Drives: 2013 BRZ Sport-tech
Dead battery - can't open door with mechanical key!
My battery has died - I installed a Lukas-LK290 (to prevent battery from dropping past 12.4 V) and a dash camera with motion detect feature, and I guess I didn't do it right.
I had left a light on before and the battery couldn't start the car, but this time the battery is so dead that the doors won't open. What's strange is that the mechanical key doesn't unlock the driver's door! I can open the trunk, so at least I can get into the car to open the hood and jump it, but I'm wondering if there's any reason why the mechanical key isn't opening the driver's door. Any ideas would be appreciated. Also, I'm going to try to get a new (better - automatic version) battery - I have the battery that came with the manual version of the car (small capacity). I heard some success with this, what helps to get it? |
Drives: BRZ SWP Limited -6MT
from my single time experimenting with the physical key, it was difficult to open likely because you cant quite get enough leverage to rotate the darn thing.
| The Following 2 Users Say Thank You to bababooey For This Useful Post: | Choco (04-27-2015), DarkPira7e (12-23-2018) |
I can rotate it - end to end - or at least it feels like it.
Drives: 16 CBS WRX Limited
Put more elbow grease into it. The first time can be a little stiff and you'll notice a thump/click when it unlocks.
Sport Tech is the same as the Limited: only the driver's door has the lock. |
Well, you were right. It really required a lot of force!
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
You need an aftermarket battery. The Subaru batteries are crap.
| The Following User Says Thank You to ntron1 For This Useful Post: | Choco (04-27-2015) |
Drives: 2015 Series.Blue
| The Following 2 Users Say Thank You to Poodles For This Useful Post: | Hyper4mance2k (05-01-2015), ntron1 (03-24-2015) |
#9 | |
Drives: 2013 GBS BRZ Limited
I calculated that if the car is left for ~10 days without starting it, the battery will run down. Add the camera and thats probably more like 5 days. (Just a WAG) |
| The Following User Says Thank You to stugray For This Useful Post: | Chad86 (08-01-2016) |
#10 |
JHerbert Racing
Drives: 2013 Scion FRS
I must have a miracle battery. I went 2 months without a start. Then on 20 degree Fahrenheit day it fired right up. The cranking was slow. But it fired and the battery still lives today.
#11 |
#12 |
Drives: WRB BRZ 6AT
It really is a weak ass battery. Like Stu said, mine sat for two weeks last month and it couldn't start. And the best part is I parked it front first into my garage....
| The Following User Says Thank You to jflBRZ For This Useful Post: | ntron1 (03-24-2015) |
#14 |
Sarcastic Bastard
| Dead battery | technoid | BRZ First-Gen (2012+) — General Topics | 17 | 03-17-2016 04:17 PM |
| Dead battery | Mikeez | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 33 | 08-07-2015 09:58 AM |
| Dead battery!?! | Hoahao | Issues | Warranty | Recalls / TSB | 5 | 02-23-2015 04:06 PM |
| BRZ LTD battery drain issue, can't stop open door beep | DoomsdayJesus | Issues | Warranty | Recalls / TSB | 9 | 02-06-2015 06:05 PM |
| Is there any know that how to open the truck when the battery is dead?????? | wilson0326 | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 07-06-2013 09:24 PM |
