Old 08-13-2014, 10:24 PM   #1
sci3
Drives: Seckksy
What is your 0-60 acceleration time?
Do you drive manuel or auto?
What is your 0-60mph/ 100kms acceleration time?
Can you get it past 7 seconds on a SCION FRS/brz / toyota 86 only
sci3 is offline   Reply With Quote
Old 08-14-2014, 12:22 AM   #2
jainish007
Drives: 2014 Monogram Scion FRS Whiteout
Today I just pulled roughly 6 sec 0-60 pull on freeway 405. I only weight 104 lbs. 6 speed monogram whiteout FRS
jainish007 is offline   Reply With Quote
Old 08-14-2014, 12:31 AM   #3
Chimera
Drives: FRS
104? I'm nearly two of you.
Old 08-14-2014, 12:33 AM   #4
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Probably somewhere around 3.5 seconds on my motorcycle, but I'm not sure how that's relevant.
FR-S? I'm not sure. 6spd manual, I suspect the best way to get it down is to start with the tires burning, and raise the redline a smidge so you hit 60 in 2nd.
Also, who is this Manuel you keep talking about?
JohnJuan is offline   Reply With Quote
The Following 4 Users Say Thank You to JohnJuan For This Useful Post:
DAEMANO (08-14-2014), Rio (08-14-2014), Roadster19 (12-21-2014), TJ3000 (08-14-2014)
Old 08-14-2014, 12:36 AM   #5
Chimera
Drives: FRS
Can one use launch control for this contest?
Old 08-14-2014, 12:40 AM   #6
Dipstik-sportech
Dipstik-sportech's Avatar
2.9sec on drag radials
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
JohnJuan (08-14-2014)
Old 08-14-2014, 01:15 AM   #7
humfrz
Oh, yes ..... easy, I can get 8 or 9 or 10 seconds real easy (MT) .....
Sorry fer messen wich your thread .....
humfrz
JohnJuan (08-14-2014), Rio (08-14-2014)
Old 08-14-2014, 01:26 AM   #8
frsqc
Drives: raven FRS
RAVEN FRS 2013 - TRD air filter - Nameless OP/DP - Greddy EVO3 - STAGE 2 OFT/OFH -
frsqc is offline   Reply With Quote
Old 08-14-2014, 02:16 AM   #9
Zozr
Drives: White
Are you female?
Zozr is offline   Reply With Quote
Old 08-14-2014, 07:56 AM   #10
paulca
Drives: Toyota GT86 Coupe Red (UK)
Originally Posted by Zozr View Post
Are you female?
If not, are you 12? If not EAT MORE!
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Old 08-14-2014, 11:42 AM   #11
TStafford
TStafford's Avatar
Drives: 2015 FR-S Ultramarine Metallic
Do you guys have a good app to record this?
TStafford is offline   Reply With Quote
Old 08-14-2014, 12:12 PM   #12
Xti
Drives: Fast, Cool, New
The topic should be "What is your longest Drift time ?"
Xti is offline   Reply With Quote
The Following 2 Users Say Thank You to Xti For This Useful Post:
funwheeldrive (08-14-2014), JohnJuan (08-14-2014)
Old 08-14-2014, 12:46 PM   #13
MrAmalto
My longest drift time is about 10 seconds. Happened this past weekend at 86Fest AutoX. I'm pretty sure it was about than long since that run time was 10 seconds slower than my previous time xD
MrAmalto is offline   Reply With Quote
The Following User Says Thank You to MrAmalto For This Useful Post:
Old 08-14-2014, 01:06 PM   #14
You mean on purpose?????????????
acceleration thump mid_life_crisis Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-10-2013 10:19 PM
Acceleration Lag - Intermittent donnyk CANADA 6 07-18-2013 12:53 AM
Acceleration Times itdansharpe Engine, Exhaust, Transmission 8 06-09-2013 05:25 PM
Does the A/C cut off upon hard acceleration? brillo Scion FR-S / Toyota 86 GT86 General Forum 13 03-26-2013 10:31 AM
Acceleration Axel Other Vehicles & General Automotive Discussions 0 02-10-2010 07:56 PM
