Old 12-30-2018, 06:05 AM   #1
Boris_Petrov
Drives: 2013 GT 86
Reliability on turbo 86
Hello guys, I have thought of puting a turbo on my 86 for a long time and I am keen on the FBM turbo kits. I want my car to be as reliable and as fast as possible. So what do you guys think is the best power range for a reliable turbo FA20 with swapped internals? I'm going to put 9:1 compression ratio pistons.
Any feedback would be really apreciated!
Sent from my SM-A520F using Tapatalk
Boris_Petrov is offline   Reply With Quote
Old 12-30-2018, 07:29 AM   #2
ggiddix
Drives: scion frs
Replace the con rods and you should be good. And keep the boost around 10
Sent from my SM-G965U using Tapatalk
ggiddix is offline   Reply With Quote
Old 12-30-2018, 07:54 AM   #3
Boris_Petrov
Drives: 2013 GT 86
This is for how much horspower?
Old 12-30-2018, 08:18 AM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Winter vacation huh?
Old 12-30-2018, 09:29 AM   #5
ggiddix
Drives: scion frs
About 275 to the wheel, anything above 300 you need to replace the clutch
Old 12-30-2018, 10:00 AM   #6
Grady
Grady's Avatar
Hello guys, I have thought of putting a turbo on my 86 for a long time and I am keen on the FBM turbo kits. I want my car to be as reliable and as fast as possible. So what do you guys think is the best power range for a reliable turbo FA20 with swapped internals? I'm going to put 9:1 compression ratio pistons.
Swapped internals and staying “reliable” around 300hp there is no need to drop the compression ratio. The clutch is easy to upgrade to handle the extra. The transmission then becomes your weak link. After that i beleive the rear shafts are next. Think of Reliabiliy, Horse power, and Cost as a triangle. Now you can only have 2 sides of the triangle. The car can be reliable in at high HP. You are just going to spend a lot.
Old 12-30-2018, 10:05 AM   #7
ggiddix
Drives: scion frs
The con rods have been found the weak link, as he said you do not need to lower compression. Really all depends on how much you want to spend. The trans wasn't built for big power
Old 12-30-2018, 10:29 AM   #8
DarkPira7e
DarkPira7e's Avatar
It may be worth noting also that aftermarket rods rarely fit factory pistons. Without personal experience, I don't want to recommend a rod that I -think- fits stock. I would love to hear from anyone who has successfully only replaced the rods and left everything else alone, but that seems too easy.
Old 12-30-2018, 10:46 AM   #9
ggiddix
Drives: scion frs
You can get aftermarket Pistons and still maintain 12 to 1 compression
Old 12-30-2018, 12:51 PM   #10
Boris_Petrov
Drives: 2013 GT 86
By trans you mean just the clutch or gearbox problems? Probably even twisting axiles?
The Following User Says Thank You to Boris_Petrov For This Useful Post:
ggiddix (12-30-2018)
Old 12-30-2018, 12:55 PM   #11
ggiddix
Drives: scion frs
Oh and don't forget the valve spring recall
Old 12-30-2018, 01:41 PM   #12
Boris_Petrov
Drives: 2013 GT 86
Isnt't this the Toyota valve spring replacement for 2012-2013 86es?
Old 12-30-2018, 01:42 PM   #13
ggiddix
Drives: scion frs
Yup well 2013-2016 they say. Mine is one of them
Old 01-01-2019, 05:24 PM   #14
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
When we rebuilt our dev car with steel rods I useed Carillo rods and modified them to fit the stock piston
just needs a chamfer adding to replicate the shape of the stock rod, it still leaves plenty of strap thickness for 8000rpm
Matt@Cosworth is offline   Reply With Quote
Turbo Reliability VS Supercharger reliability KGB Forced Induction 130 09-08-2015 09:55 AM
Turbo options/ reliability of Brz danoo Forced Induction 13 06-15-2015 09:26 PM
FI Reliability pheonixone Forced Induction 42 02-22-2015 12:51 PM
