Old 12-27-2018, 01:09 PM   #57
BertoFT
Drives: 13 FRS Firestorm
Originally Posted by PuslarBrrrz View Post
No K20 head? It was my understanding that all the 250Fwhp+ k24 swaps run the k20/k24 combo.
I remember seeing a Dyno that compared a k24a2 engine with a K20a head and k24a2 head. The results showed more torque with k24 head and more hp with k20 head. If the K20A head is sufficient for a reliable 9000rpm, then it's the route to go.
Sent from my SM-G9600 using Tapatalk
BertoFT is offline   Reply With Quote
Old 12-28-2018, 12:37 AM   #58
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
Subd
I will be going this route with a buddy of mine who tunes Honda's here in Montreal.
Scalzo is offline   Reply With Quote
Old 12-28-2018, 05:00 PM   #59
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
These are truly art!
Kheaderfinal by Brady Johnson, on Flickr
Pre Order is up : https://www.pureautomotiveperformanc...-frs-brz-gt86/
Pure Automotive is offline   Reply With Quote
The Following 7 Users Say Thank You to Pure Automotive For This Useful Post:
BatStig (12-31-2018), Draco_PR23 (01-08-2019), gtengr (12-28-2018), Irace86.2.0 (12-28-2018), Kodename47 (12-28-2018), surfwaxsmitty (01-02-2019), venturaII (12-30-2018)
Old 12-28-2018, 05:02 PM   #60
Pure Automotive
Here's a quick video showing out it mates up to FACTORY catback position!
https://www.facebook.com/SwapYour86/...63321160903109
The Following 4 Users Say Thank You to Pure Automotive For This Useful Post:
Irace86.2.0 (12-28-2018), Kodename47 (12-28-2018), PuslarBrrrz (12-28-2018), venturaII (01-01-2019)
Old 12-28-2018, 06:46 PM   #61
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
It would be nice to personally look at area under the curve more than just hearing about some peak numbers.
It would seem that a smaller displacement motor would naturally rev higher, so a smaller displacement head on a larger block would help that motor rev higher, but isn't it more about the block that will determine max rpms in this case and not the head? Shouldn't the larger stroke (higher piston speeds) determine the limit? If not, what is special about the K20A head? I'm a novice with understanding bench flowing heads or understanding fluid dynamics, but it seems that a head built for a smaller displacement motor would be restrictive at the top end if it was matted to a larger motor, even if it was designed to handle higher revs. If anything, a restricted/smaller head would make for more low end torque than allowing high flow for peak horsepower.
Am I completely off? Does the smaller head actually have better flow? If I remember correctly (it has been a while since I owned a MKIV Supra), the NA head flowed better than the TT head, but that may have been intentional to get the turbos spooling or something. Nevertheless, it demonstrates that a small head can outflow one for a larger or more powerful engine.
Old 12-28-2018, 08:27 PM   #62
gtengr
Drives: 2017 BRZ
Looking good. What kind of hp level and power band was the header designed for? Are tube lengths optimized or is it more of a swap header?
gtengr is offline   Reply With Quote
Old 12-31-2018, 04:12 AM   #63
PolishFrs13
building life
PolishFrs13's Avatar
Drives: Raven Black, 6MT
Just wanted to keep everyone updated on the K24 swap parts all in one place.
Swap Header development is moving along! This is a 1 7/8" Runner 4 to 1 with 3" V Band merge collector. We will be selling the header along with a mid pipe that mates your existing cat back! It will have the standard factory size 2.5" 2 bolt flange to mate up to the majority of standard FRS/BRZ cat back systems with little or no modification. All 304 stainless, made right here in Maryland USA, no subbing out overseas or junk metal!
