Old 02-05-2019, 01:05 PM   #1
NV89
NV89's Avatar
Drives: 14 BRZ, Genesis coupe track, 05 sti
Transmisión leaking and 4th gear not doing well
Hello fellow members,
What would I need to swap a cd009 to our platform?
Sent from my Pixel 3 using Tapatalk
NV89 is offline   Reply With Quote
Old 02-05-2019, 02:03 PM   #2
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I'm not really sure. These are the things that need to at least be sorted out:
CD009
Custom Transmission Mounts
Custom Adapter
Custom Driveshaft
Hammering
Shifter Position
TOB
Shift Fork Position
I don't know about the input shaft. Would it need to be machined? What type of clutch would work? Would a 370z pressure plate be needed to work with the input shaft, but a regular flywheel be needed for the 86's engine? Will the pilot bearing work or a new one found with a different inner diameter but the same outer diameter? Would a shift fork from the CD009 line up with the stock position for the clutch cylinder? Will the shifter line up with the stock location?
I haven't seen too many transmission swap threads, but if someone could sort out these issues then I'm sure there would be interest. I will be either rebuilding my transmission or rebuilding a donor, lightly-used transmission or considering a swap. I want a 6 speed and something that can reliably handle power upgrades up to around 500whp. I was thinking the CD009 or the S2000 transmission, but the CD009 would be the stronger choice, as I understand it.
Old 02-05-2019, 02:53 PM   #3
NV89
NV89's Avatar
CD009
Custom Adapter
Custom Driveshaft
Hammering
Shifter Position
TOB
Shift Fork Position
I'm in the same
Old 02-06-2019, 08:52 PM   #4
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
I just saw a post on instagram that FBM released a kit for the BRZ/FRS. This link isn't it but it's something to look at and an idea on price. They didn't say how much yet that I know of, but I bet if you give em a call and ask they will give you some info.
http://fullblownmotorsports.com/full...ion-conversion
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 02-06-2019, 09:07 PM   #5
NV89
NV89's Avatar
I'm going to call them tomorrow. If they have a kit for the 86 I'll be buying one ASAP. Hopefully I can magically use my current carbon driveshaft
Old 02-07-2019, 01:08 PM   #6
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
There's a kit out there for it...
https://www.mazworx.com/mazworx-favq...t-frs/brz.aspx
Old 02-07-2019, 01:09 PM   #7
Sportsguy83
Drives: Limited BRZ
Unfortunately, no magic will help on that
Partial Part Out, Engine, Turbo Kit with 3" exhaust, Driveshaft, Transmision Sportsguy83 Engine, Exhaust, Bolt-Ons 8 02-16-2017 06:25 PM
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl jakebrz Issues | Warranty | Recalls / TSB 14 06-06-2016 07:28 PM
Transmision Problems Question kombatlion Engine, Exhaust, Transmission 4 05-14-2014 12:59 PM
Oil leaking.. Senzai Issues | Warranty | Recalls / TSB 3 10-02-2013 01:02 AM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 05:43 PM
