Southern California SoCal
Old 02-03-2019, 02:36 PM   #1
tunami
tunami's Avatar
Drives: 2013 FR-S 6spd Whiteout
Mounting used tires... suggestions
I have a set of new wheels that I want to put on my car, but would like to mount the tires on my current wheels (conti extremecontact sport) onto them. The tires are less than a year old, but I’m having a hard time finding a shop that will mount used tires in the OC area. Is there a big danger in mounting used tires?
tunami is offline   Reply With Quote
Old 02-03-2019, 02:39 PM   #2
jjlBRZ
Drives: 2019 BRZ
Um are the wheels a different size than what the used tires are currently on?
I just did the same on my STI at a discount. The wheels were an inch wider so there's a bit of a stretch but they did mention there is a limit to where they wouldn't mount them (stock I'm 8.5, went to 9.5, their limit IIRC was 10). It looks kinda stupid, but I have over 80% tread life on them.
Sent from my Pixel 3 XL using Tapatalk
jjlBRZ is offline   Reply With Quote
The Following User Says Thank You to jjlBRZ For This Useful Post:
tunami (02-03-2019)
Old 02-03-2019, 02:44 PM   #3
tunami
tunami's Avatar
I bought the brz performance package wheels from another member, tire size is exactly the same. Every shop I’ve called said they don’t mount used tires. I haven’t tried discount tire yet.
Old 02-03-2019, 02:46 PM   #4
jjlBRZ
Drives: 2019 BRZ
Uh... Then wtf. What tire shops are you going to?
This is just a swap, they shouldn't be hassling you unless there's a defect in your current (or tread life) tires, which they should be pointing out...
Old 02-03-2019, 02:54 PM   #5
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Just pull up to any local mom&pop tire shop and they’ll do it. Usually $15/ tire to dismount, remount and balance.
But i recommend R compound if you cant find a shop in your area.
Decimus is offline   Reply With Quote
The Following User Says Thank You to Decimus For This Useful Post:
tunami (02-03-2019)
Old 02-03-2019, 03:07 PM   #6
tunami
tunami's Avatar
@Decimus, if I can’t find anything closer I will check them out. Thanks!
Old 02-03-2019, 03:58 PM   #7
ls1ac
ls1ac's Avatar
You are looking is all the wrong places.
Find a happy Harrys used and discounted tire shop. They are usually in a lesser part of town. They are going to help, but their balancing equipment is two generations old.
The Following User Says Thank You to ls1ac For This Useful Post:
tunami (02-03-2019)
Old 02-04-2019, 12:12 AM   #8
Thaeyo
Thaeyo's Avatar
Check out my buddy's shop, he's my go to for any tire swaps. Exact situation that you're describing.
Tire Squad
tiresquadautorepair.com
15199 Moran St, Westminster, CA 92683
Thaeyo is offline   Reply With Quote
The Following User Says Thank You to Thaeyo For This Useful Post:
tunami (02-04-2019)
Old 02-04-2019, 12:20 AM   #9
"Only in California" -
Old 02-04-2019, 12:47 AM   #10
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Pifff,
Nah it's just curtain tire shops.
The Following User Says Thank You to Mr.ac For This Useful Post:
humfrz (02-04-2019)
Old 02-04-2019, 12:49 AM   #11
jjlBRZ
Drives: 2019 BRZ
It's not a problem in California, it's whatever shop OP is going to.
As I mentioned, I had my tires swapped to a 1 inch wider wheel in my STI a month ago at a Discount Tire. If anyone was going to give me crap it would been them.
humfrz (02-04-2019)
Old 02-04-2019, 01:27 AM   #12
Thaeyo
Thaeyo's Avatar
Discount tires, America's tire, and all of those big chains have a company policy of not performing certain tasks. Such as stretching tires, performing rotations on anything lower than 2-3/32", removing TPMS (even to just transfer...), tires older than 8-10 years, etc.
humfrz (02-04-2019)
Old 02-04-2019, 01:40 AM   #13
tunami
tunami's Avatar
Tire Squad
Awesome, thanks man! Hit them up for a quote.
The Following User Says Thank You to tunami For This Useful Post:
Thaeyo (02-06-2019)
Old 02-10-2019, 05:44 AM   #14
wangson
wangson's Avatar
Drives: 2023 Toyota GR86 Trueno Blue
Check out Menos Tires in Downtown Los Angeles. They close at 10 pm everyday. The only bad thing is they are probably cash only.
https://www.yelp.com/biz/menos-tires...-los-angeles-4
wangson is offline   Reply With Quote
Mounting tires and different mounting equipment BR-ZED Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 07-08-2018 11:41 AM
Meaty tires suggestions for 17x8 35? YamahaR86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 12-04-2015 12:24 PM
New Rims and Tires! suggestions?? Chase1996 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 11-27-2015 10:58 PM
Mounting tires in the Bay Area chiefshayan Northern California 3 09-14-2015 05:01 PM
Mounting OFT? JDsThatGuy Software Tuning 3 04-09-2015 10:49 PM