Kheader2 by Brady Johnson, on Flickr
Kheader1 by Brady Johnson, on Flickr
Kheader3 by Brady Johnson, on Flickr
Kheader4 by Brady Johnson, on Flickr
Kheader5 by Brady Johnson, on Flickr
We are now stocked up on our K24 Engine mount kits. These mount are made for use with a K24 block and S2000 6 speed transmission. NO CUTTING THE TRANS TUNNEL! None, bolts up to factory mount bolt holes. We do not currently have a shifter solution for these but have already sold a couple sets to people who are fabbing them up. In stock on SwapYour86.com!
KMount by Brady Johnson, on Flickr
Stay Tuned for more!
Will you make a adapter for a intake manifold, or are you planning to run it with the F20 intake manifold,tb, etc ?
For everyone who is interested in this,
A adapter plate for the trans/motor will be needed
(adapter plate link) http://www.balladesports.com (they also have the flywheel for sale)
F2K clutch master flywheel
(flywheel link) http://www.clutchmasters.com/aluminu...eel-fw-k2f-al/
Also if you take a look at the Upper Radiator hose it will have very minimal room as its close to the firewall..will there be a fix for that ? maybe CNC a plate along with either AN fitting, or 90* welded on.
CORRECT me if im wrong on any of this information above
but overall still should be a fairly easy swap if you have fabrication skills.
Look forward to seeing a PNP for this.
PolishFrs13 is offline   Reply With Quote
Old 12-31-2018, 05:43 AM   #64
DIY
DIY's Avatar
Drives: BRZ, WRX
There are options to fix this, here is one I can think of for now.
https://kmiata.com/collections/plumb...r-coolant-neck
Follow me on Instagram: @brzdiy
My Build Thread
DIY is offline   Reply With Quote
The Following 2 Users Say Thank You to DIY For This Useful Post:
PolishFrs13 (12-31-2018), Pure Automotive (12-31-2018)
Old 12-31-2018, 06:43 AM   #65
PolishFrs13
building life
thanks, that might actually be perfect
Old 12-31-2018, 08:52 AM   #66
Pure Automotive
We looked at a lot of FWD dyno graphs when trying to design it. So kind of yes to both, yes it is a swap header but yes we did try to optimize it both in runner size and length. It's big enough to flow some bigger HP (300+) and the runners should be conducive to higher RPM flow. But to be 100% honest, as we have not actually put one together yet, it is a best guess until we test.
The Following User Says Thank You to Pure Automotive For This Useful Post:
gtengr (12-31-2018)
Old 12-31-2018, 09:52 PM   #67
PolishFrs13
building life
will there be a FI setup soon ?
Old 01-01-2019, 08:53 AM   #68
BertoFT
K-swapped and BOOSTED FRS with S2000 cluster. Looks sick.
He starts talking about the swap here:
Says he uses an AEM infinity ECU. No A/C, but has traction control. He doesn't mention ABS; I'm assuming it doesn't work. I also don't know if that's an AP1/AP2 cluster. AP2 clusters switched to CAN in 06.
The Following User Says Thank You to BertoFT For This Useful Post:
PolishFrs13 (01-01-2019)
Old 01-01-2019, 03:13 PM   #69
Irace86.2.0
I don't even see an ABS module or lines. Unless he relocated them and/or tucked them then he deleted the ABS.
Old 01-01-2019, 10:59 PM   #70
PolishFrs13
building life
something ill have to take a look at when im off work..
does he have a build thread on here ?
Pure Auto's Swap Compilation Thread - 2JZ and LSX ! Pure Automotive Engine Swaps 29 01-10-2018 01:20 AM
SwapYour86.Com Pure Automotive 2JZGTE Billet Intake Manifold For 2JZ FT86 Swap Pure Automotive Engine Swap 0 12-01-2017 11:57 AM
SwapYour86.Com Pure 2JZ MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 11:49 AM
SwapYour86.Com Pure LSX MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 11:23 AM
Pure Auto's 2JZ Swap Thread - The DRAGFRS Pure Automotive Engine Swaps 153 06-20-2016 06:33 PM
