Old 01-07-2019, 11:28 AM   #15
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by Jpembry View Post
That’s the setup I was looking at.. +35.. Fitment on this car is proving pretty tricky especially if you want to stay with an 8” wheel
17x8 +53 to +15 offset will work.
Op, those are nice looking wheels. Fairly light weight too. Good choice!
I LIKE TIRES!
Old 01-07-2019, 11:40 AM   #16
Jpembry
Drives: 2019 Subaru BRZ Series.Gray
Yes, I’m aware which is why I’m trying to figure out if they’ll clear the PP brakes! I didn’t realize that the OP’s post was specific to the +45, but I’m looking to go with a wheel in the 17x8 et30-35 range
Jpembry is offline   Reply With Quote
Old 01-07-2019, 12:13 PM   #17
86TOYO2k17
Drives: 2017 toyota 86
I have the advanti 17x8 +35 in black with 225/45r17 tires. The top of the tire is perfectly flush with fender zero poke at all, the very bottom of tire has slight poke maybe 3/4” Gives the car a nice wide stance but not too extreme. Should be 30mm wider overal.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
SuperTom (01-07-2019)
Old 01-07-2019, 07:51 PM   #18
Jpembry
Thanks for all of the suggestions! as I’ve mentioned the real limiting factor is brake clearance, so I will have to go with something that has proven clearance.
Old 01-07-2019, 08:22 PM   #19
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
That's a great looking wheel set up!
eastendraceshop is offline   Reply With Quote
Old 01-07-2019, 09:16 PM   #20
86TOYO2k17
As far as fitment I couldn’t tell you from personal experience, but a bbk that fits in pretty much any 17x8 +35 or more offset should fit on this rim. Nothing “weird” poking, sticking, bending in/out. Spokes are pretty straight and about as thin as can be made.
In fact I just measured stock rotor clearance for you. From rotor face to closest point of inside spoke is about 2.75” and from outside edge of rotor to inside rim is about 2.15” closest point of caliber to spoke is 1.5” so if you know stock caliber/rotor compared to whatever BBK your looking at should beable to tell.
As long as new caliber is less then 1.15” thicker, and new rotor is less then 4” bigger diameter. It should have plenty of clearance.
Old 01-07-2019, 09:29 PM   #21
Jpembry
Cool, thank you, I appreciate it!
Old 01-11-2019, 12:41 PM   #22
JDM4E
Drives: Honda Accord Euro
@86TOYO2k17 Would you be that kind a post some photos of that setup? I want them in 17x8+45 in black but I am hesitant since I never seen them. The OPs photos due to angles does not look as good as I hoped.
JDM4E is offline   Reply With Quote
Old 01-16-2019, 10:45 AM   #23
86TOYO2k17
Sorry, never notified me of post.
This is an older pic, if weather and time permits I might be able to take another at different angle if you like.
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
eastendraceshop (01-16-2019), JDM4E (01-16-2019)
Old 01-16-2019, 01:38 PM   #24
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
So are they +35 or +45? They look fairly flush but your car isn't lowered so hard to tell.
SuperTom is offline   Reply With Quote
Old 01-16-2019, 03:08 PM   #25
JDM4E
Thanks. Do you have 225/45 tires? Do the rims have a bit of concavity or are they totally flat face? Can you make a photo in aligement from front the car to see the poke/inset? Thank you again ))
Old 01-16-2019, 03:08 PM   #26
JDM4E
Se said +35
The Following User Says Thank You to JDM4E For This Useful Post:
SuperTom (01-16-2019)
Old 01-16-2019, 03:27 PM   #27
86TOYO2k17
Yes 17x8 +35 offset 225/45r17 wheels.
They have very slight concave maybe 1/4” at the very center but not much. Few more pics I just took.
JDM4E (01-18-2019)
Old 01-16-2019, 08:15 PM   #28
Jpembry
Looks good! Thinking of going with the same setup this year. Wheels are on closeout right now at Tire rack FYI
Enkei RSF5 Hyper Silver vs Machined Silver? Nonexistent Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 06-14-2016 12:06 PM
New XXR 550 Hyper Silver 18x8.75 JoeBoxer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-14-2015 02:19 PM
Hyper silver or hyper black on raven frs? KingGT86 Scion FR-S / Toyota 86 GT86 General Forum 8 05-13-2015 05:06 PM
WTB: 18" Hyper Silver XXR 530's Shedd22 Wheels and Tires 0 04-02-2015 02:04 PM
Hyper Silver, Hyper Black, and SBC. Are they the same? Tainen Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 03-20-2014 12:50 AM
