Old 11-07-2017, 01:02 AM   #15
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Originally Posted by Pointmutation View Post
Why no Mishimoto on this list? Just started researching oil coolers recently too.
Make sure you get the updated version. The older versions were known to leak
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
Pointmutation (11-07-2017)
Old 11-07-2017, 06:50 AM   #16
Azzudien
Drives: 2017 Series Yellow BRZ
If you get a 2017 manual BRZ, remember Jackson Racing oil cooler will not clear the air box.
Azzudien is offline   Reply With Quote
The Following User Says Thank You to Azzudien For This Useful Post:
botbs (07-02-2018)
Old 01-19-2019, 02:58 PM   #17
Sgtfluffy16
Drives: White BRZ Limited
I know I'm Reviving a dead old thread. But I am tracking the car this year. What are your thoughts now on the oil cooler kits that are out there. Or what about this one?
https://www.nedautoparts.com/product...nt=25891388432
Sgtfluffy16 is offline   Reply With Quote
The Following User Says Thank You to Sgtfluffy16 For This Useful Post:
Sisko's_Baseball (06-03-2021)
Old 01-19-2019, 03:22 PM   #18
Just get the correctly-sized traditional Jackson and call it a day.
https://jacksonracing.com/product/fr...il-cooler-kit/
Old 01-19-2019, 03:28 PM   #19
Sgtfluffy16
Because I feel like there are a ton of better options out there than the Jackson Racing one.
Old 01-19-2019, 03:31 PM   #20
Like?
Old 01-19-2019, 03:37 PM   #21
Sgtfluffy16
Multiple
Oem "ish" option https://www.nedautoparts.com/product...nt=25891388432
More cooling capability https://maximalperformance.com/produ...er-kit-frsbrz/
Old 01-19-2019, 04:48 PM   #22
OwlDance
Drives: Halo 86, '19
You literally just bumped another thread that literally discussed those options for you and then some...
Guess I ended up reading the thread for you because the DIT kit is good enough for spirited driving on NA power, not track. Here's the first thing that comes up on google. http://www.ft86club.com/forums/showthread.php?t=93127
The poster of the Maximal kit said it was decent enough for NA tracking and even posted a datalog of it. Said you should go heavier duty on cooling if FI, which you stated you had. Everyone else more or less pointed to Jackson, RacerX, and Mishimoto.
With the assumption you want "best bang for buck" as the parameter for "BETTER" just get a heavier duty oil cooler from any of those mentioned options since you're on forced induction dude, which means more heat and more potential for damage on the engine without adequate cooling. That, purportedly, neither the DIT nor Maximal can provide for FI. It's not rocket science. You put thousands of dollars into an engine and car, why skimp on merely one of the most important aspects of vehicle protection and maintenance?
OwlDance is offline   Reply With Quote
Old 01-19-2019, 05:54 PM   #23
ZDan
ZDan's Avatar
Drives: '23 BRZ
You could send oil sample to Blackstone, run a track event or two without a cooler, then send another sample and see if oil is still ok and if there excess of bearing material or other particulates indicating undue wear. If all is OK with 2nd sample, maybe no oil cooler needed...
Full credit to Bonburner for this straight-to-the-bloody-point easily implemented ideer, see post #56 from this thread: https://www.ft86club.com/forums/show...=132041&page=4
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Sgtfluffy16 (01-19-2019), Ultramaroon (01-19-2019)
Old 01-19-2019, 06:00 PM   #24
In terms of heat transfer rate those two range between laughable and too small, respectively. ZDan is on point but if you're going to go to the trouble, you might as well do it properly.
Old 01-19-2019, 06:02 PM   #25
Sgtfluffy16
Full race is another one i was looking at
Old 01-19-2019, 06:44 PM   #26
ayau
Drives: Some rust bucket
The OEM Forester XT oil cooler is only marginally better than no oil cooler. I would not bother. It's only on the turbo Subaru cars to decrease the oil warm up times.
How often are you planning to track your car and what's your experience level? You might be able to get away with no cooler if you're only going to see the track 1-2 times a year and have little to no track experience.
Running a proper oil cooler, such as the Jackson cooler, just means your oil is going to take a long time to reach operating temp in the winter, and you'll have additional points of failures.
Old 01-19-2019, 06:54 PM   #27
Sgtfluffy16
I have five events already scheduled this year, and looking to add possibly three or four more. again, I'm not going with the Jackson Racing one. I've already looked into the fact of getting oil coolers. But one that has a thermostatic switch. The other thing is I put my car away from November 15th to February 15th every year
Located in central Pennsylvania so it doesn't get super cold when I am driving the car
Old 01-19-2019, 07:10 PM   #28
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Tranny mounts: STI Group N (vs) "others" need some others comparisons.. OICU812 Engine, Exhaust, Transmission 8 04-15-2014 12:11 AM
Sizing comparisons? rainmonkey Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 04-17-2013 01:47 PM
Bolt-ons dyno comparisons thread? seven Engine, Exhaust, Transmission 6 11-25-2012 10:28 PM
Personal Comparisons to Elise BobsElise FR-S / BRZ vs.... 30 10-26-2012 06:29 PM
some comparisons i'm interested in pr086 Scion FR-S / Toyota 86 GT86 General Forum 25 07-07-2012 02:11 PM
