Old 01-07-2019, 05:44 PM   #1
raz.sofer
raz.sofer's Avatar
Drives: Subaru BRZ 2015
EL Headers “plug and play”
EL Headers (any) - are they “plug and play”? Are just some of them easy to install at home? If not what do I need to do in order to fit them to the stock exhaust? Looking to get the HKS with catalyzer. If there is anything better that doesn’t require a tune I’m open for suggestions. Not looking to upgrade the whole exhaust system right now.
raz.sofer is offline   Reply With Quote
Old 01-07-2019, 06:11 PM   #2
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
They're all easy and able to be installed at home. 8 bolts and 3 gaskets iirc. Literally all you gotta do is take all those bolts off, replace headers, replace gaskets (use new gaskets) and tighten nuts and bolts. Then tune for it and listen to the sweet music that comes out the ass of your car.
@KingJon1991 fixed with new gaskets
Sent from my ONEPLUS A6013 using Tapatalk
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
The Following User Says Thank You to Strife26 For This Useful Post:
raz.sofer (01-07-2019)
Old 01-07-2019, 06:38 PM   #3
KingJon1991
Drives: scion frs 2015
took me about 30 mins to do make sure you have new gaskets
KingJon1991 is offline   Reply With Quote
The Following 2 Users Say Thank You to KingJon1991 For This Useful Post:
raz.sofer (01-07-2019), Strife26 (01-07-2019)
Old 01-07-2019, 07:13 PM   #4
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
Originally Posted by Strife26 View Post
They're all easy and able to be installed at home. 8 bolts and 3 gaskets iirc. Literally all you gotta do is take all those bolts off, replace headers, replace gaskets and tighten nuts and bolts. Then tune for it and listen to the sweet music that comes out the ass of your car.
+1 The installation is very easy and straightforward!
You will definitely need a tune with an aftermarket header.
eastendraceshop is offline   Reply With Quote
The Following 2 Users Say Thank You to eastendraceshop For This Useful Post:
Old 01-07-2019, 08:12 PM   #5
raz.sofer
raz.sofer's Avatar
Thank you everybody! Is there anything that doesn't require a tune? I can deal with a check engine light but not performance problems. My car is still under warranty and I don't want to void it
Does the greemspeed gasket will fit the HKS headers?
Old 01-07-2019, 08:15 PM   #6
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
Everyone is looking out for your best interest when they tell you to tune it. Most of the catted headers that people run end up throwing a cel at some point anyway.
MCTeeJ is offline   Reply With Quote
The Following User Says Thank You to MCTeeJ For This Useful Post:
eastendraceshop (01-07-2019)
Old 01-07-2019, 08:46 PM   #7
raz.sofer
raz.sofer's Avatar
I'm kinda scared about the warranty, I have like a year and a half left for it and if something will happen to the car it can get very expensive in israel
The real question is if I can drive without a tune and just ignore the cel or will it affect the performance instead of making it better.
Beautiful car btw!
The Following User Says Thank You to raz.sofer For This Useful Post:
MCTeeJ (01-08-2019)
Old 01-07-2019, 08:50 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
Installing catless header has great chance for cat readiness CEL after a time to pop-up, unless those checks are disabled in tune. Not killing thing though, as it will only mean that cruise control will be disabled.
Old 01-07-2019, 08:52 PM   #9
raz.sofer
raz.sofer's Avatar
Going catless is kind of a problem since we have very very hard emission rules here so my only option is to compensate for catalyzed headers
Old 01-07-2019, 09:09 PM   #10
86TOYO2k17
Drives: 2017 toyota 86
Dealership can not tell if you have ever tuned your car as long as you flash back stock tune before taking it in. Same with header. Flashing back to stock tune takes only a few mins. Header swap might take 2-3hours the first times. But once you get it down 45min -1hour including jacking up car, cleaning up etc. otherwise a catted header by itself will have very minimal gains.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Old 01-07-2019, 09:12 PM   #11
raz.sofer
raz.sofer's Avatar
So if I get an OFT and flash the ecu back and forth they wouldn’t know? Sounds awesome.
Headers here does not void the warranty (well they do but the mechanics at the dealership don’t know anything about these cars because they do not get them a lot. we only have 150 brzs in the country) the only thing I need to worry about is if I flash the ecu back to stock and a cel pops up that they will check it
Old 01-07-2019, 09:41 PM   #12
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Don't mess with it.
end thread.
Old 01-07-2019, 09:46 PM   #13
raz.sofer
raz.sofer's Avatar
Originally Posted by x808drifter View Post
Don't mess with it.
end thread.
Well I will regret for asking.. Why not?
Old 01-07-2019, 10:22 PM   #14
Strife26
Strife26's Avatar
Grimmspeed has gaskets for the whole exhaust AFAIK, and more.
I just got the header gaskets for $23 on Amazon. I also got the 3inch, but it was the wrong size for headers (my turbo exhaust is 3" so mistakenly got 3"). I believe you just need a 2.5" gasket for headers to downpipe or whatever they are calling thing connecting the headers to front pipe. You also need header gaskets, just Google brz grimmspeed header gaskets and you'll find em easy.
Not tuning it may decrease performance as it will likely alter the afr, etc depending on the design vs stock. I'm a car newb still, but I know you need to tune for most upgrades done to the engine.
MCTeeJ (01-08-2019)
V8 plug and play ECU smudge Engine Swaps 7 02-04-2018 02:23 PM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 10:53 AM
ECU Plug and Play Mo707 Engine, Exhaust, Transmission 8 08-26-2012 11:21 AM
HID Plug 'n Play Kit JW89225 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 07-31-2012 12:17 AM
Which hid plug n play kit? huma Cosmetic Modification (Interior/Exterior/Lighting) 11 07-20-2012 11:10 PM
