Old 02-04-2019, 04:45 PM   #1
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Right oil temp for higher revs
Hello everybody,
I've recently installed an OBD2 dongle together with the matching app, and was wondering at what oil temp I could start getting the engine in the higher rev range. In current use (and more or less freezing temperatures), it needs about 10 miles / 20 minutes before it stabilizes in the 180s - 190s.
Car's completely stock and using the Toyota 0W20 oil.
Thanks!
Alex
alex87f is offline   Reply With Quote
Old 02-04-2019, 04:49 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Your water temp is a more important factor than your oil temp when it comes to revving it out. As long as your coolant is at normal operating temp (180-220 deg F) you're fine, which usually happens after just a few miles depending on ambient temp.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
humfrz (02-04-2019)
Old 02-04-2019, 05:15 PM   #3
Now there ya go. Nothing else needs to be said - for fear it will trigger ANOTHER back-in-the-day story -
Tcoat (02-04-2019), thpark93 (02-11-2021)
Old 02-04-2019, 05:17 PM   #4
JIM THEO
Drives: BRZ 2018
Most high quality (ester base) oils don't protect below 70-73C degrees so regardless of what your water temp is you should give enough time for the oil to reach those temperatures
JIM THEO is offline   Reply With Quote
The Following 8 Users Say Thank You to JIM THEO For This Useful Post:
7 skulls (02-04-2019), Atmo (02-05-2019), Dave-ROR (02-04-2019), jrb363 (02-04-2019), Tcoat (02-04-2019), Tokay444 (02-06-2019), Trust86 (02-04-2019), Ultramaroon (02-04-2019)
Old 02-04-2019, 05:47 PM   #5
7 skulls
Drives: 2014 scion frs
I have the pivot dual gauge (OBD) for oil temp. and I don't run above 4000 rpm until my oil is at least 80 C (176 F). A number I determined from exhaustive internet research and the reading here on the forum.
7 skulls is offline   Reply With Quote
The Following 2 Users Say Thank You to 7 skulls For This Useful Post:
DarkPira7e (02-04-2019), Tokay444 (02-06-2019)
Old 02-04-2019, 06:01 PM   #6
Trust86
Drives: 2016 Halo FRS
Well I don’t agree with that at all. This is fake news
Trust86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Trust86 For This Useful Post:
ermax (02-06-2019), Tokay444 (02-06-2019)
Old 02-04-2019, 06:02 PM   #7
Trust86
This is real news
JIM THEO (02-04-2019), Tokay444 (02-06-2019)
Old 02-04-2019, 06:21 PM   #8
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
This. Oil being up to temp is more important that worrying about coolant temp. It will warm up slower than coolant temp.
Coolant temp will only matter when it's too cold (in which case oil will be as well) or overheating.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
Old 02-04-2019, 07:13 PM   #9
ls1ac
ls1ac's Avatar
OK, oil yes, water yes. The whole darn engine should be up to temp before wringing the blank out of it.
The Following 8 Users Say Thank You to ls1ac For This Useful Post:
Atmo (02-05-2019), e_lunatic (02-04-2019), jrb363 (02-04-2019), MCTeeJ (02-07-2019), Spuds (02-07-2019), Tcoat (02-04-2019), Trust86 (02-04-2019), Ultramaroon (02-04-2019)
Old 02-04-2019, 07:15 PM   #10
Trust86
True, but if oil is up to temp, chances are water temp has been up to temp
The Following User Says Thank You to Trust86 For This Useful Post:
Old 02-04-2019, 07:38 PM   #11
Damn kids these days - bouncing a stone cold engine off of the rev limiter. SMH
Old 02-04-2019, 09:12 PM   #12
7 skulls
Lucky our cars aren't 2-strokes. Always get my sled water temp up before I wring her out. Full throttle on an ice cold 2-stroke is just asking to stick a piston.
The Following User Says Thank You to 7 skulls For This Useful Post:
Old 02-04-2019, 11:43 PM   #13
jrb363
Drives: 2015 Scion FR-S
I redline it a couple half dozen times in the driveway when it snows to get it warm faster.
Sent from my Nexus 5X using Tapatalk
jrb363 is offline   Reply With Quote
Old 02-04-2019, 11:46 PM   #14
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Wait, is that bad?
oil, temperature
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 06:47 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-30-2013 12:50 AM
2.5L with lower revs/more torque, or 2.0L with higher revs? Superhatch Engine, Exhaust, Transmission 124 08-28-2013 01:20 PM
