Old 02-03-2019, 03:05 PM   #4201
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Originally Posted by nos145 View Post
contemplating between this kit and edelbrock for DD purposes and the heavenly TQ add.
have they fixed the tensioner issues on the newer versions of the kit?
They increased the belt to 30mm which help it last longer but tension is stil manually adjusted.
Sent from my iPhone using Tapatalk Pro
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following User Says Thank You to Apoc For This Useful Post:
nos145 (03-21-2019)
Old 02-09-2019, 05:05 PM   #4202
grostoine
Drives: Subaru BRZ
Am I the first one to try the kit on a 2017 Toyota 86 ? The piping that goes to the intercooler are interfering with the bumper. The intercooler would need to move back 1 inch and a quarter so the bumper could fit. Is there new bracket ? I have a kit that was sold in the first 30 !
grostoine is offline   Reply With Quote
Old 03-20-2019, 09:39 AM   #4203
j.F.c.R.a.S
j.F.c.R.a.S's Avatar
Drives: rx8. frs.
Anyone tracking their car with this kit? Autocross, drifting, etc.
I started drifting my car last year, the first belt lasted a few events. I replaced the belt and this one only last about 1 1/2 events, with one event in the raining and this last event maybe about 25 laps total. It’s sad when my cheap tires last longer than a belt. Feel like this kit was more for street driven cars or show cars.
j.F.c.R.a.S is offline   Reply With Quote
Old 03-20-2019, 10:40 AM   #4204
J1Avs
Drives: 2018 BRZ tS
Jackson and Edelbrock are the only SC kits, that I am aware of, that are certified from the manufacturer to fit the MY17+ without any modification. It appears the Sprintex does as well, but quite tightly. My guess would be, no they did not update the kit, as I did pretty extensive research before deciding on my JRSC C30 kit for my 18 tS.
J1Avs is offline   Reply With Quote
Old 03-22-2019, 08:03 AM   #4205
j.F.c.R.a.S
Drives: rx8. frs.
Has anyone upgraded to the 30mm belt? If you have, how is it holding up?
Old 04-17-2019, 09:32 AM   #4206
j.F.c.R.a.S
Drives: rx8. frs.
No one?
Or did everyone sell their kit? Haha
Old 04-17-2019, 09:39 AM   #4207
15limited
15limited's Avatar
Idk when, but Kraftwerks, revised the kit to come standard with the wider belt/pulleys. But I've read with the new wider belt, failure is no longer a concern.
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 04-17-2019, 01:12 PM   #4208
j.F.c.R.a.S
Drives: rx8. frs.
Well, the first belt system wasn’t a concern until I started tracking the car, I wonder if anyone here has tracked their car with the new belt system.
Old 04-17-2019, 06:18 PM   #4209
15limited
15limited's Avatar
I mean that would make sense with the increased load on the engine, hence them making the system stronger...
Old 04-24-2019, 04:42 PM   #4210
blu-frs
Drives: scion frs
I’ve bought a used kit and installed it but not getting boost. Anyone know what i can do to troubleshoot it?
blu-frs is offline   Reply With Quote
Old 04-24-2019, 10:01 PM   #4211
Apoc
Apoc's Avatar
Is everything connected and clamped. No leaks? Are you data logging? Seeing posts you had put up previously leads me to suspect you are in way over your head or are trolling. You have been installing this since Sept last year .
“The World is Flat”
[||•]=(86)=[•||]
Old 04-25-2019, 01:35 PM   #4212
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
@Apoc
Since you are local to me, I may be able to help. Shoot me your # over PM and we can talk over text if you'd like.
projek_01 is offline   Reply With Quote
Old 04-25-2019, 08:25 PM   #4213
Apoc
Apoc's Avatar
Originally Posted by projek_01 View Post
@Apoc
what do I need help with??
“The World is Flat”
[||•]=(86)=[•||]
Old 05-06-2019, 03:10 AM   #4214
codec
Drives: gt86 FIRST edition #86
Does anyone own the basic software for the map of the 86 with volumetric? Or at least an example from which to adapt then the map to my car
codec is offline   Reply With Quote
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
