| Engine Swaps Discussion of engine swaps. |
Drives: 2015 FRS - FFR GTM
Depinning ECM Plugs
I'm in the process of trying to remove the wires that run from the AC1 plug in the engine bay (runs FA20 motor ) to the PCM. I'd like to just de-pin them from the PCM and clip the wires on either side of the firewall.
OK,,, I watched a couple of YouTube videos,,, looked at the plugs Colin sent so I think I understand how to de-pin the PCM plugs. Executing it is another matter. I've totally screwed up two already. I lift the 'gate' on the top of the plug. It doesn't move much though. Then insert a pick and do a top down kind of motion while pulling on the wire. No good. What's the trick??? How far in should the pick go??? HELP!
2015 FR-S - One Day I'll Finish The Swap |
#2 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Usually, a de-pinning tool is a cylinder that fits around the pin snugly and depresses the lock tab.
Then you can pull the pin out the back. Sort of like a ring compressor to get a set of pistons into a cylinder bore. Using a pick can mess up the plastic connector if you're not careful.
"I gotta rock." -- Charley Brown |
#3 |
I wish it was like those but Toyota has a different way of doing it. There are two holes for each pin. One for the pin, one for the tool. It looks like there's a small plastic barb that locks the pin in place. The tool should depress the barb and release the pin. At least that's what it looks like.
I've try a dental pick,, paper clip that I massaged in the grinder, an 1/8 pop rivit again massaged in the grinder. I'm at a loss. Looks like there are some 'tools' available on ebay,, may need to try those. These guys make it look easy..... [ame]http://youtu.be/fg1xHMIDcy4[/ame] [ame]http://youtu.be/JPGDVfl7wJY[/ame]
2015 FR-S - One Day I'll Finish The Swap Last edited by gtpvette; 02-03-2019 at 02:50 PM. |
#4 |
Screw it. I chased all of the wires left over from the FA20 yesterday in the engine compartment. Basically the AC1 plug, everything left goes to the PCM (46 wires), Injector driver to the PCM (8 wires) and the park neutral safety switch (2 wires).
The thought is to clip them short and shrink wrap the ends less the 5 ground wires in the AC1 plug as I'll ground these. Hide behind the battery,, call it good. Any thoughts from you that've done it??
#5 |
Drives: Subaru brz 2013 LS1 swap
Sorry to jump in without much to add but I am also to that point of frustration and about to just start cutting and heat shrink what's left. Seems to be the easiest route.
#6 |
Drives: LS Swapped Scion FRS = 440HP
I pulled that plastic tab up (not too far just enough), and was able to release with a very small jeweler's screwdriver. On some wires that I knew were no longer going to be used, (after getting that tab up) i was able to pull the wires and pins out with needle nose pliers.
#7 | ||
#8 | |
The only original wires I have running to the LS engine is the alternator/batterr, starter trigger, Reverse trigger too, but none of those were in the AC1 plug. Stand alone harness from wiringspecialities, PSI, speartech made the install super easy. Everything in my hand got chopped:
| The Following User Says Thank You to spitsnaugle For This Useful Post: | gtpvette (02-06-2019) |
| Switched plugs? | Legend@wheels | Engine, Exhaust, Transmission | 5 | 01-11-2019 01:54 AM |
| PLUGS? | Im_SPEED | Forced Induction | 5 | 09-03-2016 08:44 PM |
| Help! From check engine light to fouled plugs back to check engine + plugs refouling | larchamb | Issues | Warranty | Recalls / TSB | 44 | 04-03-2016 10:39 AM |
| Where do these plugs go from? | Z3D | BRZ First-Gen (2012+) — General Topics | 10 | 02-18-2013 11:59 AM |
