#407 | |
2 - The important point here is to make sure that the clutch adequately disengages. Yes, setting the clutch pedal to match the brake pedal height seems to be ok. Make sure you have maybe 3 cm of extra travel to the floor.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Legend@wheels (01-05-2019) |
#408 | |
nenber
Sent from my SM-G960F using Tapatalk |
#409 |
3 cm from floor to clutch contact is where I personally feel adequate clutch disengagement. Others may prefer more decoupling. If that's the case, raise the pedal accordingly.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Legend@wheels (01-06-2019) |
#410 | |
nenber
So vague. Anyhow as long as i dont hear any noises and/or experiencing any gear grinding(more than usual *shitty boxes*)i guess im ok. Cheers. P.s going to order this week the part (aa111 and the washers). Will not remove the spring at all so i hope ill be pleasant with the the new cylinder alone. Sent from my SM-G960F using Tapatalk |
#411 | |
#412 |
nenber
#413 |
That spot should be about 3 cm from the floor. It can be more but shouldn't be less. It's a feel thing. I push my pedal all the way to the floor when I shift. Some others don't. Those people should adjust the pedal for more travel.
#414 |
nenber
Btw
How does it disconnect from the fork metal? Cuz i dont see any secure pin/bolt/nut between them -then i assume is just to push it out? Sent from my SM-G960F using Tapatalk |
#415 |
Pull the fork forward and see. No substitute for hands-on. ...but yes.
#416 |
nenber
Great tnx
#417 |
#418 | |
Drives: swp mt '14 brz premium
| The Following 4 Users Say Thank You to jcw99 For This Useful Post: |
#419 | |
I suggest that the spring rate is akin to seasoning to taste. Keep your stock parts so you can play around. I've driven all three and I like the MTEC. It just doesn't do that much for me in the context of the swapped cylinder. It's really quite a subjective topic.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | jcw99 (01-06-2019) |
#420 |
nenber
Well just done mine.
Definitely Nice one but cant say its earth and sky diff. In that price its worth it. Sent from my SM-G960F using Tapatalk |
| The Following User Says Thank You to Legend@wheels For This Useful Post: | Ultramaroon (01-08-2019) |
| Tags |
| clutch line, slave cylinder |
| Clutch Engagement Improved! | enjoyminutemaid | Engine, Exhaust, Transmission | 53 | 11-07-2018 06:31 PM |
| Can steering feel, tactility, be improved? Without sacrificing adjustability? | Trettiosjuan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 101 | 08-16-2016 08:14 PM |
| Aftermarket Clutch Master and Slave? | Yruyur | Engine, Exhaust, Transmission | 5 | 07-27-2013 10:22 AM |
| Hate the feel of the clutch | FRSGeek | Engine, Exhaust, Transmission | 18 | 07-10-2013 01:24 PM |
| Clutch feel? | Shit Luck | Engine, Exhaust, Transmission | 5 | 04-21-2013 05:32 PM |
