Old 01-02-2019, 11:37 PM   #1
Pillow142
Pillow142's Avatar
Drives: '18 86 (Asphalt)
Front Tow Hook mounting threads
I just got a front license plate tow hook relocation kit. However, it doesn't seem to thread right. It feels like it's threading in, but I can easily pull it out. To check this, I also screwed in the tow hook that came with the car. It also wiggles a little bit and is easily pulled out. Am I just not screwing it in correctly? or is the threading in the car's front tow hook receiver defective?
Pillow142 is offline   Reply With Quote
Old 01-02-2019, 11:42 PM   #2
Brink
Drives: 2017 BRZ
Which kit did you get? I got the kit from Grimmspeed and it's completely solid. Maybe you got a kit for a different car that doesn't have the right threading?
Brink is offline   Reply With Quote
Old 01-03-2019, 12:41 AM   #3
Pillow142
Pillow142's Avatar
I got the TurboXS kit. I got it because it fits the 17+ 86 bumper. http://www.ft86speedfactory.com/turb...2013-ft86.html
But also the tow hook that came with the car in the trunk doesnt seem to thread correctly, I can pull it off easily. I dont know if its the threading or i'm not screwing it in correctly.
Old 01-03-2019, 01:12 AM   #4
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
try putting the tow hook in one of the rear mounts and see if it screws in correctly.
fx1mark is offline   Reply With Quote
Old 01-03-2019, 01:39 AM   #5
schmitty.jaegermj
Drives: 2019 Toyota 86
Youre just not aligning it properly. I installed one a couple a days ago and had exact same issue, took me damn 20 minutes to figure out hoe to thread it in properly. If it helps, from the way I was trying to thread it in (you might be doing it differently/at a different angle) I had to very slightly change angle so the non-threaded end moved towards the center of car (my right ). Just keep trying until it doesnt come out when you pull on it. Finish up tightening with a wrench
Sent from my LM-Q610(FGN) using Tapatalk
schmitty.jaegermj is offline   Reply With Quote
Old 01-10-2019, 01:53 PM   #6
R_E_L
He's got this.
R_E_L's Avatar
Drives: 50th Anni BRZ
Exclamation Having problems with Perrin relocation kit
I'm having issues with my Perrin relocation kit. It felt like it went in correctly and I was able to make it hand tight. The problem is the instructions say to tighten it to 50 ft-lbs, I used my torque wrench but it would not get any tighter, it just kept spinning with the same resistance. I have I done something wrong?
It felt secure enough so I attached the plate but now I can use the plate to spin the whole assembly.
Don't worry, I'm certified... promise.
R_E_L is offline   Reply With Quote
Old 01-10-2019, 02:04 PM   #7
schmitty.jaegermj
Try pulling it out with force. I dont think you have threaded it in, it shouldnt spin continuously
Old 01-10-2019, 07:13 PM   #8
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Its stripped
Dr. BRZ is offline   Reply With Quote
Old 01-10-2019, 07:37 PM   #9
Grady
Grady's Avatar
Righty tighty, Lefty loosey
Old 01-12-2019, 02:12 PM   #10
R_E_L
He's got this.
R_E_L's Avatar
Well it seems like I just didn't realize how many times I had to spin the thing. Removed it, threads were ok, tried the stock toe hitch, that went in fine and tightened (much sooner I might add), reinstalled the perrin piece and kept spinning with no increase in resistance until... it stopped. Guess I am less inclined to car maintenance than I throught.
The Following User Says Thank You to R_E_L For This Useful Post:
bcj (01-12-2019)
tow hook
DIY: Center Mounting the Front License Plate WITHOUT DRILLING Neurytic DIY (Do-It-Yourself) Guides 28 05-14-2018 05:37 PM
WTB: Need front seatbelt lower mounting hardware skylinekin Want-To-Buy Requests 0 04-02-2018 06:33 PM
FS: Front Tow Hook plus front and rear covers imartisfrs Exterior Parts (Aero, Lighting, Etc.) 8 08-05-2015 04:15 PM
How are you guys mounting front license plates? SubaSteveDDS Cosmetic Modification (Interior/Exterior/Lighting) 19 07-30-2015 08:07 PM
APR Front splitter, mounting? mrk1 Cosmetic Modification (Interior/Exterior/Lighting) 0 03-26-2014 11:58 PM
