Old 02-10-2019, 01:43 PM   #1
omadab
Drives: n/a
DIY climate control and push to start
Hello people,
I am looking to buy a 2015 BRZ with no features on it. I really want this car because the color, mileage and price are perfect. Here is a picture of the interior:
https://tdrpmimages.azureedge.net/ph...e.jpg-1024x786
The problem is I really wanted climate control, heated seats and push to start. The heated seats I know I can DIY myself ez pz
However the climate control and push to start is a different story. So, does anyone know if these projects are relatively simple, or is it way too much work?
Thanks
oma
omadab is offline   Reply With Quote
Old 02-10-2019, 10:42 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
i was told in '14 that adding seat heaters aftermarket can potentially mess with the passenger airbag sensor switch, that is located in the seat pad.
the climate control involves gutting the entire dash to install the full suite of motors and wiring.
you're much better off looking for another car.
Old 02-11-2019, 11:28 AM   #3
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Climate Control is possible but very difficult and can be expensive (some of the pins/wires for the connectors needed are $15 a piece and you need a lot of them) if you are not able to find them from other places/other cars.
Factory Push start is not an option for retro fit. Complete wiring harness is different as well as extra sensors and I do think an extra security ecu.
They do sell aftermarket push to start though. Works pretty well. Ft86speedfactory sells it.
Old 02-11-2019, 11:55 AM   #4
omadab
Drives: n/a
Where did you read this? on the forum? Heated seats are the most important thing to me lol. I can do without all except the seats haha
Old 02-11-2019, 07:47 PM   #5
soundman98
soundman98's Avatar
i don't really remember anymore. i want to say it was a salesman first, and then some research later found similar statements.
i went with a brz limited because i wanted the heated seats anyways, and the minor price bump wasn't enough to justify the possible hassle.
Old 02-11-2019, 09:21 PM   #6
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Way too much work. You are better off paying a bit more for a model that already has them.
It's in par with doing an auto to manual conversion.
Old 02-12-2019, 12:44 PM   #7
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
You're going to hate this car.
You want comfort and I can guarantee if the rattles and noise don't drive you nuts, the harsh ride will.
guybo is offline   Reply With Quote
Old 02-12-2019, 05:33 PM   #8
soundman98
soundman98's Avatar
the only thing that's ever rattled on my car was the rear deck and the dome light switch. the rear deck was fixed with some sound dampening, the dome light was fixed with some felt...
Old 02-28-2019, 03:51 PM   #9
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by omadab View Post
Hello people,
Thanks
oma
Soundman is right, the passenger airbag detection is a circuit that involves detecting the resistance of whatever or whoever is in the seat, that's why if the seat gets moist it sets it off as it calculates the seat weight from the resistance. This also means EMF from certain tablets or phones can trigger it as well, my oneplus 5 used to trigger it with it's aluminum body and my 6t does with NFC on sometimes. Adding an aftermarket seat heater element will most definitely interfere with it.
Climate control is also quite complex you'd need the Climate Control Unit
Temp Sensors, Different piping assembly, Front Button/Dash Assembly
,Appropriate Wiring harnesses and the cost goes well past $2k just to get it to work in automated fashion.
If you had done your research, you would've realized you should honestly should just save up for a higher trim BR-Z
Old 02-28-2019, 06:28 PM   #10
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
It may be less expensive to buy the car with the features you want on it and then paint it?
Old 10-16-2019, 06:53 PM   #11
mrhayes1
Drives: 2013 Scion FRS white
Not to sound like a troll but buying this car and trying to add heated seats, dual climate and push start after the fact sounds like the dumbest idea ever. I don't think you are realizing how much work this would be and I would strongly recommend not doing this. Unless you are getting a base model for thousands less and saving a ton of money, its not worth it. Just pay the $ and buy the better model with those features.
mrhayes1 is offline   Reply With Quote
FS: STI engine start push start OEM plug and play sokol Interior Parts (Incl. Lighting) 5 06-13-2019 02:12 PM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
F/S: BNIB Homelink mirror, Digital HVAC control panel, Push Button Start Opie Interior Parts (Incl. Lighting) 11 05-28-2013 11:53 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
