#29 |
Drives: Panda FR-S
My battery just died and I have this issue. I had the car for 6 years so far and the mechanical key doesn't work. I turned so hard that the key started to twist. It's jammed. I had to enter from the trunk to get in the car.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
#30 |
The old style key hole in the door turns the opposite direction than you'd expect to unlock. I found this out the hard way when my doors were frozen shut last winter and almost bent the key before I thought to turn it the other way.
| The Following User Says Thank You to gravitylover For This Useful Post: | Brink (12-23-2018) |
#31 | |
Drives: Subaru BRZ
#32 |
That is because there is no mechanical activator. Even the "key" just throws a switch and activates a solenoid.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Cal3000 (12-23-2018), Ultramaroon (12-23-2018) |
#33 |
Drives: Panda FR-S
Wow, interesting. I did not know that. Might as well not have a key slot at all. What's the point if it's not fully mechanical? lol
#34 |
I forgot about that very important detail. Wow.
#35 |
That's kinda f'd up, turning a key should move mechanical bits not activate a solenoid. I had to go in through the trunk once when I couldn't open the doors enough to get in because a couple of brodozer guys thought it would be funny to park 2" away. It SUCKED
I made myself feel better though when I pulled 2 of the valve cores out of the stems on their 38" mudders after realizing they had no spare tires.
#36 | |
Drive From Home
Drives: BRZ STI Performance
BTW when I first got the car I tried the BRZ mechanical key on the door and trunk and it took some finesse but I eventually got it to work. The key will no longer bend after the initial try. It feels mechanical to me. Are you guys sure it's just a solenoid? The inside door lock pulls 2 cables as I've taken the door cards off before to see that. |
| The Following 2 Users Say Thank You to krayzie For This Useful Post: | gravitylover (01-03-2019), Ultramaroon (12-24-2018) |
#37 | |
Guess I didn't forget anything.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | krayzie (12-24-2018) |
#38 |
UMMMMM the reason I thought it was electronic was because YOU said it was a while back.
#39 |
That was the Camry. It is.
#40 |
Well you shouldn't talk about other cars here. It confuses us!
#41 |
It was in Reno, dufus.
#42 |
Well you shouldn't talk to me in person it just confuses us.
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (12-24-2018) |
| Dead battery | technoid | BRZ First-Gen (2012+) — General Topics | 17 | 03-17-2016 05:17 PM |
| Dead battery | Mikeez | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 33 | 08-07-2015 10:58 AM |
| Dead battery!?! | Hoahao | Issues | Warranty | Recalls / TSB | 5 | 02-23-2015 05:06 PM |
| BRZ LTD battery drain issue, can't stop open door beep | DoomsdayJesus | Issues | Warranty | Recalls / TSB | 9 | 02-06-2015 07:05 PM |
| Is there any know that how to open the truck when the battery is dead?????? | wilson0326 | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 07-06-2013 10:24 PM |
