-2019)
Old 02-11-2019, 05:44 PM   #3
LimitedSlip
Yes you can.
Yeah, it was only a little over 40 years ago that I installed my first Craig PowerPlay sytem!
Thanks for confirming my suspicions about "the block".
Old 02-11-2019, 07:11 PM   #4
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
No worries it's pretty much the same tech just in a new wrapper
Old 02-11-2019, 08:44 PM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
hopefully you held on to that system! some audio nuts are paying big money for vintage gear now...
Old 02-11-2019, 11:57 PM   #6
LimitedSlip
I don't have much vintage car stuff unfortunately.
Negative Battery Terminal UNCC_BRZ Electronics | Audio | NAV | Infotainment 2 09-19-2018 11:23 PM
Battery Brace touched Positive Battery terminal, car won't start!! 7m28 Issues | Warranty | Recalls / TSB 21 09-24-2017 01:55 PM
Battery terminal setup fuddbutter Electronics | Audio | NAV | Infotainment 0 01-24-2017 05:27 PM
Lost my battery terminal nut. qqzj BRZ First-Gen (2012+) — General Topics 3 08-05-2014 08:51 AM
Battery Terminal for Amp Install rbizzle004 Electronics | Audio | NAV | Infotainment 3 06-05-2013 01:46 AM
