Old 02-04-2019, 11:52 AM   #15
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by bsco View Post
Yeah I tried that. Car won't start, just go into accessory when turning the key all the way
Sent from my SM-G955U using Tapatalk
I understand. The car doesn't have to start to check voltage.
Just take the batter to Autozone or something and have it tested then
Old 02-04-2019, 11:53 AM   #16
bsco
Drives: 2013 Scion FRS
It's about 11.85 when off and 11.5x when trying to turn it over
bsco is offline   Reply With Quote
Old 02-04-2019, 11:54 AM   #17
finch1750
finch1750's Avatar
It's at 11.5 in ACC and 11.5 when holding it to Start? It should drop when holding it in Start
Old 02-04-2019, 11:55 AM   #18
bsco
Yes
Old 02-04-2019, 11:56 AM   #19
Boost it and see what happen.
finch1750 (02-04-2019)
Old 02-04-2019, 12:03 PM   #20
finch1750
finch1750's Avatar
Yes
The easiest thing to do is take the battery down to Autozone or something to have tested. Otherwise troubleshooting just gets more time consuming and complex.
Because your battery seems dead based on the resting voltage and is the strongest battery ever when cranking. So I'd still start there.
Tcoat (02-04-2019)
Old 02-04-2019, 12:24 PM   #21
We get this same issue brought up every month or so. Nobody ever seems to want to start with the battery. Look at all the posts in this thread alone that are saying "starter" or "alternator". The results of these threads where it just stopped working are the battery at least 99% of the time yet people still want to try everything else first.
Electrical trouble shooting hierarchy
1 - Power supply
2 - power transfer (wires and fittings)
3 - Powered equipment.
Don't start looking at equipment if you can not confirm supply.
finch1750 (02-04-2019), FRSBRZGT86FAN (02-07-2019), Sapphireho (02-04-2019), x808drifter (02-05-2019)
Old 02-04-2019, 12:27 PM   #22
bsco
1 - Power supply
Will do! Thank you
The Following User Says Thank You to bsco For This Useful Post:
Tcoat (02-04-2019)
Old 02-04-2019, 12:36 PM   #23
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Holy crap people, 11.8V isn't slightly low, it's beyond discharged.
A 12V battery is full between 12.6 and 12.8, and below 12.2 is considered completely discharged. Below 12.4 it shouldn't even be load tested.
The Following 2 Users Say Thank You to RZNT4R For This Useful Post:
bsco (02-04-2019), Ultramaroon (02-04-2019)
Old 02-04-2019, 12:37 PM   #24
bsco
Going to get it tested and get a new battery
Old 02-04-2019, 01:20 PM   #25
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
As someone who just bought a new battery, go to the dealership. It was one of the cheapest and had the best warranty.
$110 with 7 year warranty.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
Tcoat (02-04-2019)
Old 02-04-2019, 02:57 PM   #26
I find it hilarious that they offer a 7 year warranty on a replacement battery but the one that comes with the car is only covered by the general new car warranty.
I put a new battery in my car yesterday. The dealership wanted $180 for the stock one. I got a better one for $160.
8RZ (02-04-2019), FRSBRZGT86FAN (02-07-2019)
Old 02-04-2019, 03:38 PM   #27
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
It's a sports car; not a Jeep. It isn't supposed to turn over.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following 4 Users Say Thank You to Stang70Fastback For This Useful Post:
8RZ (02-04-2019), finch1750 (02-04-2019), gkubed (02-05-2019), Tcoat (02-04-2019)
Old 02-04-2019, 03:44 PM   #28
Well it can. Once.
Turn as tail timing not matching with the front turn signals NahumCC Cosmetic Modification (Interior/Exterior/Lighting) 1 01-03-2016 10:40 PM
Steering wheel issue---left turn lighter than right turn!!! xingxingtjf Issues | Warranty | Recalls / TSB 12 10-14-2015 06:47 PM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 10:11 AM
