Drives: frs whiteout
valve spring recall/ additional work performed when engine is out
hi what would you recommend to do additional when the Dealer is doing recall for valve springs more than spark plugs. thanks inadvance
#2 |
Drives: Asphalt FR-S
#3 |
| The Following User Says Thank You to humfrz For This Useful Post: | why? (03-09-2019) |
#4 |
#6 |
Drives: WRB BRZ
My dealer refused to do any additional work. This is Steven creek subaru in NorCal. They first said yes, but on the actual day, they refused to do it and wanted to charge full labor. Doesn’t make sense. They just hate me. Oh well.
#8 |
Drives: BRZ Premium GBS
does anyone know if a coolant flush is done with the valve spring recall?
#9 |
Coolant is listed in the parts. Doubt they do an actual flush though. They will just drain out what they need and then replace it.
| The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (01-18-2019) |
#10 |
Drives: '13 BRZ
What about swapping over to the revised throw-out bearing design?
#11 |
Then I wouldn't have left the car. I realize you may only have so many choices with a Subaru (fewer dealers) but from a customer prospective that makes no sense.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#12 |
#1 Plugs
#2 Throw out bearing/clutch #3 Address any other leaks you may have on the car #4 Does car need other maintenance? Trans or Diff fluid, Alignment, brake flush, etc. Great time to get it done as you will be at the dealer and have a loaner. #5 Motor Mounts? |
| The Following 5 Users Say Thank You to ka-t_240 For This Useful Post: | Blu-by-U (03-09-2019), DarkPira7e (01-18-2019), slizoth (01-18-2019), swfrs (01-18-2019), tobin (01-18-2019) |
#13 |
Rust bucket enthusiast
As I posted in the other recall threads, they're doing my plugs and clutch assembly. Charging me a half hour of labor for clutch, no labor on plugs. Priced plugs at $8-10 a piece which is very fair. They even asked if I had a preferred oil weight and what expected capacity is with my oil cooler installed
#14 |
The OP's question was "more than spark plugs".
That's the reason I said "nothing" - (nothing, more than spark plugs).Is this a test to see whether or not ol humfrz is payen attention? As Willie would say - "after taking several readings, I think my mind is fairly sound". Now, my body is shot - but, that's not what were talkin about - was it? - ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Blu-by-U (03-09-2019) |
| 2013 Valve Spring recall - modified (FI) engine thread | shiumai | Forced Induction | 71 | 08-11-2020 06:21 PM |
| Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 09:32 PM |
| Valve spring recall | meadowz06 | Issues | Warranty | Recalls / TSB | 115 | 06-08-2019 11:38 PM |
| valve spring recall-engine oil leak | TYinhouse | Issues | Warranty | Recalls / TSB | 13 | 01-17-2019 11:09 AM |
| I have the valve spring recall information. | meadowz06 | Issues | Warranty | Recalls / TSB | 24 | 12-23-2018 08:44 PM |
