Old 02-07-2019, 10:54 AM   #1
Pat
Pat's Avatar
Drives: 2023 BRZ
Does the ACT Streetlight kit need a Verus clutch fork?
I'm considering replacing my OEM components with the ACT Streetlight clutch and flywheel (SB8-XTSS). My mechanic says he has not seen the OEM clutch fork fail with the Streetlight kit and said the Verus fork was unnecessary. Does anyone here have experience telling them otherwise? I was leaning towards getting it for piece of mind, but also don't want to spend money unnecessarily.
Thanks,
Pat
Old 02-07-2019, 12:02 PM   #2
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
No it does not but your oem clutch fork will go out over time. Best to buy it now since you're going to take it apart, get it done in 1 job. It holds 1000hp. Especially good if your race the car or push it every once in a while so REPLACE IT.
Dr. BRZ is offline   Reply With Quote
Old 02-07-2019, 12:02 PM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Once the transmission is out, I don't see why not upgrade it. Might as well for peace of mind. It's not excessively expensive and can potentially save a lot of headaches.
Old 02-07-2019, 12:05 PM   #4
Sportsguy83
Drives: Limited BRZ
It's really not rated by HP or even clutch torque capacity. It's rated for 1000 lbs of pressure plate clamping force.
The Following 4 Users Say Thank You to Sportsguy83 For This Useful Post:
CSG Mike (02-07-2019), Pat (02-07-2019), Turbo (02-07-2019), wparsons (02-08-2019)
Old 02-07-2019, 12:07 PM   #5
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Yes, it does. Mine needed it. Silly not to put it in at same time.
Old 02-07-2019, 12:08 PM   #6
Dr. BRZ
Dr. BRZ's Avatar
That's what i meant lol
The Following User Says Thank You to Dr. BRZ For This Useful Post:
Sportsguy83 (02-07-2019)
Old 02-07-2019, 12:19 PM   #7
Pat
Pat's Avatar
Drives: 2023 BRZ
What do you mean, "Mine needed it"? Was your fork bent with OEM components? How did it need it?
TIA
Old 02-07-2019, 12:26 PM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
TIA
Stock would flex and be impossible to drive at times. Had to drop the tranny AGAIN to put the better fork on. Solved a lot of the engagement problems.
Then a couple months later, I got rid of the ACT all together because it sucked.
dhuang (02-08-2019), wparsons (02-08-2019)
Old 02-07-2019, 12:38 PM   #9
Turbo
Drives: FR-S Turbo
Can you please quantify how "it sucked" with a bit of detail ?
Curious because I've heard favourable reports from someone who tracks their car pretty hard running the ACT SB8-XTSS clutch/lightweight flywheel combo.
I'm going to do a clutch/lightweight flywheel swap when my engine is out for the recall, and am deciding on what direction to go. I've also considered the ACT 6-puck versions w/lightweight flywheels, but I'm unsure how the 6-puck versions compare to the full-face discs driveability and performance wise.
Turbo is offline   Reply With Quote
Old 02-07-2019, 12:42 PM   #10
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Originally Posted by Turbo View Post
Can you quantify how "it sucked".
I've also considered the 6-puck versions of their clutch with the lightweight flywheels.
The shudder with the flywheel was nasty, and had hang up problems constantly. I drive my car on the street. For a dedicated track car might be ok. Not for street.
Edit: Just went thru my paperwork and I had the SB7-XTSS kit, I now run the South Bend Stage 2 Daily with stock flywheel.
For more detail, sometimes I would come to a light, have my foot to the floor and still be creeping forward. Other times I would go to take off and start releasing the clutch and nothing, nothing, nothing, then bam, like you dropped the clutch. The shop I used sent it back to ACT for testing, and they came back and said everything was in spec.
Old 02-07-2019, 01:15 PM   #11
Turbo
Drives: FR-S Turbo
ok, thanks.
What clutch fork, pivot & release bearing were you running at that time? Did you try making any adjustments to it?
Old 02-07-2019, 01:21 PM   #12
Sapphireho
Famous Potatoes
Sapphireho's Avatar
ok, thanks.
The velox fork and pivot. I assume the bearing was a pre-dot version, since they were not out yet at the time. I still have the clutch kit with only about 5k miles on it. I figure I might try it again someday with an updated TOB. I did like how stiff it was; WAY stiffer than stock.
Old 02-07-2019, 02:10 PM   #13
Pat
Pat's Avatar
Drives: 2023 BRZ
This is all new to me, and I'm trying to learn about how it all works. How could you tell the OEM fork was flexing? It seems unlikely to me one would be able to tell if a fork is flexing simply from driving the car.
Old 02-07-2019, 03:27 PM   #14
CSG Mike
CSG Mike's Avatar
It does not. Just make sure the pivot is in good shape.
Icecreamtruk (02-07-2019), Pat (02-07-2019)
Verus Engineering Billet Clutch Fork and Pivot Drakiv Engine, Exhaust, Transmission 218 07-13-2023 08:45 AM
[NorCal] FS: ACT SB7-HDSS, Verus Engineering Clutch Fork & Pivot akahenry Transmission and Driveline 8 07-10-2020 03:15 PM
[SOLD!] FS: NEW Diftech Heavy Duty Clutch Fork + Versus Clutch Fork Pivot reeves Transmission and Driveline 2 08-25-2018 12:18 AM
FS: Velox Verus Engineering Billet Shift Fork continuecrushing Transmission and Driveline 1 02-09-2018 07:03 PM
Ordered my ACT streetlight clutch kit! Anyone have this? NickFRS Engine, Exhaust, Transmission 17 06-17-2013 06:05 PM
