#29 |
Drives: 2015 Scion FR-S
i have a 2015 on a stock battery. it's not my DD and I noticed the past couple weeks its taking an extra second or 2 to start. I figured the batt is on the way out and have started looking at braille batteries
#30 | |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Both my motorcycles get plugged in for the winter.
"I gotta rock." -- Charley Brown |
#31 |
#32 |
My Monogram is still on the original battery. Almost 5 years now. I'm pretty impressed.
| The Following User Says Thank You to funwheeldrive For This Useful Post: | eastendraceshop (01-08-2019) |
#33 |
Drives: FRS 2013
#34 |
UPDATE:
Waited 24-30 hours for the Battery Tender to fully charge the battery. Reinstalled battery into FR-S. Started up just fine. No stuttering before it fires up. Then I made a short trip to the grocery store, another short trip to the car wash, and then a longer trip to another grocery store. Each time I started the car, it was fine. MISSION ACCOMPLISHED! Thanks to those in this thread who made great suggestions!
#35 |
Mentat
Drives: 2013 Scion FRS 6MT
Mine lasted for almost 4 years. I used battery charger almost everyday in the winter when it was on its last leg.
#36 |
Still on my original battery from 2012. Noticed degraded performance last year, but still works fine. Waiting for this one to bite the dust so I can replace it with a nice lightweight one.
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | e_lunatic (01-10-2019) |
#37 |
The 2 things that reduce battery life is high temperature and sitting in a discharged state. If you car sits on the lot a long time and the battery sits dead. The dealer will charge it back up but it will not last as long. Cold does not hurt a battery (unless it is discharged and freezes) but it will let you know that you have a weak battery.
#38 | |
friendly
Drives: 17' 86
VW jetta replaced at a year. I think the time you got out of yours is good/on target.
Seek comfort in discomfort.
#39 |
Feeling like thinking....
My 2013, manufacture date 07/12, just got its valve spring recall notice a few days ago, but the original battery is still doing its job... so I guess the battery is tougher than the springs. Go figure.
Northeast US, lots of winter driving, alternately garaged and parked outside, very varied usage including being parked for several days and short trips, then occasional very long trips.Never needed to charge battery, but it does turn over slower after sitting more than two days.
Drive like everyone's life around you depends on it...
| The Following User Says Thank You to MuseChaser For This Useful Post: | ToySub1946 (01-10-2019) |
#40 |
Drives: 2013 Ultramarine FRS
My FRS was originally bought in Oct 2013. Replaced the battery last month with an Autozone Duralast battery. Mine hadn't given me any trouble yet, but I had Autozone test it anyway and it was done
#41 |
Drives: Scion FR-S Series 10 #2462
Just had to replace my OEM Panasonic battery from 2013. Worked great and then started to just slow crank until the last day when it just barely started the car. Drove straight to O'Reillys and picked up a new one. My problem is a lot of "short trips" like moving the car out of the driveway, etc. Trips too short to recharge the battery after a cold crank.
#42 |
Drives: 2016 Subaru BRZ
I had an oem battery go for 8 years, 5 in the Florida heat. If you maintain it like you're supposed to they will last a long time. You have to check your fluid levels, also helps to throw it on a charger(with desulfator) every other month. Going on 3 years next month with my OEM battery in the BRZ, all SWFL.
| The Following User Says Thank You to Trueweltall For This Useful Post: | MJones_RB (01-14-2019) |
| Stock Shock Lifespan | TommyW | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 03-06-2017 12:07 PM |
| LCA Spherical Bushing lifespan. | x808drifter | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 05-14-2016 02:50 AM |
| Stock Suspension Lifespan? | smg1138 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 03-18-2015 01:19 AM |
| Rear brake pad lifespan | ddeflyer | Tracking / Autocross / HPDE / Drifting | 21 | 07-16-2014 02:15 AM |
| Weak battery or bad alternator from factory? | empower-auto | Issues | Warranty | Recalls / TSB | 2 | 09-21-2012 03:17 PM |
