Old 01-17-2019, 05:14 PM   #1
swfrs
Drives: frs whiteout
valve spring recall/ additional work performed when engine is out
hi what would you recommend to do additional when the Dealer is doing recall for valve springs more than spark plugs. thanks inadvance
swfrs is offline   Reply With Quote
Old 01-17-2019, 05:26 PM   #2
pasternak
Drives: Asphalt FR-S
Same question. 58K miles.
pasternak is offline   Reply With Quote
Old 01-17-2019, 06:50 PM   #3
Nothing.
why? (03-09-2019)
Old 01-17-2019, 06:50 PM   #4
Nothing.
Old 01-17-2019, 06:58 PM   #5
Brink
Drives: 2017 BRZ
Turbo.
Brink is offline   Reply With Quote
The Following User Says Thank You to Brink For This Useful Post:
olsonpg (01-23-2019)
Old 01-17-2019, 07:03 PM   #6
jacjac3
jacjac3's Avatar
Drives: WRB BRZ
My dealer refused to do any additional work. This is Steven creek subaru in NorCal. They first said yes, but on the actual day, they refused to do it and wanted to charge full labor. Doesn’t make sense. They just hate me. Oh well.
jacjac3 is offline   Reply With Quote
Old 01-18-2019, 01:59 AM   #7
pasternak
Nothing.
Not an opportune time to replace the spark plugs?
The Following User Says Thank You to pasternak For This Useful Post:
humfrz (01-18-2019)
Old 01-18-2019, 02:08 AM   #8
djrbash
Drives: BRZ Premium GBS
does anyone know if a coolant flush is done with the valve spring recall?
djrbash is offline   Reply With Quote
Old 01-18-2019, 06:50 AM   #9
Coolant is listed in the parts. Doubt they do an actual flush though. They will just drain out what they need and then replace it.
Dadhawk (01-18-2019)
Old 01-18-2019, 07:25 AM   #10
tobin
tobin's Avatar
Drives: '13 BRZ
What about swapping over to the revised throw-out bearing design?
tobin is offline   Reply With Quote
Old 01-18-2019, 07:26 AM   #11
Then I wouldn't have left the car. I realize you may only have so many choices with a Subaru (fewer dealers) but from a customer prospective that makes no sense.
Old 01-18-2019, 09:24 AM   #12
ka-t_240
#1 Plugs
#2 Throw out bearing/clutch
#3 Address any other leaks you may have on the car
#4 Does car need other maintenance? Trans or Diff fluid, Alignment, brake flush, etc. Great time to get it done as you will be at the dealer and have a loaner.
#5 Motor Mounts?
ka-t_240 is offline   Reply With Quote
The Following 5 Users Say Thank You to ka-t_240 For This Useful Post:
Blu-by-U (03-09-2019), DarkPira7e (01-18-2019), slizoth (01-18-2019), swfrs (01-18-2019), tobin (01-18-2019)
Old 01-18-2019, 10:31 AM   #13
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
As I posted in the other recall threads, they're doing my plugs and clutch assembly. Charging me a half hour of labor for clutch, no labor on plugs. Priced plugs at $8-10 a piece which is very fair. They even asked if I had a preferred oil weight and what expected capacity is with my oil cooler installed
Old 01-18-2019, 11:17 AM   #14
The OP's question was "more than spark plugs".
That's the reason I said "nothing" - (nothing, more than spark plugs).
Is this a test to see whether or not ol humfrz is payen attention?
As Willie would say - "after taking several readings, I think my mind is fairly sound".
Now, my body is shot - but, that's not what were talkin about - was it? -
2013 Valve Spring recall - modified (FI) engine thread shiumai Forced Induction 71 08-11-2020 06:21 PM
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-08-2019 11:38 PM
valve spring recall-engine oil leak TYinhouse Issues | Warranty | Recalls / TSB 13 01-17-2019 11:09 AM
I have the valve spring recall information. meadowz06 Issues | Warranty | Recalls / TSB 24 12-23-2018 08:44 PM
