Old 01-26-2019, 12:01 PM   #15
DraxReaper
Drives: Black GT86 auto 2013
Not new. I went uel catless and had it ecutek tunned at the same time about a month ago. Didn’t notice popping noises, and it hasn’t happened since. It’s going back to the tunner to be looked at. Thanks for the suggestions.
DraxReaper is offline   Reply With Quote
Old 01-27-2019, 01:41 PM   #16
shawnmcgettigan
Drives: 2014 Scion FR-S
Originally Posted by hussen View Post
Hi guys
I have problem in my toyota 86 2013
When start accelerating hardly some vibration/shock on the rpm comes.
Kindly have a look at the below video for the problem.
Anybody face this problem can help me?
Regards
I am having the same issue with my car. Its not as bad as in the video posted above but is very similar. Has anyone had this issue and properly resolved it?
shawnmcgettigan is offline   Reply With Quote
Old 01-29-2019, 07:07 PM   #17
shawnmcgettigan
This tread found the issue to be a bad direct injector. http://www.ft86club.com/forums/showthread.php?t=132025
I'm going to be pulling my direct injectors this week and am going to get them flow tested to find the bad ones. I will give an update when I get the car back together.
Old 01-30-2019, 06:28 PM   #18
DraxReaper
I’d be interested to know how you get on. Does your do it on every journey?
Old 02-08-2019, 04:01 PM   #19
shawnmcgettigan
It happens most of the time when I'm between 2500 and 3000rpms. I have new direct injectors on order. hopefully ill be up and running next week.
Old 02-08-2019, 08:35 PM   #20
Silverz
Drives: Black frs
You would think if it was a sensor (map, tps, maf) it would throw some type of code and the Check engine light would come on.
That would leave...
Dirty fuel injectors
Weak fuel pump/relay/filter
Vacuum leak
Bad gas
Bad spark plug
Bad spark plug wires/coils
Silverz is offline   Reply With Quote
Car pulling under acceleration Midjetv8 Issues | Warranty | Recalls / TSB 37 11-15-2016 10:53 AM
What is your 0-60 acceleration time? sci3 Scion FR-S / Toyota 86 GT86 General Forum 21 08-14-2014 11:01 PM
Acceleration Times itdansharpe Engine, Exhaust, Transmission 8 06-09-2013 05:25 PM
Does the A/C cut off upon hard acceleration? brillo Scion FR-S / Toyota 86 GT86 General Forum 13 03-26-2013 10:31 AM
Acceleration Axel Other Vehicles & General Automotive Discussions 0 02-10-2010 07:56 PM
