Old 01-19-2019, 05:22 PM   #1
maxspeed
Drives: frs
Do you need oil gauges for tracking
Just got a 86. I have installed the JR oil cooler.
Do I need to install a gauge to monitor oil temperature or is not necessary? Hoping that this is NOT necessary since I put the cooler on.
I run about 12-15 weekends a year, consider my self an intermediate/advanced driver.
Last edited by maxspeed; 01-20-2019 at 12:32 PM. Reason: meant to say Not necessary
maxspeed is offline   Reply With Quote
Old 01-19-2019, 05:28 PM   #2
FastWhite
Drives: Subaru BRZ Limited M/T
You can always buy an OBD II scan tool, hook it up to your phone and monitor temps that way.
FastWhite is offline   Reply With Quote
Old 01-19-2019, 07:30 PM   #3
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
You don't "need" them. But it is always nice to know where your temps are. I 2nd the OBDII scan tool and phone app route for starters.
justinco is offline   Reply With Quote
Old 01-19-2019, 08:29 PM   #4
maxspeed
Drives: frs
I have one the wireless scan tool modules I can use. Just wasn't sure if most of the track guys were monitoring the oil temperatures each session.
Old 01-19-2019, 10:11 PM   #5
Robbie
In the slipstream
In the three years I’ve tracked my BRZ, I’ve never logged. I just check using my scan tool after a session is finished.
Robbie is offline   Reply With Quote
Old 01-20-2019, 12:07 AM   #6
fminicooper
Drives: FRS Hot Lava
Using ScanTool OBDLink LX Bluetooth...pricey yes. Works perfect.
Its connects to lap timer apps.
Needed in summer texas weather.
Sent from my SAMSUNG-SM-G930A using Tapatalk
fminicooper is offline   Reply With Quote
Old 01-20-2019, 12:20 AM   #7
86MLR
86MLR's Avatar
The only way to maybe saving your engine is big bright warning lights.
I've use longacre with good success.
http://www.longacreracing.com/products.aspx?itemid=1734
Going from good oil pressure to none doesn't take long.
Temps on the other hand are much slower and you can identify a issue if you keep looking at the gauges.
Me, I tend to not pay to much attention to gauges when I'm going balls to the wall.
A big bright light within my field of view will let me know its time to back off, and look at the gauge.
Old 01-20-2019, 07:39 AM   #8
Juzzotec
Juzzotec's Avatar
Drives: Toyota 86 GTS
Android Headunit + OBDLink MX
Juzzotec is offline   Reply With Quote
Old 01-20-2019, 10:26 AM   #9
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I've considered this route
OP, since I'm in Florida when I ran the BRZ I did run oil temp and oil pressure gauges. I do that in pretty much all my track cars (all except for the Camaro which has some built in but they suck to switch between and use on track - I data log with that car though).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-20-2019, 12:27 PM   #10
fminicooper
Like it. I will consider. Not expensive.
Old 01-20-2019, 12:28 PM   #11
fminicooper
Thanks, do you know if you can program any alarm base on a previus set up?
Old 01-20-2019, 12:31 PM   #12
maxspeed
Drives: frs
Did you ever see temps/pressures that forced you to come in early or take it easy on the next lap?
Old 01-20-2019, 02:11 PM   #13
redlined600
redlined600's Avatar
Drives: Fr-s
I ended up using one of these for pressure, it has built in warnings as well as an output for external warning light.
http://www.longacreracing.com/produc...30&prodid=7405
redlined600 is offline   Reply With Quote
The Following User Says Thank You to redlined600 For This Useful Post:
86MLR (01-20-2019)
Old 01-20-2019, 05:28 PM   #14
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
With an oil cooler, no. Sometimes pressures in the race car cause it uses oil.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Tracking the F's Gearbanger Tracking / Autocross / HPDE / Drifting 13 08-07-2016 05:42 PM
Circuit Tracking the FRS!! nmctacticz Tracking / Autocross / HPDE / Drifting 5 04-02-2016 12:17 PM
Car Tracking systems Sudhir AFRICA 5 07-06-2013 05:52 PM
Oil and tracking? SavingManuals Scion FR-S / Toyota 86 GT86 General Forum 11 07-04-2013 05:38 AM
Who's tracking their BRZ? random hero BRZ First-Gen (2012+) — General Topics 11 08-20-2012 10:30 PM
