Old 01-24-2019, 01:23 PM   #52361
p1l0t
p1l0t's Avatar
Interesting approach - however, meet mrs humfrz -
I'll bet she cleans up nice.
p1l0t is offline
Old 01-24-2019, 01:55 PM   #52362
If she ever sees your posts, you are a dead man.
Please tell us you are getting the water heater installed today.
Also, how's your pain management now? A lot better I hope.
Well, Sapphireho, thanks for asking.
I arranged to have mrs humfrz pre-emptively banned from the forum - so, I think I'm safe.
The hot water heater installer dude is scheduled to arrive between noon and 2 PM TODAY! Yaaaa ….
Pain management? Under the circumstances, my back pain, has been put on hold, till we get some hot water (nobody around here wants to hear about it - ).
Story time - why I don't hook up the hot water heater myself??
Back in Missouri, I had a gas hot water in the basement, that went out. So, I took my 3/4 ton PU truck and picked up a new one. I was ready to install that puppy, so I decided to call my oldest son down to the basement to show him how to "sweat" copper pipes together to hook up the water supply.
So, after shutting off the water and draining the lines, I grabbed my soldier and fired up my torch. Yep, I showed him how to clean the copper pipes and fittings first. Well, after several attempts, I COULD NOT get the copper pipe and fittings not to leak after several attempts to "sweat" them together.
My son was NOT impressed, so I sent him upstairs. Then I called a plumber.
The plumber arrived the next day and started the minor job. He asked for a piece of bread. I thought he was hungry, so I went upstairs and made him a sandwich. He thanked me, then took the top slice of bread off, wadded it up and stuffed it up into the copper pipe that led down from the ceiling.
THAT stopped the constant dripping of water, that was preventing the copper fitting from to sweating to the copper pipe without leaking.
(the bread just washes out after the water is running)
THE END
humfrz is offline
p1l0t (01-24-2019), Sapphireho (01-24-2019)
Old 01-24-2019, 02:58 PM   #52363
If she could!
Tcoat is offline
humfrz (01-24-2019), p1l0t (01-24-2019), Sapphireho (01-24-2019)
Old 01-24-2019, 03:19 PM   #52364
If she could!
Actually if she WOULD. I rigged up a shower out on the deck, but, she won't use it -
(damn spoilt woman - )
humfrz is offline
Old 01-24-2019, 03:20 PM   #52365
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
I like riddle... but I hate when they make riddle that have multiple answers, so they can say I’m wrong. When I point out their mistakes/errors, they just say “It’s just for fun”... FUCK YOU & YOUR STUPID RIDDLE!!!!!
potty mouth.........lol
IceFyre13th is offline
Old 01-24-2019, 03:23 PM   #52366
IceFyre13th
Drives: Mazdarati
Stainless. The aluminum ones can oxidize.
= aluminum oxide......aluminum rust
iron oxide is rust too........lol
Old 01-24-2019, 03:40 PM   #52367
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Sort of....
Only Iron, or metal with iron in it like steel, can "rust". Which happens in a combination of water and air.
Aluminum is subject to oxidation. Aluminum oxide forms on the surface from exposure to air. The oxide is harder than aluminum. And, protects the aluminum form further deterioration. Aluminum has a hardness of 2-2.9. Aluminum oxide is 9 in hardness; the same hardness as sapphire. Aluminum will deteriorate in chlorine. Or in environments that have extreme PH.
Rust does not protect iron. In this way Iron Oxide and Aluminum oxide are fundamentally different.
I LIKE TIRES!
Leonardo is offline
Spuds (01-24-2019)
Old 01-24-2019, 03:43 PM   #52368
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I bought a 2TB HP NVME drive. Once in, my lappy will hold 4TB total. Not perhaps as much as I'd like, but passable.
EAGLE5 is offline
Old 01-24-2019, 03:58 PM   #52369
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Haha thanks Dave for removing my “potty mouth” post lol
...but that riddle deserve my potty mouth
ichitaka05 is offline
Old 01-24-2019, 03:59 PM   #52370
IceFyre13th
Drives: Mazdarati
I thought it was funny......LOL
Old 01-24-2019, 06:02 PM   #52371
cjd
cjd's Avatar
Drives: 2017 BRZ
Finally have a new furnace... which is good, because tomorrow is supposed to be low single digits into the negatives (F) overnight. Already seems to be working better than the old one since our Nest says 2hrs for the remaining 2 degrees, but it's already up 10 in under an hour...
Down side is, because the engineer was inattentive and presumptive, we thought the a/c condenser was 15 and reasonably due for replacement. Turns out, it was the 10 year old condenser... but the new one should be a lot more efficient, and too late now, so... in it goes. Tomorrow. That's right, they'll be installing our air conditioning when it is no warmer than 4 degrees out there. At least mostly out of the wind, I hope!
cjd is offline
The Following User Says Thank You to cjd For This Useful Post:
humfrz (01-24-2019)
Old 01-24-2019, 07:00 PM   #52372
You have had no heat and we have been listening to Hum's wife (by proxy) complain abut no hot water?
Tcoat is offline
cjd (01-24-2019), humfrz (01-24-2019)
Old 01-24-2019, 07:35 PM   #52373
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
We went back to doing a major portion of our heating with wood again this year, and it's really true... wood heat keeps you warmer. You're warm while you split it, you're warm while you haul it, you're warm while you stack it, you're warm while you haul it inside for burning, you're warm bent over trying to coax the morning fire back into life....
Drive like everyone's life around you depends on it...
MuseChaser is offline
The Following 4 Users Say Thank You to MuseChaser For This Useful Post:
cjd (01-24-2019), EAGLE5 (01-25-2019), humfrz (01-24-2019), Tcoat (01-24-2019)
Old 01-24-2019, 07:45 PM   #52374
I spent the better part of my childhood doing those things and when we bought our current house it had a wood stove. I don't think we were fully moved in before I had it ripped out and sent for scrap!
Tcoat is offline
Dadhawk (01-24-2019), humfrz (01-24-2019)
