Old 01-14-2019, 12:58 PM   #1
stlgrym3
sway bars recommendation for canyon runs
do we better off getting the front and rear or just the rear sway bar? any particular brand for recommendation? thicker or narrower bars, which ones better?
stlgrym3 is offline   Reply With Quote
Old 01-14-2019, 01:15 PM   #2
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
just the front, from an autoX perspective. we have a few people with rears also but we do not see a time difference from it. I have a whiteline adjustable 22mm front
G-Man is offline   Reply With Quote
Old 01-14-2019, 01:26 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I installed Perrin front and rear. I ordered them over whiteline, because the Perrin bars have the bushing coller welded to the bar.
Can't give feedback on the sways, as I installed too many parts at the same time.
I LIKE TIRES!
Old 01-14-2019, 01:29 PM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
How about asking not "which swaybar", but IF and how YOU want to change current handling, in what way, and to what extent.
Different drivers have different handling preferences and you should better ask what change you want to achieve, not just buying and installing suspension parts because internet says so, that different drivers bought & installed in theirs some.
The Following 7 Users Say Thank You to churchx For This Useful Post:
Captain Snooze (01-15-2019), cjd (01-15-2019), finch1750 (01-15-2019), G-Man (01-14-2019), kch (01-15-2019), strat61caster (01-14-2019), wparsons (01-17-2019)
Old 01-14-2019, 01:33 PM   #5
PuslarBrrrz
I went with a Progress front bar 70% stiffness increase over stock, which was about the most mild one I could find. Zero complains, I wanted less roll and a bit more stability on corner exit and that's what I got.
PuslarBrrrz is offline   Reply With Quote
Old 01-14-2019, 01:41 PM   #6
stlgrym3
basically less body roll, but i guess every sway bar does that. when i had my Lexus IS350 i was told to only install the rear sway bar as the front does nothing for handling, but now i'm hearing the opposite for the 86.
Old 01-14-2019, 02:33 PM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
Less body roll .. but also it will make suspension less independent and thus will rob some grip. I'd say if roll is only thing you want to change/reduce, then to proportionally change to stiffer/thicker both swaybars, so to not shift grip bias by reducing grip on only one end. Or to not bother about changing swaybars at all, if you will change also other things, eg. installing coilovers with higher spring rates .. maybe reduced roll due that too will be sufficient even with stock swaybars?
Leonardo (01-14-2019), wparsons (01-17-2019)
Old 01-14-2019, 02:58 PM   #8
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Change the stock front end camber to negative. Sway bars can affect handling in a negative way, You don't get something for nothing. There really is no reason to mess with things. Until you have a better idea of what you want to achieve I'd wait.
TommyW is offline   Reply With Quote
Old 01-14-2019, 09:39 PM   #9
norcalpb
norcalpb's Avatar
I personally like a stiffer front bar for auto x and stiffer rear bar on the track.
It seems you have a 2017 so you have a 18/16mm sway bar setup (140lbs front/180lbs rear) which feels nice with stock camber but can sometimes become too much if you start adding front camber. I personally believe the 16mm bar is to compensate for soft springs, but if you want to keep the stock springs keep the 16mm rear bar.
If you are just going fast in the canyons I would upgrade one side only but don’t over do it on the size. Too big of sway bars will make the car super rough on bumps as each strut/shock assembly can’t act as independently as stock. As a reference a 22mm bar is 3x stiffer than an 18mm. 20mm solid front is the biggest I’d run on the street, with 19mm being preferable.
Old 01-14-2019, 10:18 PM   #10
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
I know you're just providing a general guideline, but I'd like to clarify for anyone reading that an increase in diameter does not equal a proportional increase in stiffness. Always check the stiffness quoted by the manufacture when choosing a bar, instead of basing it of mm of diameter. Stiffness is determined by a multitude of things in addition to overall diameter, including thickness of bar inner wall, metal composition, spring shape (blade vs. tube) and the number and angle of bends in the bar from side to side. Specs can vary wildly for this reason, even among bars that appear identical, so again always check the manufactures specs.
BlueWhelan is offline   Reply With Quote
The Following User Says Thank You to BlueWhelan For This Useful Post:
Old 01-15-2019, 03:13 AM   #11
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
You say body roll like it's a bad thing.
Are you trying to modify the steering? That is, less/more under-steer/over-steer?
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
cjd (01-15-2019), wparsons (01-17-2019)
Old 01-15-2019, 08:56 AM   #12
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
If you like the way the car feels now and just want to reduce lean in corners, then get a matched set so you don't change the roll stiffness bias. Adding a larger bar to only one (either) end of the car will totally change the cornering dynamics.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following User Says Thank You to venturaII For This Useful Post:
nikitopo (01-15-2019)
Old 01-15-2019, 09:18 AM   #13
ZDan
ZDan's Avatar
Drives: '23 BRZ
IMO, negative camber up front (bolts or plates) + lowering springs (careful here, combined with plates can rob too much bump travel) >> stiffer sway(s)
Old 01-15-2019, 09:45 AM   #14
TommyW
TommyW's Avatar
This
FS: Cusco Strut Bars and Power Braces, Hotchkis Sway bars armyoffoo Brakes, Suspension, Chassis 10 08-08-2018 08:28 AM
WTB F&R sway bars blkmamba Canada Classifieds 1 06-04-2017 02:15 PM
FR-S stock sway bars compared to TRD bars babydriver Scion FR-S / Toyota 86 GT86 General Forum 3 12-01-2014 09:12 PM
brz and fr-s sway bars different? 1010110 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-03-2013 01:43 AM
FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! NJA Brakes, Suspension, Chassis 18 04-07-2013 06:00 PM
