#15 |
Drives: Black GT86 auto 2013
Not new. I went uel catless and had it ecutek tunned at the same time about a month ago. Didn’t notice popping noises, and it hasn’t happened since. It’s going back to the tunner to be looked at. Thanks for the suggestions.
#16 |
Drives: 2014 Scion FR-S
I am having the same issue with my car. Its not as bad as in the video posted above but is very similar. Has anyone had this issue and properly resolved it?
#17 |
This tread found the issue to be a bad direct injector. http://www.ft86club.com/forums/showthread.php?t=132025
I'm going to be pulling my direct injectors this week and am going to get them flow tested to find the bad ones. I will give an update when I get the car back together. |
#18 |
I’d be interested to know how you get on. Does your do it on every journey?
#19 |
#20 |
Drives: Black frs
You would think if it was a sensor (map, tps, maf) it would throw some type of code and the Check engine light would come on.
That would leave... Dirty fuel injectors Weak fuel pump/relay/filter Vacuum leak Bad gas Bad spark plug Bad spark plug wires/coils |
| Car pulling under acceleration | Midjetv8 | Issues | Warranty | Recalls / TSB | 37 | 11-15-2016 10:53 AM |
| What is your 0-60 acceleration time? | sci3 | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 08-14-2014 11:01 PM |
| Acceleration Times | itdansharpe | Engine, Exhaust, Transmission | 8 | 06-09-2013 05:25 PM |
| Does the A/C cut off upon hard acceleration? | brillo | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 03-26-2013 10:31 AM |
| Acceleration | Axel | Other Vehicles & General Automotive Discussions | 0 | 02-10-2010 07:56 PM |
