Old 01-15-2019, 01:41 PM   #1
InstaGib
Drives: 2015 Scion FR-S || Raven Black
Question OFT Tunes - V4 uses the same tune for both EL and UEL header designs?
I've been doing quite a bit of reading leading up to the spring, when I plan to do summer tires + alignment + brakes + Tomei UEL headers + OFT tune. Now I understand that the V4 tunes use the same tune for both EL and UEL headers, but my question is why/how?
In the past these were broken out into separate tunes, which makes more sense to me as wouldn't the exhaust valve timing be different? I've also read that V4 suffers from worse fuel economy, so now I'm wondering if I should just stick to the V2 tunes, or if there's just something I'm not understanding here.
I've tried to search for some info related to this, but I'm having some trouble digging through posts, so please feel free to redirect me if this has been discussed in detail before.
InstaGib is offline   Reply With Quote
Old 01-15-2019, 04:58 PM   #2
steve99
Drives: FT86
Yes you could use older v2 tunes
Old 01-17-2019, 11:20 AM   #3
InstaGib
Sure, I understand that, but why the change at all? If the tunes could have been the same between header designs without performance/reliability concerns, then why were they originally split into EL/UEL specific tunes?
Sent from my Pixel 2 using Tapatalk
Old 01-17-2019, 11:49 AM   #4
tomm.brz
Drives: brz 2017 hksv2
i think v4 are mostly tuned for OFH uel header
if you use them with other headers is mostly a compromise
Old 01-17-2019, 11:54 AM   #5
InstaGib
Do you have a source for that? This is the first time I've heard of this, and I can't even find anywhere to buy the Open flash Header any more.
Old 01-17-2019, 02:00 PM   #6
tomm.brz
mostly because the cam timings for. v4 are identical to the OFH v2 tunes Shiv released time ago
Old 01-18-2019, 12:32 AM   #7
steve99
Drives: FT86
their is some advantage having specific cam timings for each type of header, but the difference is not great unless you have very different design header like ace or p-tuning
saves time not having many different tunes for little advantage
Old 01-18-2019, 07:47 AM   #8
InstaGib
Okay, that's kind of what I suspected then, thanks.
Are there changelogs or anything like that, that I can read over?
Old 01-18-2019, 08:06 AM   #9
steve99
Drives: FT86
The older v2 tunes came with a readme file but not the V 4 only jnfo will be on the openflash support website or compare v4 tune to stock rom in romraider to see changes
Old 03-15-2020, 11:18 AM   #10
thornad
Drives: 2016 GT86 N/A
EL header
I've got a TOMEI EL header, and using OFT v4.3 Stage 2+ at the moment, but from what I read on the forums, it seems the v4 Stage 2 has the AVCS of v2 EL tune, while Stage 2+ is closer to v2 UEL AVCS.
The only difference in v4 between Stage 2 and Stage 2+ seems to be the AVCS and Primary Open Loop Fueling tables.
So, for a decat EL header would it make sense to use Stage 2+ (which is for decat ) but with the Stage 2 AVCS ? Or same thing, the Stage 2 tune (EL) with the Stage 2+ POLF table (decat) ?
thornad is offline   Reply With Quote
Old 03-15-2020, 01:51 PM   #11
tomm.brz
try EL cam timings from stg2 V2
they work good
thornad (03-20-2020)
Old 08-30-2021, 10:59 AM   #12
NicFromTheNorth
Drives: Subaru BRZ 2016
@thornad, which AVCS tables did you end up using?
NicFromTheNorth is offline   Reply With Quote
Old 08-30-2021, 11:52 AM   #13
J95
J95's Avatar
they work good
Do you mean stage 2 works better than 2+ for EL decat headers? I have some EL 4 2 1
J95 is offline   Reply With Quote
Old 08-31-2021, 09:54 AM   #14
thornad
I got a Wayne tune eventually, but I did try the v2 EL AVCS tables and liked them better than v4 (everything else was v4).
The Following User Says Thank You to thornad For This Useful Post:
J95 (08-31-2021)
Header/Tune Decision Jakinit Engine, Exhaust, Transmission 50 01-15-2019 10:50 PM
UEL HEADER W/o tune turtlefeeder Engine, Exhaust, Transmission 10 11-29-2016 04:46 AM
Header without a tune eddiev116 Engine, Exhaust, Transmission 73 02-07-2015 07:01 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 11:34 PM
FI or Tune and Header? RSH Engine, Exhaust, Transmission 30 10-23-2013 06:09 PM
