#29 | |
Nope. You still need to stiffen up the diff mounts to lessen how much it moves under load.
#30 | ||
Drives: 2022 GR86
My OS Giken contact (who is also a friend, and is also on these forums) instructed me to drop it right in. I have other friends (also on the forum) who have swapped the OSG diff in and out multiple times and did not have to do anything other than pull and replace. YMMV. My diff is quiet, there might be a little whine when slowing but that's about it. It clunked A LOT with the Motul fluid in there, nice and quiet once switched to the proper OS 250R. The NVH did not change after the OSG diff was installed. I still recommend the diff inserts regardless of what diff you have in there, it makes a big difference.
#31 |
Drives: 2017 BRZ w/PP
really fucking dumb question, how beneficial would this be in winter weather? took my car to an empty lot to play around in the snow today and was thinking on the way home good thing i didnt get stuck. saw this thread and wondered.
#32 |
Drives: 2022 GR86
Your stock Torsen is just fine.
#33 |
#34 | |
Steve Bodalenko
Drives: Toyota 86 GTS
Yes they make a huge difference and if you can put up with the mild side effects are well worth doing. |
#35 | |
Drives: 13 BRZ, 17 Focus RS
#36 | |
Drives: 16' BRZ
#37 |
Drives: 2016 BRZ
I'm currently rebuilding a dif for friends who have a local shop to me and the previous builder used that gasket and it worked great. I even ordered the same thing for when I'm done with this rebuild.
#38 |
Drives: 2022 GR86
It worked perfectly fine!
#39 | |
Drives: 2015 Series Blue BRZ WRB
So the IRP shifter is STX legal? |
#40 |
Noodleking
Drives: 2013 Firestorm FRS
Anyone here know how these OS Giken's come straight from the factory? I haven't found much info on it as a 1.5 way or 2 way and there aren't any specs on it. When I contacted OS Giken USA, they told me to send one in to get tuned for my specific application. I'm looking to drift with it. Any info out there or resources you've been able to find?
2013 Firestorm FR-S, Kraftwerks C38 kit, FT-86 UEL Catted Headers, TRD D-Tip cat-back, Vibrant 1140 Resonator, Exedy Stage 1 Normal/smoother clutch that replaced the Stage 2 3-puck clutch, Exedy Lightweight flywheel, DSS carbon fiber driveshaft, TEIN springs on performance package Sachs dampers, Megan Racing Inner tie rods, 17x8 +35 Enkei Silver RPF1's, OS-Giken 1.5-way diff, J-Luth steering wheel and now a GKTech angle kit-- which rubs.
#41 | |
Drives: 2022 GR86
#42 |
Drives: None
If someone has a picture of one pre-install looking in at the ramps we could tell you.
I will say that it is totally worth it to send the diff off to Lugod (OSGiken USA in CA) to be retuned, it was night and day on my S2000.
| Tags |
| lsd, os giken |
| Review soon:OS Giken Super Lock Limited Slip Differential + Greddy differential cover | mav1178 | Engine, Exhaust, Transmission | 5 | 02-11-2021 01:20 PM |
| Project Mu Lugs BNIB - Racing Floating Nut & Super Lock Nut 7 | SonnyBRZ | Canada Classifieds | 0 | 02-05-2014 10:37 PM |
| Results: OS Giken SoPac Super Regional Autox Championship ... | des | Tracking / Autocross / HPDE / Drifting | 5 | 06-25-2013 11:02 PM |
| Nagisa Auto D-Lock Super Low Seat Rail | poormans_LFA | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 11-06-2012 04:35 PM |
