Old 01-08-2019, 10:26 AM   #1
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Bumper countermeasure SB18-200E - SUBARU RECOGNIZES
..and after 5 years Subaru recognizes damned front bumper issue ABOUT gap!
JAPAN PRICE IS JPY 546 EACH - USD 5.10 - EUR 4,37 (see invoice)
Buy 57722CA030 PLATE BMPR SD
Trap63 is offline   Reply With Quote
The Following 16 Users Say Thank You to Trap63 For This Useful Post:
bcj (01-08-2019), beltax90 (07-04-2021), Bonburner (04-21-2019), BriRZed (09-24-2021), chaoskaze (01-23-2019), churchx (09-03-2019), humfrz (01-08-2019), JesseG (05-02-2020), KL (01-08-2019), nikitopo (01-11-2019), sato (01-08-2019), Sportsguy83 (01-09-2019), TofuJoe (05-17-2019), Tristor (04-14-2019), Ultramaroon (01-10-2019), ZionsWrath (01-11-2019)
Old 01-08-2019, 11:25 AM   #2
xjohnx
Grip>Slip
xjohnx's Avatar
any idea when the part will be available to order? 57722CA030
Old 01-08-2019, 11:27 AM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Isn't there already an aftermarket company that sells these?
Current DD: M235i
8RZ is offline   Reply With Quote
Old 01-08-2019, 12:02 PM   #4
Gunman
Drives: 2019 Mazda Miata RF
Part looks a bit different.
The Following User Says Thank You to Gunman For This Useful Post:
Trap63 (01-08-2019)
Old 01-09-2019, 07:31 AM   #5
Trap63
Trap63's Avatar
sent a WA message to JP Carparts in Japan to request availability and $ in Japan.
Old 01-09-2019, 08:49 AM   #6
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
The aftermaket company stopped selling their own part and now they are selling a revision which is much more difficult to install.
Subaru's part looks much better.
The Following User Says Thank You to nikitopo For This Useful Post:
sato (01-09-2019)
Old 01-09-2019, 09:35 AM   #7
sato
sato's Avatar
Drives: Dodge Patitas
Yup, there is another thread on that part but don't have the link right now. Problem with the Subaru part is zero availability ATM.
Sent from my Pixel 2 using Tapatalk
sato is offline   Reply With Quote
Old 01-09-2019, 10:23 AM   #8
Grady
Grady's Avatar
This SB was issued in December. Just wait a couple months those parts will be in stock at every dealer. Parts are almost never available at the release of a SB.
The Following 2 Users Say Thank You to Grady For This Useful Post:
nikitopo (01-09-2019), sato (01-09-2019)
Old 01-10-2019, 06:38 AM   #9
Eazy-V
I assume this would also work on the FRS?
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73
1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress)
2023 Chevrolet Corvette Z51 Stock
Eazy-V is offline   Reply With Quote
The Following User Says Thank You to Eazy-V For This Useful Post:
JesseG (05-02-2020)
Old 01-10-2019, 02:19 PM   #10
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
With this being a service bulletin and my car needing the recall should I just ask to fix during the recall ?
mswbrz is offline   Reply With Quote
Old 01-10-2019, 05:16 PM   #11
Grady
Grady's Avatar
I do not recall?
Old 01-10-2019, 06:21 PM   #12
maslin
Benz Tech
Drives: 2017 BRZ Premium
Generally, a Bulletin is an update or guidance for a known issue, updated part, updated procedure, etc. It does not extend any additional warranty on top of your normal warranty.
A recall would be work performed under warranty regardless of the vehicles age or mileage.
A car may have 2 or 3 recalls, there are hundreds of bulletins that could apply to the same car.
maslin is offline   Reply With Quote
The Following User Says Thank You to maslin For This Useful Post:
Opie (05-05-2020)
Old 01-11-2019, 04:07 AM   #13
Trap63
Trap63's Avatar
updated post #1 about Japan price.
The Following User Says Thank You to Trap63 For This Useful Post:
Old 01-11-2019, 05:56 AM   #14
ZionsWrath
Thanks
ZionsWrath's Avatar
This would be a bumper to bumper (no pun) issue. If you are not under the 3/36 you will be out of luck. If you have an extended warranty you might get it fixed depending on your contract.
Service bulletins are not recalls. Generally the way it works is you complain about issue and they will verify the issue and refer to service bulletin for repair procedure. If you go in and say hey there is a service bulletin I want this, they won't do it. We are lucky we have the internet and easy access to service bulletins because in my experience dealers are very secretive about them for some reason.
The Following 2 Users Say Thank You to ZionsWrath For This Useful Post:
slizoth (01-18-2019), Trap63 (01-11-2019)
57722ca060 plate bmpr sd, brz, subaru, zc6
DIY - Color Code of ID plate and code of part (SUBARU) - SB18-091 Trap63 DIY (Do-It-Yourself) Guides 0 06-14-2018 04:52 AM
SB17-067 Leakage countermeasure for VALVE ASSY OIL CTRL 2013-2017 Trap63 Issues | Warranty | Recalls / TSB 10 06-03-2018 11:33 PM
SB18-077 *BRZ ALL, Flywheel assy and ball bearing Trap63 Issues | Warranty | Recalls / TSB 0 05-29-2018 03:26 AM
Someone recognizes this rear spoiler? pepe Cosmetic Modification (Interior/Exterior/Lighting) 13 08-12-2016 05:57 AM
USB flash drive for mp3's, only recognizes 61 songs per folder? Suparu Electronics | Audio | NAV | Infotainment 6 08-22-2015 02:15 PM
